NEW: HP 15C Collectors Edition
11-01-2023, 01:24 PM
Post: #621
RE: NEW: HP 15C Collectors Edition
I would like to buy the cord need to flash the HP 15C CE.
11-01-2023, 02:02 PM
Post: #622
(11-01-2023 01:24 PM)Eddie W. Shore Wrote: I would like to buy the cord need to flash the HP 15C CE. Who wouldn't? Wait and see... Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
11-01-2023, 04:17 PM
Post: #623
(10-23-2023 02:02 PM)Divasson Wrote: to put HP15c CE claims in perspective, there are 17 claims out of 1200 units shipped by The Calculator Store. Today I add 1 (one) to that count; my HP15C CE arrived yesterday and most of the keys on the right hand side fail to work correctly. I have tried to excercise the keys but that doesn't make any difference. Sad, the calculator is a thing of beauty but essentially useless now. |
11-01-2023, 04:33 PM
Post: #624
RE: NEW: HP 15C Collectors Edition | |||
11-01-2023, 04:47 PM
Post: #625
It looks to be the same cable for flashing the 20b, 30b, 15C LE, etc., correct? I've still got mine around here somewhere, so I should be able to install firmware updates on mine should the need arise. I'm not super concerned about the 16C mode, neat as it is, because I can just pull out my original 16C if I need it. And also (heresy warning) I usually prefer to grab my Casio fx-991EX for doing binary and hex. The two-line display of all 32 bits at once, with spaces making groups of 4 bits each is a lot more convenient than moving the viewing window around on the 16C.
Mostly I'm just using 15.2 mode at the moment for more memory than one could possibly need in a 15C. Are there any known issues or reasons to stick with the default 99-register mode? (Which is still probably more memory than I need...) |
11-01-2023, 04:55 PM
Post: #626
If you already have the 15C, would you still need the 16C?
HP-12C Gold / HP-12C Platinum |
11-01-2023, 04:58 PM
Post: #627
(11-01-2023 04:47 PM)Dave Britten Wrote: It looks to be the same cable for flashing the 20b, 30b, 15C LE, etc., correct? Nope, it's USB: different voltages and pins. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
11-01-2023, 05:24 PM
(This post was last modified: 11-01-2023 05:26 PM by Maximilian Hohmann.)
Post: #628
(11-01-2023 04:55 PM)lvt Wrote: If you already have the 15C, would you still need the 16C? Define „need“ ;-) Almost nobody really needs a pocket calculator in the year 2023 if we are honest. But the HP-16C is maybe one of the calculators that is really useful to some people designing digital hardware and/or doing low-level computer programming. Because it can perform some clever calculations with hexadecimal and binary numbers that most calculator apps on one's mobile phone can't do. And neither Excel or whatever one uses on the computer in the office. And the normal HP-15C can't do that either, only our new 15C CE in HP-16C mode. So if you have one of those you probably don't need an extra 16C! Regards Max NB: The HP-16C is one of very few calculators that I don't have in my collection yet. Because I missed some opportunities 20 years ago (I was very arrogant then regarding calculators and wouldn't touch anything that did not glow in the dark) and now prices have risen to a level that far exceeds my allowance for unnecessary toys... |
11-02-2023, 01:42 AM
Post: #629
Has the new cable been documented anywhere? How to build from scratch or modify the LE cable?
How was the firmware obtained to be patched? Can it be downloaded from the CE (I didn't think this was possible with the LE)? I'd like to patch my 15C CE but don't really want to destroy my LE cable so creating a new one would be ideal I think. (11-01-2023 01:49 AM)Valentin Albillo Wrote: . Calculator Clique on YouTube |
11-02-2023, 03:45 AM
Post: #630
(11-01-2023 05:24 PM)Maximilian Hohmann Wrote: Hello! Thanks for sharing your thoughts. HP-12C Gold / HP-12C Platinum |
11-02-2023, 04:15 AM
Post: #631
(11-02-2023 01:42 AM)dmh Wrote: Has the new cable been documented anywhere? How to build from scratch or modify the LE cable? If you are willing to permanently sacrifice an LE (20b/30b) cable, here are the steps: 1. Open the section with buttons (two #0 Phillips screws), desolder the serial cable, slide off the strain relief to reuse, cut a USB cable, slide the strain relief on the USB cable, and solder the USB cable on. Green from USB goes to TXD, white to RXD, and black to GND2. Red is unused. 2. Cut the two traces from TXD and RXD to the chip using a razor blade or other sharp object, with two separate cuts (see the photo, above and below the left hole). Then make a single long cut to the lower left of the right hole to cut all three traces there (DTXD, DRXD, and VCC). The VCC trace is thicker than the other two. Cutting these is to bypass the level shifter chip. 3. Now you need to solder two jumper wires. Solder one from RXD to DRXD (the top via on the left to the upper-middle via on the right) and one from TXD to DTXD (the bottom via on the left to the lower-middle via on the right). 4. Reassemble (be careful with your wire routing so they don't get squished by the posts when screwing the box back together) and it's all done: The effective wiring is as follows: |
11-02-2023, 05:00 AM
Post: #632
Thanks for the detailed information and photos Eric !
A previous post mentioned a button was still used, which line has the button connected? It appears the wiring is direct and not going through the chip at all now, is that correct? So if you can roll your own pogo type connector could you could make a new cable the same way? So, where do I get the firmware (original and patched) and what software is now required? Thanks again. (11-02-2023 04:15 AM)Eric Rechlin Wrote:(11-02-2023 01:42 AM)dmh Wrote: Has the new cable been documented anywhere? How to build from scratch or modify the LE cable? Calculator Clique on YouTube |
11-02-2023, 06:05 AM
Post: #633
(11-02-2023 05:00 AM)dmh Wrote: Thanks for the detailed information and photos Eric ! The Reset button and Erase button are both still connected. You don't need Reset because you can just use the reset hole on the calculator instead, but the button is more convenient. It's connected in the same place as the old cable, which I believe is pin 2, which would be to the left of the black (ground) wire, lower left corner, in the last image above. I believe Erase is pin 6, which would be to the right of the black ground wire, lower right corner. It's also unchanged from the old cable. Wiring is indeed direct, bypassing the chip. The chip was only used for the TTL to RS-232ish voltage level conversion. Since the new calculators speak USB directly there is no need for any level shifting. As long as you have something to work for the pogo connector, which is the toughest part, you can make your own cable. Software is just a newer version of the SAM-BA software used for programming the older calculators. I have been using version 2.14; I don't see that for download anywhere, but I do see version 2.16 is still available, so maybe you could use that. It still claims to support the sam4l chips so I assume it will work. To flash the calculator, here are the directions I found worked best: 1. Install SAM-BA. 2. Remove the battery door from the calculator and plug in the 6-pin connector from the cable. 3. On the cable, hold down Erase, then press and release Reset, then release Erase. This just puts the calculator in USB linking mode. Unlike on the 20b/30b, this won't actually erase your firmware, so you can safely do this even if you fail to connect in the later steps. 4. Plug the USB connector from the cable to your PC. 5. Wait for it to detect as a USB Serial Device. Then check Device Manager for the COM number; usually I saw COM4 or COM5. 6. Start SAM-BA, make sure the right COM port is selected, and select at91sam4l-ek as the board type: 7. Click Connect. A new window will appear, where you must enter 0x04000 as the address, pick the ROM file to upload, and then click Send File: 8. After the file is done transferring (less than 10 seconds), press the Reset button on the cable (or use the reset hole on the calculator) and then turn the calculator on. If you have a problem anywhere prior to the point where you click "Send File", pressing the Reset button will let you get back to the "Pr Error" display without losing the firmware. If a failure occurs after clicking "Send File", then your calculator may not operate until you can successfully load a new firmware. |
11-02-2023, 10:48 AM
Post: #634
Thanks Eric, that was very clarifying.
So in theory it's possible to connect the calculator to the PC without even the pogo connector, just holding the wires like some of us did with HP20b/HP30b BUT in that regard the USB protocol is pradoxically less forgiving to bad contacts due to the hot-plug negotiation, so having new produced pogo connectors available would be very handy. |
11-02-2023, 01:36 PM
(This post was last modified: 11-02-2023 01:58 PM by ctrclckws.)
Post: #635
Indeed, the explanation was wonderful. However it just convinced me to wait for a standard cable to be produced.
Also, what if you would like an LE/20b/30b cable to update your WP-34S? I saw some recent tweaks in various posts. I asked a forum member for support a while back to do the conversion of my HP-30b, since commercial cables are not available. |
11-02-2023, 10:52 PM
Post: #636
Thanks again Eric.
So the software looks like it can download the current image, is that correct? Then I just need to find the patch details. Does anyone know the pogo pin pitch? I've found 2mm and 2.54mm versions. (11-02-2023 06:05 AM)Eric Rechlin Wrote:(11-02-2023 05:00 AM)dmh Wrote: Thanks for the detailed information and photos Eric ! Calculator Clique on YouTube |
11-03-2023, 08:50 AM
(This post was last modified: 11-03-2023 08:51 AM by linq2008.)
Post: #637
11-03-2023, 02:47 PM
Post: #638
(11-02-2023 10:52 PM)dmh Wrote: So the software looks like it can download the current image, is that correct? According to The Calculator Store blog, the patch is just a change of a couple of bytes in the HP16C rom (but doesn't say which bytes), so it's possible to do it with a hex editor. No need to redistribute the entire firmware that would require HP/Moravia approval. |
11-03-2023, 04:08 PM
(This post was last modified: 11-03-2023 04:09 PM by Divasson.)
Post: #639
(11-03-2023 02:47 PM)ebs Wrote:(11-02-2023 10:52 PM)dmh Wrote: So the software looks like it can download the current image, is that correct? Actually 3 bytes. I'd leave the author to comment/explain - his baby, not mine. Aside from that: with this big memory, it is a pity to lose all programs every time you move back and forth from HP16c to HP15c, so working this weekend on backing up the user memory space to a file and restoring it later. (better solution: buy another !! ) |
11-03-2023, 05:53 PM
Post: #640
Hi, all, (11-03-2023 04:08 PM)Divasson Wrote: [...] with this big memory, it is a pity to lose all programs every time you move back and forth from HP16c to HP15c, so working this weekend on backing up the user memory space to a file and restoring it later. (better solution: buy another !! ) For those interested in using both the HP-15C and the HP-16C it's indeed the best solution by far: you buy a second unit and then you keep one of them permanently in HP-15C/192 mode and the other one permanently in HP-16C mode, both always ready to use at a moment's notice without losing all your programs and data and without wasting time performing tedious backup procedures before the switcheroo. Matter of fact, to put my money where my mouth is, I'm getting my second unit precisely for that very purpose (and also to play it safe in case something would happen to my first one, perish the thought ! ). Hopefully it will arrive tomorrow from The Calculator Store. Besides, come to think of it, people here often express their desire for the release of an HP-16C "Collector's Edition", incredibly fast and with vastly increased memory, which would allow e.g. programming the six trig functions, exp, log, y^x, all of them executing almost instantly and with plenty of program memory to spare. Well, with the overlay in place this is it ! Best regards. V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
