New Saturn asm "add loop" benchmark for the HP48G
11-04-2023, 06:26 PM
RE: New Saturn asm "add loop" benchmark for the HP48G
What also confused me into thinking that dividing by two was necessary is that there are various disparate instruction cycle count lists -- one by Mika Heiskanen, the official one from SASM.DOC and the cycle times reported by CTIM of the HACK library. All these list lower cycle counts ( Also, Cycles du Saturn list ~7MHz to ~8MHz clock speeds, which made me think they were talking about the HFO ). Also, CTIM reports half and quarter cycles, which are absent in Cycles du Saturn. It makes me think that there are no completely accurate cycle counts out there for the Yorke Saturn.
Regards, Jonathan Aeternitas modo est. Longa non est, paene nil. |
11-04-2023, 07:45 PM
(10-26-2023 06:11 PM)Xorand Wrote: I realize this isn't the Prime forum, but I was curious what a Prime G2 could do with just a straight PPL program: here there is a program (likely on the G1) that does it a bit faster. http://www.wiki4hp.com/doku.php?id=benchmarks:addloop - 6,646,300 (and I likely missed some updates over time, I don't keep track of everything but on the wiki everyone could contribute if they register!) Wikis are great, Contribute :) |
11-04-2023, 07:47 PM
(10-27-2023 12:56 AM)Valentin Albillo Wrote:(10-26-2023 06:11 PM)Xorand Wrote: [...] I was curious what a Prime G2 could do with just a straight PPL program:[...] Result was 4,979,849 ! Though I would expect that the Ipad2 is much more beefy than the prime (G1 or G2) and of course could add even more if the free42 could run multiple time (one per core). I wonder if here is a version of the prime for iOS. I know that is there for android. Wikis are great, Contribute :) |
11-04-2023, 08:26 PM
(11-04-2023 07:47 PM)pier4r Wrote: I wonder if here is a version of the prime for iOS. I know that is there for android. There is. https://apps.apple.com/us/app/hp-prime-pro/id1064702857 --Bob Prosperi |
11-05-2023, 02:49 PM
Assuming the cycle counts from "Cycles du Saturn" are accurate ( which I doubt as they don't contain any half or quarter cycles due to Saturn bus NSTR cycle stretching ), then an estimated count for Werner's original non-unrolled add loop would be :
\( \dfrac{3900000 \cdot 60}{49} \approx 4775510 \) This is 392325 larger than the actual count. Again, assuming the cycle counts I've been referencing are accurate, then this means something is stealing about (392325/60)*49 ~ 320398 cycles/sec . I know TIMER2, when running, steals a small amount of cycles for the purposes of keyboard polling every 1mS. Also, the card detect circuitry steals cycles while it's enabled. I'm dubious as to whether the aforementioned cumulative overhead steals ~320398 cycles/S, but I'm not sure. If the lower performance of my code can't be explained by taking the above into account, then we have a mystery. Regards, Jonathan Aeternitas modo est. Longa non est, paene nil. |
11-06-2023, 12:10 PM
Maybe you will find correct cycle count here:
https://www.hpcalc.org/hp48/docs/programming/cycles.zip This document contain quarter cycles, compiled by Mika Heiskanen From the title of the document it is for the 48GX model. br Gjermund |
11-06-2023, 04:30 PM
(11-06-2023 12:10 PM)Gjermund Skailand Wrote: Maybe you will find correct cycle count here: Yes, I know about Mika's cycle count doc The problem is that -- I think -- the cycle counts only take into account the number of NSTR cycles taken up by the Saturn bus and the internal execution time taken up by the CPU disregarding the time taken up by the memory controllers. The same goes for SASM.DOC . If we use Mika's cycle counts, we have :
This means ( at least at even addresses ) that, according to Mika's counts, Werner's inner add loop takes 12.75 cycles which means : (3900000*60)/12.75 ~ 18352941 which is obviously wrong. Also, with SASM.DOC :
which is a total of 17 cycles, and therefore we have : (3900000*60)/17 ~ 13764705 which is also obviously wrong. AFAIK, there are no completely accurate cycle counts that take into account the memory controllers, the Saturn bus and the CPU execution time. Regards, Jonathan Aeternitas modo est. Longa non est, paene nil. |
11-06-2023, 05:26 PM
(11-05-2023 02:49 PM)Jonathan Busby Wrote: [snip]...something is stealing about (392325/60)*49 ~ 320398 cycles/sec . I know TIMER2, when running, steals a small amount of cycles for the purposes of keyboard polling every 1mS. I think keyboard polling may be the culprit : (320398/1024) ~ 313 -- which means that each keyboard poll takes about 313 cycles. Quote:Also, the card detect circuitry steals cycles while it's enabled. Actually, although I'm not completely sure, I think this isn't the case. Quote:I'm dubious as to whether the aforementioned cumulative overhead steals ~320398 cycles/S, but I'm not sure. If the lower performance of my code can't be explained by taking the above into account, then we have a mystery. The only way to determine this for sure is to use a hardware Saturn bus analyzer. Regards, Jonathan Aeternitas modo est. Longa non est, paene nil. |
11-07-2023, 06:12 PM
(11-05-2023 02:49 PM)Jonathan Busby Wrote: Assuming the cycle counts from "Cycles du Saturn" are accurate ( which I doubt as they don't contain any half or quarter cycles due to Saturn bus NSTR cycle stretching ), then an estimated count for Werner's original non-unrolled add loop would be : Have you thought about the UMA architecture sharing the main RAM between CPU und display controller in connection with the Clarke and York chip? Not ony keyboard polling or card detection need some extra cycles, quote from the Clarke document: "The CPU is halted for 22-23 uS every 244 uS to read the data." To avoid this, switch off the display during program execution. (11-05-2023 02:49 PM)Jonathan Busby Wrote: Assuming the cycle counts from "Cycles du Saturn" are accurate ( which I doubt as they don't contain any half or quarter cycles due to Saturn bus NSTR cycle stretching ) This is an extraction of the HP17BII =BPUTL source code. This code was designed to run on on the Saturn-ROM inside the Lewis chip or with different timing contants on an external 8-bit ROM chip. The Saturn cycles are in [] where as the MEMC cycles are in (). Code:
For thoose who may ask, sorry I don't have the complete HP17BII souece code, only the =BPUTL and =CHECKSUM implementations. Also no further information about the NSTR cycle stretching. The HP17BII entry point table is part of the Emu42 installer distribution so when runnung a HP17BII inside Emu42 you can easily jump to the =BPUTL code entrypoint in the Debugger. |
11-08-2023, 06:26 PM
(11-07-2023 06:12 PM)Christoph Giesselink Wrote: Have you thought about the UMA architecture sharing the main RAM between CPU und display controller in connection with the Clarke and York chip? At the very beginning of the program the display is turned off via =DispOff Also, I thought the card detection circuitry ran independently of the CPU? Quote:Also no further information about the NSTR cycle stretching. This seems to be undocumented and a big mystery. Regards, Jonathan Aeternitas modo est. Longa non est, paene nil. |
11-09-2023, 10:51 AM
(This post was last modified: 11-11-2023 11:03 AM by dlidstrom.)
This program will run until keypress and will calculate the per minute number of additions. Using iHP48 on my iPhone Xs it reports about 5-7 million (!) additions. Imagine a physical device at that speed!
2xHP48GX, HP 50g, two Retrotronik ram cards, DM42 /Daniel Lidström |
