HP 50g Compare Strings?
09-01-2014, 12:03 PM
How do you compare the contents of a variable to a string in algebraic notation on an HP 50g? I've tried both the following ('a' contains either "Y" or "N")
Of course neither one works. So how do you do it? TIA Tom L Tom L Cui bono? |
09-01-2014, 12:09 PM
RE: HP 50g Compare Strings?
(09-01-2014 12:03 PM)toml_12953 Wrote: How do you compare the contents of a variable to a string in algebraic notation on an HP 50g? I've tried both the following ('a' contains either "Y" or "N") Suggestion: Don't use an algebraic. Just use IF a "Y" SAME THEN. <0|ɸ|0> -Joe- |
09-01-2014, 01:25 PM
(09-01-2014 12:09 PM)Joe Horn Wrote:That works, thanks! You should be canonized, but I can't find my cannon at the moment. ;^)(09-01-2014 12:03 PM)toml_12953 Wrote: How do you compare the contents of a variable to a string in algebraic notation on an HP 50g? I've tried both the following ('a' contains either "Y" or "N") Tom L Cui bono? |
09-01-2014, 10:24 PM
(09-01-2014 01:25 PM)toml_12953 Wrote: That works, thanks! You should be canonized, but I can't find my cannon at the moment. ;^) No need; I'm already a canon regular. <0|ɸ|0> -Joe- |
09-02-2014, 03:07 AM
(09-01-2014 10:24 PM)Joe Horn Wrote:(09-01-2014 01:25 PM)toml_12953 Wrote: That works, thanks! You should be canonized, but I can't find my cannon at the moment. ;^) An absolutely perfect setup like that does not come along every day --Bob Prosperi |
09-04-2014, 06:35 AM
(This post was last modified: 09-04-2014 07:39 AM by toml_12953.)
(09-01-2014 10:24 PM)Joe Horn Wrote:(09-01-2014 01:25 PM)toml_12953 Wrote: That works, thanks! You should be canonized, but I can't find my cannon at the moment. ;^) You win! BTW, I figured out how to do what I originally wanted to do. To test for a string in algebraic notation, enclose the test in reverse quotes (the character just before the lowercase a in the CHAR screen.) This works: Code: IF `a=="N"` THEN Tom L Cui bono? |
