HP-42S Compiler for Niklaus Wirth's PL/0 Language
01-14-2024, 04:01 PM
Introduction
Recently I stumbled upon the book Compilerbau by Niklaus Wirth. A small language PL/0 is used to illustrate how to write an interpreter and a compiler. For the compiler a stack-based machine is assumed. Thus I wondered if an HP-calculator could be used as target. There's a PL/0 Language Tools project but it appears to be abandoned. The last commit on the GitHub repository was made 7 years ago. It is still based on Python 2 which is now dead. The Language PL/0 It is a simplified variant of Pascal with the following EBNF: Code: program = block "." . Installation and Setup Download Project Download the ZIP-file and unzip it. unzip pl0-compiler.zip It should contain the following files: Code: Archive: pl0-compiler.zip Setup the Virtual Environment python3 -m venv venv source venv/bin/activate pip install --upgrade pip setuptools wheel pip install ply Programs Some example programs can be found in the examples directory. Fibonacci Code: # This program calculates the first K values of the fibonacci sequence. Compile to HP-42S The program pl0_hp42s.py is based on pl0_compiler.py and creates commands for the HP-42S: python pl0_hp42s.py examples/fibonacci.pl0 Code: GTO 00 # main Caveat Input Output For input and output use ? and !: ?n; ?k; CALL perm; !p Syntax The syntax for comparisons is slightly changed. Instead of = for equal use ==. Instead of # for not equal use !=. Integer Division It is assumed that the machine uses only integers. Therefore division results in integers. However I find it more useful to use the ordinary division on an HP-42S. It is easy to include the IP command if that is needed. Or then replace ÷ by BASE÷ in the code: Code: elif term[0] == "DIVIDE": Recursion Due to the limited size of the return stack of the HP-42S I assume that recursion doesn't really work. Scope of Variables The same variable name can be used local to a procedure but these are still mapped to global registers. Cf. examples/scope.pl0 ![]() |
02-17-2024, 10:41 AM
RE: HP-42S Compiler for Niklaus Wirth's PL/0 Language
In his talk "Reinventing the Parser Generator" David Beazley explains his ply project that is used here:
02-17-2024, 05:02 PM
(02-17-2024 10:41 AM)Thomas Klemm Wrote: In his talk "Reinventing the Parser Generator" David Beazley explains his ply project that is used here: That was fun to watch ![]() "Reinventing the Parser Generator" is a big stretch IMO. More like "Implementing Lex and Yacc in Python and how to Mess it Up" ![]() Seriously. Ply doesn't even warn when token regex patterns are subsumed, only for us to find out the tokenizer we wrote does not work? Hacking around a way to define a "PRINT" token to not match ID is pure evil. And what about LALR conflicts? Yacc and Bison not only warn, but also output annotated LALR states (dot rules) that help identify the problem to correct. Ambiguous grammars lead to all sorts of nasty problems. Disingenuous to disparage the Dragon book. It's all there and better. Don't teach students tools to use. Teach them how to write them and write them well by teaching the beauty of the underlying algebraic structures and corresponding algorithms. Then use tools, because you don't have to reinvent them. Unless you can significantly improve them (good luck). - Rob "I count on old friends to remain rational" |
02-18-2024, 09:32 AM
(02-17-2024 05:02 PM)robve Wrote: Teach them how to write them and write them well by teaching the beauty of the underlying algebraic structures and corresponding algorithms. What tools would you suggest if we want to compile a language to the HP-42S?
And which language would you use?
02-18-2024, 11:42 AM
prolog.
a prolog interpreter for lisp https://www.metalevel.at/lisprolog/ HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D |
02-18-2024, 12:45 PM
There are also Parsing Expression Grammars and, for some reason, Lua seems to be the most popular language to implement them in.
There's an intro here but I've not gone through it closely so no guaranties as to its quality. |
02-18-2024, 02:59 PM
(02-18-2024 11:42 AM)floppy Wrote: prolog. Thanks for sharing. I like these kind of projects very much, that are a little different than the usual PL projects. Here's a lazy functional language interpreter written in Prolog: Husky (disclaimer: which I wrote in the 90s). On the topic of Lisp: a lua-to-lisp transpiler with the transpiler written in lex and yacc (actually, RE/flex and Bison, but that's just about the same). RE/flex does a lot more than lex (and flex) though, to make lexical analysis easier to specify and implement in C++. Pick what you like:
Deterministic context-free LR(1) (LALR) grammars are far more common than LL. LL requires a rewrite to remove left recursion and also to explicitly deal with (or remove) ambiguity. PEGs originate from LL parsing (i.e. top down) but take a different approach to resolve some issues with LL. The list of tools and choices is extensive and covers a wide range of PL to implement a parser. A hand-written R-D parser for a tiny PL is fun and nice to implement too, especially if the grammar is already defined as a R-D grammar (LL, top down) and was tested, so you're not getting stuck in a long rinse-repeat cycle of testing and tweaking the grammar/parser. It is often a good choice to implement parsing on embedded devices and yesteryears 8-bit systems. - Rob "I count on old friends to remain rational" |
02-21-2024, 12:35 PM
I've used Flex and Bison for many years, including use in the microassembler packaged with Nonpareil. Most of this was in C, and I haven't yet converted any of those to use the native C++ support in Flex or Bison. I wasn't previously aware of RE/flex, but it looks quite appealing since much of my development is now in C++. Thanks for pointing it out!
I've also in the last yew years used some PEG parsers, including pyparsing for Python, and PEGTL for C++. I've used PEG for some of my more recent, non-calculator-related programs. pyparsing has some good support for ignoring whitespace between tokens (which can of course be disabled), but unfortunately PEGTL does not. For those not familiar with PEG (Precedence Expression Grammars): PEG is interesting in that it's generally used with a single rule set that does both tokenization (as might be done by flex) along with parsing (as might be done with bison). While one could use two layers of PEG, one for scanning and one for parsing, I've never seen that done. Debugging a PEG parser can be challenging because PEG doesn't detect shift/shift or shift/reduce conflicts. PEG uses the first matching production (hence the "Precedence"). Once it finds that first matching production, it does not care about, nor warn about, ambiguity, because the ordering always will disambiguate cases where multiple productions could match. This is simultaneously a blessing and a curse. Trying to adapt LR or LALR rgrammars for any non-trivial language to PEG, or writing a PEG grammar from an LR or LALR mindset, yields much frustration, because the syntax of productions is basically the same, but there's that huge difference in semantics. If you're accustomed to Yacc or Bison, it takes a lot of getting used to. For instance, a grammar to parse C style unsigned integers in decimal, octal with a leading zero, or hexadecimal with a leading "0x", doesn't work if you write it as: dec_lit: [0-9]+ oct_lit: 0[0-9]+ hex_lit: 0x[0-9a-fA-F]+ lit: dec_lit | oct_lit | hex_lit That will interpret intenxed octal literals as decimal, and intended hex literals as a decimal 0 with the x and subsequent digits not consumed as part of lit. If you reverse the order of the alternatives in the lit production, then it will work as desired. You may be able to guess how I learned this. :-) |
