Rebooting when connected to connectivity kit
03-06-2024, 06:59 PM
My Prime keeps rebooting when connected to my pc when i try to use the connectivity kit. Latest firmware is installed (20230413). I haven't had this problem before so i think maybe i should try to downgrade the firmware?
Any tips on how I can do this?
03-07-2024, 01:25 PM
RE: Rebooting when connected to connectivity kit
This is a known issue occurring on G1.
Just perform a memory clear (ON + APPS + ESC). This will delete all data, but it will resolve the issue, allowing you to work with the Connectivity Kit properly. If you had cleared the data before upgrading to the new firmware, the problem would not have occurred.
Piotr
03-08-2024, 07:55 AM
(03-07-2024 01:25 PM)komame Wrote:  This is a known issue occurring on G1.
Piotr
I'm trying to downgrade the FW also but i cant seem to do that, is there any way i can find older FW versions, i found an old post about this but the links don't work anymore..
03-08-2024, 05:55 PM
https://www.hpcalc.org/prime/
has some versions of the CK, and firmware; not sure if any are old enough?
Cambridge, UK
Casio, Rockwell 18R
03-10-2024, 03:28 PM (This post was last modified: 03-10-2024 03:28 PM by Jacob Wall.)
Login to hpcalc.org, then you will see previous versions to download.
For example https://www.hpcalc.org/details/7783 shows 8 different firmware versions for G2, and https://www.hpcalc.org/details/7469 shows 14 different firmware versions for G1.
