on-off button on HP 11C
03-29-2024, 09:34 PM
I can only turn on or off my HP 11C after multiple attempts. Would cleaning and restoring the conductivity of the switch/pad correct the problem?
03-30-2024, 07:59 PM
RE: on-off button on HP 11C
You may be able to clean the contacts under a key that is not responding without disassembling the heat-staked keyboard. See post #2 by David Smith in the following thread:
https://www.hpmuseum.org/cgi-sys/cgiwrap...read=26479 |
