Info on 5061-7271 Data Comm for the HP-71>
04-17-2024, 07:56 AM
I see a Data Comm module available on eBay but I can't find any manual for it online. Does anyone have a manual they can share or that I can buy? Also, does this module require a mag card to load software? I can't find any reference to it at all online.
Tom L
Cui bono?
04-17-2024, 08:20 AM (This post was last modified: 04-17-2024 08:21 AM by floppy.)
RE: Info on 5061-7271 Data Comm for the HP-71>
According this https://www.hpmuseum.org/cgi-sys/cgiwrap...ead=203736
It is the HP 82488A
which is decribed there https://www.hpmuseum.org/forum/thread-6181.html
full pdf for "82488A" found there https://literature.hpcalc.org/community/...-om-en.pdf
04-17-2024, 02:14 PM
(04-17-2024 08:20 AM)floppy Wrote:  According this https://www.hpmuseum.org/cgi-sys/cgiwrap...ead=203736
It is the HP 82488A
Thanks! I didn't know the 82488A designation so it was hard to locate. Now I just need to buy a module.
Tom L
Cui bono?
04-17-2024, 02:43 PM
Why buying a module? Just buy a MULTIMOD (with your module inside; or not, then you can upload on your own into it).
Modules are nomore needed. MULTIMOD is the tool for module use.
04-17-2024, 05:37 PM
If you have enough RAM, you can also load the software in your HP-71B.
Alternatively, fire up Emu71, load the module and play with it.
Sylvain Côté
04-17-2024, 10:41 PM
(04-17-2024 02:43 PM)floppy Wrote:  Why buying a module? Just buy a MULTIMOD (with your module inside; or not, then you can upload on your own into it).
Is the MULTIMOD still available? If so, where? I googled it but didn't find a place to order it.
Tom L
Cui bono?
04-18-2024, 06:53 AM (This post was last modified: 04-18-2024 07:27 AM by floppy.)
(04-17-2024 10:41 PM)toml_12953 Wrote:  Is the MULTIMOD still available? If so, where? I googled it but didn't find a place to order it.
contact > hp71multimod@gmail.com
https://github.com/mafleming/HP71MultiMod
.. lot of informations there https://www.hpmuseum.org/forum/thread-16...t=multimod
