Mathematician Finds Easier Way to Solve Quadratic Equations
04-28-2024, 11:35 AM
RE: Mathematician Finds Easier Way to Solve Quadratic Equations
Ok folks .... any one can talk about fractional derivatives ... would like to see us move a bit forward in math topics!!!!
Math is fun .... but trivial math can be a bit boring!!! Namir |
04-28-2024, 02:02 PM
"Easier" way is really for educationally purpose, instead of memorizing quadratic formula.
Let roots = m ± g (all parabola look like this) (x - (m+g)) * (x - (m-g)) = x² + (-2m) x + (m²-g²) Match this to x² + (b/a) x + (c/a) = 0 b/a = -2m c/a = m²-g² LHS is just constants. Solve for m, then for g We can use same pattern trick for cubic roots. Solve for y, then z = p/(-3y) (07-20-2021 10:12 PM)Albert Chan Wrote: x³ + y³ + z³ − 3xyz = (x+y+z) * (x+yω+z/ω) * (x+y/ω+zω), where ω = e^(i*2*pi/3) https://math.stackexchange.com/questions...2ab-omega2 |
05-01-2024, 04:57 PM
(This post was last modified: 05-01-2024 04:58 PM by Gerson W. Barbosa.)
(04-24-2024 12:20 AM)Thomas Klemm Wrote: The lyrics are available in the video description. I’ll place the text in a code box for space reasons. Anyway, human languages are technically codes. Google translate is not perfect, but those of us non-German speakers can have a good idea of what is being sung. I know this hasn’t been addressed to all, but thanks for posting! Code:
Since we’re at it I decided to take a look at the work you did fourteen years ago (last messages in this old thread) in order to try to fully understand it. Given the second degree equation \(x^2+px+q=0\) we can find the first root, as we have seen, with help of a this very compact formula: \(x_{1}=-\frac{p}{2}+\sqrt{\left({-\frac{p}{2}}\right)^2-q}\) This is suitable for minimizing the number of programming steps, but like the traditional formula it is subject to cancellation errors in some extreme cases. Hence your motivation for another method which avoids this problem. I’ll try to reproduce your steps to arrive at the formula you presented then. Multiply and divide the expression inside the surd by q and take the multiplying factor in the numerator out of it: \(x_{1}=-\frac{p}{2}+\sqrt{q}\sqrt{\frac{\left({-\frac{p}{2}}\right)^2-q}{q}}\) Multiply and divide the first term by √q: \(x_{1}=\sqrt{q}\left({-\frac{p}{2\sqrt{q}}}\right)+\sqrt{q}\sqrt{\left({-\frac{p}{2\sqrt{q}}}\right)^2-1}\) \(x_{1}=\sqrt{q}\left({-\frac{p}{2\sqrt{q}}+\sqrt{\left({-\frac{p}{2\sqrt{q}}}\right)^2-1}}\right)\) Make \(z=-\frac{p}{2\sqrt{q}}\) Use the identity \(\cosh^{-1}{(z)}=\ln\left({z+\sqrt{z^2-1}}\right)\) or \(e^{\cosh^{-1}{(z)}}=z+\sqrt{z^2-1}\) Then \(x_{1}=\sqrt{q}\times e^{\cosh^{-1}{(-\frac{p}{2\sqrt{q}}})}\) The second root can be computed as \(x_{1} x_{2}= q\) \(x_{2}=\frac{q}{x_{1}}\) Done totally by hand. Hopefully no mistakes or typos. HP-42 program Code:
Example: \(10^{-13}x^2-2x+1=0\) E +/- 13 ENTER 2 +/- ENTER XEQ Q -> T: previous X Z: previous X Y: 0.50000000001 X: 1.9999999996E13 Best regards, Gerson. |
05-01-2024, 06:51 PM
(05-01-2024 04:57 PM)Gerson W. Barbosa Wrote: Given the second degree equation Nice! And, we can make formula more compact, 2 roots with ± (08-01-2021 03:08 PM)Albert Chan Wrote: We can also solve for z² - 2*m*z + n² = 0 tan/asin quadratic formula based from tan half-angle formula: sin(x) = 2t/(1+t^2), where t = tan(x/2) t^2 - 2*(1/sin(x))*t + 1 = 0 exp/acosh quadratic formula based from cosh definition. cosh(x) = (y + 1/y)/2, where y = e^x y^2 - 2*cosh(x)*y + 1 = 0 Above patterns matched with scaled z² - 2*m*z + n² = 0 (z/n)^2 - 2*(m/n)*(z/n) + 1 = 0 |
05-01-2024, 09:28 PM
(05-01-2024 04:57 PM)Gerson W. Barbosa Wrote: Since we’re at it I decided to take a look at the work you did fourteen years ago (last messages in this old thread) in order to try to fully understand it. My first post in this forum was this reply: Re: Short quadratic solver (HP-15C) (05-01-2024 04:57 PM)Gerson W. Barbosa Wrote: (…) but like the traditional formula it is subject to cancellation errors in some extreme cases. Hence your motivation for another method which avoids this problem. Palmer's program uses a different approach: A "Cadillac" Quadratic Solver for the hp 33s and HP35s My article attempts to explain how it works: Solve the real quadratic equation \(c-2bz+az^2=0\) for real or complex roots. |
05-01-2024, 11:08 PM
(This post was last modified: 05-01-2024 11:09 PM by Gerson W. Barbosa.)
(05-01-2024 06:51 PM)Albert Chan Wrote:(05-01-2024 04:57 PM)Gerson W. Barbosa Wrote: Given the second degree equation Yes, \(x_{1,2}=\sqrt{q}\times e^{±\cosh^{-1}{(-\frac{p}{2\sqrt{q}}})}\) but I am mainly interested in program optimization. Anyway we can save one step with it, but at the cost of an extra couple of bytes: Code:
MEM says I have 1647 bytes left on the HP-42S and 433569792 on Free42. I don’t think memory should be a concern. |
05-02-2024, 02:00 PM
(This post was last modified: 05-05-2024 09:21 PM by Albert Chan.)
(05-01-2024 11:08 PM)Gerson W. Barbosa Wrote: \(x_{1,2}=\sqrt{q}\times e^{±\cosh^{-1}{(-\frac{p}{2\sqrt{q}}})}\) exp/cosh quadratic formula avoided subtraction canellation, but introduced another. Exponential function slope is also an exponential function! e^(x*(1-ε)) ≈ e^x - (x*e^x)*ε RelErr(x) = ε ⇒ RelErr(e^x) = (exact - approx) / exact ≈ (x*e^x)*ε / e^x = x*ε Fortunately, acosh is similar to log, keeping size of x in check. Still, Trig (tan/asin) quadratic version is perhaps more accurate. Code: 00 { 24-Byte Prgm } 1E-13 Enter -2 Enter 1 XEQ "Q" Y : 19,999,999,999,999.49999999999998749992 // error = 8 ULP X : 5.000000000000125000000000006250021e-1 // error = -21 ULP 1E-13 Enter -2 Enter 1 XEQ "T" Y: 5.000000000000125000000000006250001e-1 // error = -1 ULP X: 19,999,999,999,999.4999999999999875 // error = 0 ULP There is another issue. acosh(x) has real domain x≥1 Trig quadratic version does not have this problem. (tan/asin both odd functions) 1E-13 Enter 2 Enter 1 XEQ "Q" Y: -19,999,999,999,999.49999999999998749992-2.31605661201243998216520079425921e-21i X: -0.500000000000012500000000000625002+5.790141530031389462489503558740034e-35i 1E-13 Enter 2 Enter 1 XEQ "T" Y: -5.000000000000125000000000006250001e-1 X: -19,999,999,999,999.4999999999999875 Update: here is e^asinh version. Determinant Δ = (p/2)² - q It has the same RelErr(e^x) issue ... not recommended. \( x_{1,2}= \sqrt{q}× e^{±\sinh^{-1} \sqrt{\frac{Δ}{q}} } \) |
05-03-2024, 02:02 PM
(This post was last modified: 05-04-2024 07:07 PM by Gerson W. Barbosa.)
(05-02-2024 02:00 PM)Albert Chan Wrote:(05-01-2024 11:08 PM)Gerson W. Barbosa Wrote: \(x_{1,2}=\sqrt{q}\times e^{±\cosh^{-1}{(-\frac{p}{2\sqrt{q}}})}\) Very nice! Thanks for this alternative method, useful for both Free42 and the HP-42S. The following is longer, but preserves the previous stack register X for later use. Some optimization is still possible, I think. Code:
On the real HP-42S, in DEG mode: E 13 +/- ENTER 2 +/- ENTER 1 XEQ T -> Y: 4.99999999999E-1 Y: 2.00000000000E13 Same answers in RAD mode. RAD mode appears to be slightly more accurate. No reason to change the angular mode just for that reason, I think. (Mine is most of the time in DEG mode). This is my very first calculator program, written for the SHARP EL-5813 back in 1981: 2ndF LRN ( ( ( K₂ +/- + ( K₂ x² - 4 K₁ K₃ ) 2ndF √ ) ÷ 2 K₁ ) 2ndF LOOK + K₂ ÷ K₁ ) +/- 2ndF LRN I don’t have it anymore, but I remember the usage was a STO K₁ b STO K₂ c STO K₃ COMP Quadratic equations were often needed to be solved during my first college years, Physics then EE, so I always kept a quadratic solver in the programmable calculator I was using at the moment (TI-51-III, TI-59, HP-15C, HP-28S and HP-48GX). No Cadillac solvers needed for those trivial equations, though. My Beetle solvers did just fine! :-) Edited to fix a typo and an orthographic error. |
05-03-2024, 04:36 PM
(05-02-2024 02:00 PM)Albert Chan Wrote:(05-01-2024 11:08 PM)Gerson W. Barbosa Wrote: \(x_{1,2}=\sqrt{q}\times e^{±\cosh^{-1}{(-\frac{p}{2\sqrt{q}}})}\) Interesting formula but it uses more CPU power to calculate invers cosh and exp(x) in addition to the square root! Namir |
05-03-2024, 11:03 PM
(This post was last modified: 05-04-2024 03:06 AM by Albert Chan.)
Trivia: with signed zero, e^acosh(z) is an odd function!
acosh(z) = acos(z) * ±i // sign to ensure acosh non-negative real part. acos(z) + acos(-z) = pi // acos has non-negative real part too: 0 .. pi acosh(z) * ∓i + acosh(-z) * ±i = pi // im(acos(z)) = - im(acos(-z)) acosh(z) - acosh(-z) = ±pi*i // multiply both side by ±i e^acosh(z) / e^acosh(-z) = -1 // Euler Identity, e^(pi*i) = -1 e^acosh(z) = - e^acosh(-z) Identity might still hold without signed zero, but I have not checked edge cases. Another proof for acosh(z) - acosh(-z) = ±pi*i versin(x) = 1 - cos(x) = 2*sin(x/2)^2 → acos(1-x) = 2*asin(sqrt(x/2)) acos(z) = 2*asin(sqrt((1-z)/2)) = 2*atan(sqrt((1-z)/(1+z))) acosh(z) = 2*asinh(sqrt((z-1)/2)) = 2*atanh(sqrt((z-1)/(z+1))) acosh(z) - acosh(-z) = 2*atanh(u) - 2*atanh(1/u)) , where u = sqrt((z-1)/(z+1)) = ln(v) - ln(-v) , where v = (1+u)/(1-u) = ±pi*i |
05-04-2024, 02:24 PM
(This post was last modified: 05-08-2024 10:58 AM by Albert Chan.)
(05-01-2024 04:57 PM)Gerson W. Barbosa Wrote: Use the identity Above identity does not hold, if sign(Re(z)) = -1 acosh(z) = ln(z + √(z+1) * √(z-1)) // 2 square roots to ensure acosh non-negative real part Example: z = -2 ln(-2 + √(-1) * √(-3)) = ln(-2 − √3) ≈ +1.31696 + pi*i ln(-2 + √((-2)^2 - 1)) = ln(-2 + √3) ≈ −1.31696 + pi*i For acosh √(z²-1) form, we need to match sign, to ensure non-negative real part. Again, assume sign(x) = ±1, never 0 \(e^{\cosh^{-1}{(z)}}=z + sign(\Re(z)) \;\sqrt{z^2-1}\) It is now trivial to show e^acosh(z) is an odd function: e^acosh(z) = - ((-z) + sign(Re(-z)) * √((-z)²-1)) = - e^acosh(-z) Update: Perhaps better proof e^z = (e^z+1/e^z)/2 + (e^z-1/e^z)/2 = cosh(z) + sinh(z) e^acosh(z) = cosh(acosh(z)) + sinh(acosh(z)) = z + sign(Re(z)) * √(z²-1) |
05-04-2024, 07:37 PM
(05-03-2024 02:02 PM)Gerson W. Barbosa Wrote: The following is longer, but preserves the previous stack register X for later use. Some optimization is still possible, I think. This saves four bytes and four steps: Code:
On the real HP-42S, in DEG mode: E 13 +/- ENTER 2 +/- ENTER 1 XEQ T -> Y: 0.5 Y: 2.E13 On Free42, in DEG mode: E 13 +/- ENTER 2 +/- ENTER 1 XEQ T -> Y: 0.500000000000012500000000000625 X: 19,999,999,999,999.4999999999999875 \(x_{1}=\left({\cos\left({\arcsin{\frac{\sqrt{q}}{-\frac{p}{2}}}}\right)+1}\right)\times-\frac{p}{2}\) That is equivalent to Albert Chan’s formula. \(x_{2}=\frac{q}{x_{1}}\) |
05-04-2024, 11:19 PM
(This post was last modified: 05-07-2024 12:09 AM by Albert Chan.)
(05-04-2024 07:37 PM)Gerson W. Barbosa Wrote: \(x_{1}=\left({\cos\left({\arcsin{\frac{\sqrt{q}}{-\frac{p}{2}}}}\right)+1}\right)\times-\frac{p}{2}\) Going for x²+p*x+q=0 big root ... I like it! ![]() cos(asin(z)) = √(1-z²) // both sides have non-negative real part x1 = (√(1 - q/(-p/2)²) + 1) * -p/2 x2 = q/x1 Another way to see this: x^2 + p*x + q = 0 // x = (-p/2)*y y^2 - 2y + sin(θ)^2 = 0 // sin(θ)^2 = q/(-p/2)^2 (y-1)^2 = cos(θ)^2 y = 1 ± cos(θ) |
05-04-2024, 11:52 PM
The following geometric approach uses the right triangle altitude theorem.
Given \(c = p + q\) and \(h^2 = p \cdot q\) we get: \( \begin{align} 0 &=(x - p)(x - q) \\ &= x^2 - (p+q)x + p \cdot q \\ &= x^2 - c x + h^2 \\ \end{align} \) But then also: \( \begin{align} c &= 2r \\ r^2 &= h^2 + d^2 \end{align} \) And therefore: \( \begin{align} r &= \frac{c}{2} \\ d &= \sqrt{r^2 - h^2} \\ \\ p &= r + d \\ q &= r - d \\ \end{align} \) Example \( \begin{align} x^2 - 5x + 6 = 0 \\ \end{align} \) \( \begin{align} c &= 5 \\ h^2 &= 6 \\ \\ r &= 2.5 \\ d &= \sqrt{6.25 - 6} \\ &= \sqrt{0.25} \\ &= 0.5 \\ \\ p &= 2.5 + 0.5 = 3 \\ q &= 2.5 - 0.5 = 2 \\ \end{align} \) |
05-05-2024, 02:24 AM
(This post was last modified: 05-05-2024 02:28 AM by Namir.)
Let's keep in mind the KISS principle (keep it simple stupid), or what Einstein said, "Make it simple, but no simpler". Using fancy functions like cosh, exp, sin, and so on is fancy, but introduces a bit of complicatrion in my very humble opinion.
Wat's next? Solving systems of linear equations using Cramer's rule??? Namir |
05-05-2024, 06:31 AM
(05-05-2024 02:24 AM)Namir Wrote: Wat's next? Solving systems of linear equations using Cramer's rule??? And what’s wrong with using Cramer’s rule for linear systems? :) |
05-05-2024, 11:07 AM
(05-05-2024 02:24 AM)Namir Wrote: Wat's next? Solving systems of linear equations using Cramer's rule??? How about using the HP-67 to evaluate the determinant of a square matrix by repeated applications of the process of pivotal condensation? |
05-05-2024, 12:48 PM
(05-05-2024 02:24 AM)Namir Wrote: Let's keep in mind the KISS principle (keep it simple stupid), or what Einstein said, "Make it simple, but no simpler". Yes, it's amazing. A simple statement "Mathematician Finds Easier Way to Solve Quadratic Equations" has turned into "how many HP calculator nerds does it take to change a lightbulb?" ;-) But apart from that I keep wondering why the quadratic equation and it's memorized solution is attributed such a high significance by schools. I have never since finishing school come across a quadratic equation in real life. Things are mostly simple and can be handled with linear calculations ("if my plane needs 1400 pounds of fuel in one hour, how much must I take along for a 2:25h flight?") or they are really complicated and require higher order polynomials, transcendental funcions or numeric solutions. But a quadratic equation? Never ever. Regards Max |
05-05-2024, 01:18 PM
(05-05-2024 06:31 AM)carey Wrote:(05-05-2024 02:24 AM)Namir Wrote: Wat's next? Solving systems of linear equations using Cramer's rule??? In the late 80s I attended a programmers' conference in Boston. A speaker mentioned that he encountered a math application that was running WAY TOO SLOW! When he checked the source code, he found that the code author was using Cranmer's method to solve linear equations. You should have heard the attendees reaction .. a resounding ouuuuuuuh!!! Just sharing! |
05-05-2024, 01:23 PM
(05-05-2024 11:07 AM)Thomas Klemm Wrote:(05-05-2024 02:24 AM)Namir Wrote: Wat's next? Solving systems of linear equations using Cramer's rule??? I don't see Cranmer's rule mentioned much in Numerical Analysis books when they discuss the topic of solving linear equations.`I guess these authors maintain a reasonable bar for algorithms used to solve linear equations. Namir |
