12-15-2023, 04:46 AM
Post: #321
RE: newRPL - Updated to build 1510 [official build remains at 1487]
(11-21-2023 03:15 PM)Francois Lanciault Wrote: Hi Claudio, I don't know which benchmark it is but it's not possible to be slower on the Prime being the same code. My only guess is that perhaps your memory was dirty and a garbage collection was triggered during the test?? A GC cleaning up 32 MB of ram can take a while... if you post your benchmark I can run it on my 50g and Prime and we can compare results. |
12-15-2023, 05:00 AM
Post: #322
(11-27-2023 12:24 PM)Klaus Wrote: I had to reinstall the stock ROM on my HP50 after using the NewRPL ROM for a long time. After the installation, I discovered that the HOME directory with all user files, all the libraries I had installed, and all the special settings of the computer were there as originally --- as if by magic. How is that possible? I always thought that when the NewRPL operating system was installed on the HP50, all memory would be rewritten, meaning everything would be deleted. Can someone explain this to me -- would be very grateful! The 50g stores Port0 and your HOME directory in the higher portions of your Ram. The "lower" parts here means the bottom of the 512k. The first 128kb are used by the Kinpo OS and the Saturn emulator, the second 128k are used for Port1 if I remember correctly, and only then the user visible memory starts. First system variables and then TempOb, and above that the stack. All of that memory so fart can be lost without any consequence. Above the stack is your Home directory and above that Port0. NewRPL takes 4k pages and assigns it to different areas as needed, but starts taking memory from the bottom so if you used your calc lightly it is entirely possible that you never needed to use the higher portions of ram, and your data stayed there untouched. The TTRM prompt will aggressively try to recover your Home directory so don't be too surprised that it found it. |
12-18-2023, 02:36 PM
Post: #323
Visual Studio Code (VSC) is the source code editor that is increasingly used in computer programming education.
How complex would it be to create an newRPL plugin in Visual Studio Code? |
12-18-2023, 04:35 PM
Post: #324
(12-15-2023 04:46 AM)Claudio L. Wrote: I don't know which benchmark it is but it's not possible to be slower on the Prime being the same code. My only guess is that perhaps your memory was dirty and a garbage collection was triggered during the test?? A GC cleaning up 32 MB of ram can take a while... if you post your benchmark I can run it on my 50g and Prime and we can compare results. I ran the benchmark 12 times with different starting values (time of benchmark depends on starting value). All results were slower than HP-50G and it was a bit worst at every new iteration of the test (maybe a clue?) How is the best way to send you the actual program ? François |
12-27-2023, 03:19 AM
(This post was last modified: 12-27-2023 03:20 AM by Claudio L..)
Post: #325
(12-18-2023 04:35 PM)Francois Lanciault Wrote:(12-15-2023 04:46 AM)Claudio L. Wrote: I don't know which benchmark it is but it's not possible to be slower on the Prime being the same code. My only guess is that perhaps your memory was dirty and a garbage collection was triggered during the test?? A GC cleaning up 32 MB of ram can take a while... if you post your benchmark I can run it on my 50g and Prime and we can compare results. A PM through the forum is fine or an email at my first name at hpgcc3.org. |
05-17-2024, 11:14 AM
(This post was last modified: 05-17-2024 04:40 PM by ggauny@live.fr.)
Post: #326
I, right now, installed NEWRPL on desktop.
Seem good ,but is exist a owner manual and an referance manuel ? Thanks. EDIT : I've found ! Thanks. Gérard. |
05-30-2024, 11:08 AM
Post: #327
I've been trying to get newRPL Desktop to run on my Win11 machine for a long time (Build 1487). The status always shows "Device is not responding". This version ran without any problems on Win10. Greetings Klaus |
07-18-2024, 10:24 PM
Post: #328
(05-30-2024 11:08 AM)Klaus Wrote: Hello, That's unfortunate, it may need to be recompiled from source for Windows 11 (and linked against the newer SDK libraries). I do not have any Windows 11 machines to do that build unfortunately, I moved all my work to Linux, only have one old Windows 10 VM. |
07-19-2024, 06:34 AM
(This post was last modified: 07-19-2024 06:39 AM by Massimo Gnerucci.)
Post: #329
(07-18-2024 10:24 PM)Claudio L. Wrote:(05-30-2024 11:08 AM)Klaus Wrote: Hello, Just tried to install it on a Win 11 Pro (10.0.22631) computer and couldn't find issues with it... Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
07-19-2024, 11:08 AM
Post: #330
(07-19-2024 06:34 AM)Massimo Gnerucci Wrote:(07-18-2024 10:24 PM)Claudio L. Wrote: That's unfortunate, it may need to be recompiled from source for Windows 11 (and linked against the newer SDK libraries). I do not have any Windows 11 machines to do that build unfortunately, I moved all my work to Linux, only have one old Windows 10 VM. Hello Massimo, I see you are working with a Prime machine. I have a 50g. Maybe that is the cause? Greetings! |
07-19-2024, 11:21 AM
Post: #331
(07-19-2024 11:08 AM)Klaus Wrote:(07-19-2024 06:34 AM)Massimo Gnerucci Wrote: Just tried to install it on a Win 11 Pro (10.0.22631) computer and couldn't find issues with it... Hi Klaus, I just showed the two calculators side by side, on the same computer. Is installing newRPL on Win11 what we are talking about, or installing it on a calculator? I had no problems installing the build you mention on a Win11 Pro computer. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
07-20-2024, 09:42 PM
Post: #332
(07-19-2024 11:21 AM)Massimo Gnerucci Wrote:(07-19-2024 11:08 AM)Klaus Wrote: Hello Massimo, If I understood correctly, he means connecting a real calculator to newRPL Desktop via USB is not recognizing the device. Can you try that with your Win 11 install? |
07-21-2024, 08:05 AM
(This post was last modified: 07-21-2024 08:31 AM by Massimo Gnerucci.)
Post: #333
(07-20-2024 09:42 PM)Claudio L. Wrote:(07-19-2024 11:21 AM)Massimo Gnerucci Wrote: Hi Klaus, Sorry then, completely missed the meaning. I tried to connect my converted 39gs and this showed up on the display: Code: .......................... After selecting Cont, on PC in Dialog: Code:
Finally on the calculator: Code: USBAUTORCV Error: So yes, it seems a problem lies somewhere. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
07-21-2024, 10:16 AM
Post: #334
(07-21-2024 08:05 AM)Massimo Gnerucci Wrote:(07-20-2024 09:42 PM)Claudio L. Wrote: If I understood correctly, he means connecting a real calculator to newRPL Desktop via USB is not recognizing the device. Can you try that with your Win 11 install? This appears when the newRPL desktop wants to establish a connection... |
07-21-2024, 11:57 AM
Post: #335
Yes. That's what I see when connecting the calculator (apart from 39gs vs 50g in the Device Name column)
08-01-2024, 03:09 PM
Post: #336
hello
I think New-RPL should be present in the hp-prime firmware, as APP, especially in the version for mobile devices, I would buy it without hesitation. you have to negotiate with HP |
User(s) browsing this thread: 32 Guest(s)
