TVM solve for interest rate, revisited
06-14-2024, 09:59 PM
Post: #41
RE: TVM solve for interest rate, revisited
(05-13-2022 10:34 PM)Albert Chan Wrote: lua> n,pv,pmt,fv = 10,50,-30,100 Lets try sign test, to see which way possible roots are located. (06-14-2024 03:29 PM)Albert Chan Wrote: sgn(-(pv+fv)/n) = sgn(pv*(i - pmt/-pv)) = sgn(-fv*(i - pmt/fv)) -(pv+fv)/n = -(50+100)/10 = -15 sgn(i - pmt/-pv) = sgn(-15/50) = -1 → i < pmt/-pv = 0.6 sgn(i - pmt/fv) = sgn(-15/-100) = 1 → i > pmt/fv = -0.3 True rates are 0.582038 and -0.284436 ... all checked out. Lets try split loan "y" method (06-13-2024 01:05 PM)Albert Chan Wrote: (pv+y) * (fv-y) < 0 (y+pv) * (y-fv) > 0 (y+50) * (y-100) > 0 pmt = -30, i = pmt/y: (y<-50) → i < -30/-50 = 0.6 (y>100) → i > -30/100 = -0.3 -- same edges and direction, without memorized formula! ![]() |
06-15-2024, 03:05 AM
(This post was last modified: 06-26-2024 01:49 PM by Albert Chan.)
Post: #42
Assume n>1, (x → ∞), we wanted to show (x - f/f') → -pmt/pv
Let K = (1+x)^n, g = x / (K-1) (x → ∞) ⇒ (K → ∞) ⇒ (g → 0) f = (pv+fv)*g + pv*x + pmt f' = (pv+fv)*g' + pv (x → ∞) ⇒ (f → pv*x + pmt) ⇒ (f' → pv) x - f/f' → x - (pv*x + pmt)/pv = -pmt/pv Assume n>1, (x → -1), we wanted to show (x - f/f') → pmt/fv (x → -1) ⇒ (K → 0) ⇒ (g → 1) ln(g) = ln(x) - ln(K-1) g'/g = 1/x - n*K/(1+x)/(K-1) = 1/x - n/((1+x)*(1-1/K)) (x → -1) ⇒ (g'/g → 1/-1 - n/∞ = -1) ⇒ (g' → -1) f = (pv+fv)*(1) + pv*(-1) + pmt = fv + pmt f' = (pv+fv)*(-1) + pv = -fv (x → -1) ⇒ (f → -fv*x + pmt) ⇒ (f' → -fv) x - f/f' → x - (-fv*x + pmt)/(-fv) = pmt/fv This allow for getting not just edge rate, but direction where it is going! i > pmt/fv, because previous guess was -1 i < pmt/-pv, because previous guess was ∞ If we get smaller edge by picking bigger sized denominator, pmt=0 also work. lua> tvm(10, nil, -10, 0, 20, true) 0 1 0.06896551724137931 0.03766397216483768 0.07176928097229544 5.600549027886197e-05 0.07177346252703834 1.2395358963512803e-10 0.07177346253629316 0 0.07177346253629316 Above example, we pick fv, because its size is bigger --> i > 0/20 = 0 Here is a nice mnemonic: < pv pmt fv >, same order as most financial calculator. Of course, this is assuming root in that direction exist. We might not have 2 solutions, even with 2 good edges. Direction info can only show where is possible, or not. Update: 6/18/24 I made HP71B Secants Method Rate Solver using asymptotic slopes. |
06-15-2024, 12:19 PM
Post: #43
(06-10-2024 03:27 PM)Albert Chan Wrote: Lets make bottom branch more accurate, with log1p_sub / expm1_sub I figured out why Newton on f does not work well with tiny rate! Say, with non-zero a, we want to solve f(x) = g(x) - a Newton's method: x ← x - f(x)/f'(x) = x - (g(x)-a) / g'(x) With iteration zeroed-in to true root, g(x) ≈ a f(x) will get less and less accurate, due to cancellation errors. It does not matter if g(x) is super-accurate, even if correctly rounded! Cancellation errors may happen for slope too, if a is also a function of x This is normally not an issue. If f(x) only get half-precision, iterated x holds the other half. With final f turns into garbage, more Newton's iteration may make it worse. lua> x = 1 lua> for i=1,6 do f=x*x-2; print(x,f); x=x-f/(2*x) end 1 -1 1.5 0.25 1.4166666666666667 0.006944444444444642 1.4142156862745099 6.007304882871267e-06 1.4142135623746899 4.510614104447086e-12 1.4142135623730951 4.440892098500626e-16 But, that does not hold if X is very close to zero. Iterated x unable to keep its share. This is the reason tiny rate top branch is needed, to keep cancellation errors at bay. The other way is to throw in more-precision to the problem, but that is expensive. |
06-15-2024, 03:29 PM
Post: #44
I recently translated find_rate() for HP71B (with test samples)
But, instead of copy/paste the code, I redo the math. HP71B code seems simpler, with just as good accuracy. I am updating old with new, in iter_i(), post #31 Code: OLD NEW Just to check math again, for df/di s = (1+i)^n - 1 k = (pv+fv)/s // note: (k*s) = (pv+fv) = constant ln(i/s)' = ln(i)' - ln(s)' (i/s)' / (i/s) = 1/i - n*(s+1)/(1+i)/s s * (i/s)' = 1 - n*(s+1)/(s+s/i) f = (k + pv)*i + pmt = (k*s)*(i/s) + pv*i + pmt f' = (k*s)*(i/s)' + pv = k*(1-n*(s+1)/(s+s/i)) + pv |
06-16-2024, 04:20 PM
(This post was last modified: 06-21-2024 03:04 AM by Albert Chan.)
Post: #45
Looking up old notes, there was a reason iter_i() was written that way.
Variables (num,den) were shared to build iter_i2(), Halley's method. Code: -- Halley's method iter_i2() But, if Newton's method required sharp f, Halley's even more so. I removed iter_i2(), and only solve rate with Newton's from now on. (01-03-2024 08:10 PM)dm319 Wrote: And in part VI Plus42 is the only one that finds the negative root first. Is that because it is only going left? Plus42 start guess from small sized edge, not left or right. There is a reason for this. Think of mortgage with tiny ± final balance. Tiny balance should have little effect to rate. We don't want the other weird rate. It is the same when using quadratic formula. We keep the one that make sense. Update: I just think of another good reason. Small sized guess at worst goes down to 0; Big sized guess can get *very* big. We may hit with overflows errors, instead of inconsequential underflow. But, it is trivial to get either edges. Perhaps Plus42 should add this option? Code: function edge_i(n,i,pv,pmt,fv) -- big edge if i is false lua> tvm(10,false,50,-30,100, true) -- big sized edge = -30/-50 0.6 0.8260581870403279 0.5821069833315318 0.0031464275173469503 0.5820382979602389 4.932464037210593e-08 0.5820382968834661 -3.552713678800501e-15 0.5820382968834661 Updates to post #31 |
06-17-2024, 02:33 PM
(This post was last modified: 06-24-2024 02:38 PM by Albert Chan.)
Post: #46
Previously (post #31), iter_i() returned i, f, eps = -f/fp
With verbose option, eps is not shown, because it can be deduced from i changes. It may give better picture if eps is replaced by fp, and shown in verbose output. With {i, f, fp}, we can mentally picture how the curve behave. (flatline? no solution?) Another issue is find_rate() returned false for no solution case. Boolean cannot be used for arithmetic calculations. nan is better. Fudge factor to test converged i doubled. (i==i+eps/1000) --> (i==i+eps/2000) Update: iter_i() produce correct i, f, fp even if s = EFF(i,n) not finite. find_rate(): no Newton step if f=0. (it may not be equivalent, if f'=0 too) Here is the updated version. Code: function EFF(i,n,div) i=div and i/n or i; return expm1(log1p(i)*n) end Example, slight changes to pmt, we have 0 solution (returned nan), changed to 2 lua> tvm(10,nil,1000,-287,2000,true) Code: -0.1435 116.13771101577868 -1087.5631610761484 lua> tvm(10,nil,1000,-288,2000) 0.05503638712931415 lua> tvm(10,false,1000,-288,2000) 0.09744316384349011 Above is not typical. fp normally does not change that much, especially at the end. lua> n,i,pv,pmt,fv = 48,nil,19198,-450,0 -- test sample #12 lua> tvm(n,i,pv,pmt,fv,true) Code: 0.023439941660589644 220.49758413166887 13196.166742730682 |
06-18-2024, 01:11 AM
Post: #47
Let S=(1+I)^N-1, D = N*I/S, C = subst(D,N=-N) --> C/D=(S+1), C-D=N*I
If solved rate is close to zero, this may be a better formula: NPMT = C*PV + D*FV + N*PMT NPMT = (C-1)*PV + (D-1)*FV + (PV+FV+N*PMT) if I=0 --> (C-1) = (D-1) = 0, we are left with last term, F0 = (PV+FV+N*PMT) In other words, if F0=0, then rate is 0. If solved rate is tiny, so does F0 too. Formula is usable as is, but let's adjust it to match our iter_i(): NPMT = (D-1)*(PV+FV) + PV*N*I + F0 (D-1) = N*I/S - 1 = (N*I-S) / S We get this iter_i(). Note: f = NPMT, not npmt, but trivial to scale (f, fp) by n, if needed. Code: function iter_i(n,i,pv,pmt,fv) -- f = NPMT (06-10-2024 01:33 AM)Albert Chan Wrote: Problem 4: lua> find_rate(480,nil,1e5,-1e5/480, 0, true) Code: 0.0020833333333333333 58293.549096938164 31781021.329671178 Of course, it work with normal cases too. Say, previous post examples. lua> tvm(10,nil,1000,-287,2000) nan lua> tvm(10,nil,1000,-288,2000) 0.05503638712931402 lua> tvm(10,false,1000,-288,2000) 0.0974431638434901 But, I like simple formula, f = (k + pv)*i + pmt ... I am keeping old code. |
06-18-2024, 11:11 AM
Post: #48
(06-15-2024 03:29 PM)Albert Chan Wrote: I recently translated find_rate() for HP71B (with test samples) Replaced with NPMT = (D-1)*(PV+FV) + PV*N*I + F0 --> FNF = NPMT/n, we have: 10 INPUT "B,N,P,M,F? ";B,N,P,M,F @ F0=(P+F+N*M)/N 12 IF B THEN P=P+M @ F=F-M ! end mode 14 IF ABS(P)>ABS(F) THEN X=F @ F=-P @ P=-X @ N=-N ! time reversed 20 DEF FNZ(I,A,B,C) @ D=(A+B)/2 @ B=A*C @ FNZ=F0+(D+B)*I @ D=D+2*B @ END DEF 30 DEF FNF(I) @ IF 1+N*I*I=1 THEN FNF=FNZ(I,(P+F)/N,P-F,(N*N-1)/12*I) @ END 40 S=EXPM1(LOGP1(I)*N) @ K=(P+F)/S @ D=K*(1-N*(S+1)/(S+S/I))+P 50 FNF=K*(I-S/N)+P*I+F0 @ END DEF 60 I=M/F @ Y=FNF(I) ! "smallest" edge guess 70 DISP 100*I,Y @ H=-Y/D @ I=I+H @ Y0=Y @ Y=FNF(I) 80 IF SGN(Y0)=SGN(Y) AND ABS(Y0)>ABS(Y) THEN 70 90 DISP 100*I,Y @ J=I-Y/D/2 @ DISP 100*J ! half-correction Running test samples shown similar result, except for Problem 5 Code: B,N,P,M,F? 0,365*24*60,0,-0.01,5260.382426 It is interesting we have a one solution case, but FNF have no sign changes. Final FNF value get worse, on the same side of root! I expect this behavior from a 2 solutions to 0 solution borderline case, but not here! The problem here is F0 is tiny (if true rate is 0, so does F0), much smaller than M Without needed cancellation, FNF is less stable. Sometimes, cancellation is good! If we do an extra iteration, indeed we have sign changes, i.e. guaranteed solution. >FNF(J) -1.546E-14 >(J-RES/D/2) * 100 ! half-correction 3.17097920515E-7 |
06-21-2024, 12:44 PM
(This post was last modified: 06-25-2024 06:40 PM by Albert Chan.)
Post: #49
Code: function npmt(n,i,pv,pmt,fv) return ((pv+fv)/EFF(i,n)+pv)*i + pmt end Due to decay shape d = i/EFF(i,n), if we have 2 edges, I think zero slope (if exist) is on the left of edges center. If my gut is correct, we may use center of 2 edges to reach big root. (*) Proof welcome! Disproof with counter example also nice. Center guess may overshoot to the right, but with non-zero slope, should not go crazy big. If overshooted, we would at worst wasted 2 iteration. (next of next back to edge) If not, we saved all iterations, from big edge to center of 2 edges. If there is only 1 valid edge, it is improved with I ≈ 1/P - P/N^2 formula, where 1/P = edge. Improved guess may not be in correct region for 1-sided convergence, but Newton would fix it. Both cases, first Newton iteration will not be used to test termination. 10 INPUT "B,N,P,M,F? ";B,N,P,M,F 15 IF B THEN P=P+M @ F=F-M ! end mode 20 DEF FNZ(I,A,C) @ C=A*C @ D=(P-F+A)/2+C @ FNZ=A+M+D*I @ D=D+C @ END DEF 30 DEF FNF(I) @ IF 1+N*I*I=1 THEN FNF=FNZ(I,(P+F)/N,(N*N-1)/12*I) @ END 40 S=EXPM1(LOGP1(I)*N) 50 D=(P+F)/S*(1-N*(S+1)/(S+S/I))+P @ FNF=((P+F)/S+P)*I+M @ END DEF 51 I=-1 @ IF F THEN I=M/F 52 J=-1 @ IF P THEN J=M/-P 54 IF I<=-1 THEN I=J-1/(J*N*N) @ GOTO 60 55 IF J<=-1 THEN I=I-1/(I*N*N) @ GOTO 60 57 I=(I+J)/2 ! 2 good edges 60 DISP 100*I,FNF(I) @ I=I-RES/D @ Y=FNF(I) 70 DISP 100*I,Y @ H=-Y/D @ I=I+H @ Y0=Y @ Y=FNF(I) 80 IF SGN(Y0)=SGN(Y) AND ABS(Y0)>ABS(Y) THEN 70 90 DISP 100*I,Y @ IF Y THEN I=I-Y/D/2 @ DISP 100*I Line 90 only correct i when FNF(i)≠0. This is not an optimization. I want D=0 to give divide-by-0 warning, but not when FNF(i)=0 already. >run B,N,P,M,F? 0,10,50,-30,80 Code: 11.25 -16.6938992149 Center guess is on the inside, Newton pushed it out. 2 iterations less with big edge guess, but won't know until tried it. Here is a case center guess help, by a lot. (no overshoot this time) >run B,N,P,M,F? 0,10,50,-12.8277219567,80 Code: 4.81039573375 .0048896134 Same problem, but with big edge guess. >i=m/-p @ run60 Code: 25.6554439134 3.7843086116 Example with only 1 valid edge. >run ! 5 B,N,P,M,F? 0,365*24*60,0,-0.01,5260.382426 Code: 3.17141393E-7 -1.14278E-9 Same problem, but with edge guess. >i=m/f @ run 60 Code: -1.90100247286E-4 .005827435363 (*) I was picturing f(x) = npmt(n,x,pv,pmt,fv) in my head With 2 valid edges, we can make g(x) = f(edge1 + edge2 - x) 2 curves would not overlap, because of decay factor. 1 curve will have zero slope (if exist) on the left, the other on the right. Center guess (where 2 curve intersect) would not hit with zero slope. plot {(130/((1+x)^10-1)+50)*x-30, (130/((1+(.6-.375-x))^10-1)+50)*(.6-.375-x)-30}, x = -.375 .. 0.6 |
06-21-2024, 03:11 PM
(This post was last modified: 06-21-2024 08:42 PM by Albert Chan.)
Post: #50
Last example, if we set P=0.01, big edge = 100%, center about 50%
Both guesses will cause S=EXPM1(LOGP1(I)*N) to overflow. This does not mean algorithm is wrong ... we just need a better FNF, for big rate. FNF=((P+F)/S+P)*I+M --> S=inf --> FNF=P*I+M < 40 S=EXPM1(LOGP1(I)*N) > 40 S=EXPM1(LOGP1(I)*N) @ IF S>9E499 THEN D=P @ FNF=D*I+M @ END >run B,N,P,M,F? 0,365*24*60,0.01,-0.01,5260.382426 Code: 49.9999049499 WRN L40:Overflow How do I remove WRN L40:Overflow? Is there exception handling (like Python), for HP71B? 100% rate? Yes! Every period, 1 penny loan doubled to 2, paid back 1 With exact 100% rate, we still owe 1 penny at the end (fv = -0.01) But we have credit balance instead --> rate i = 1 - ε, ε>0 Split loan Code: PV PMT FV #1: x=0 --> i = 1 #2: i=1 --> x = 5260.392426/(2^525600-1) ≈ 2^-525587.64 i = 0.01/(0.01+x) = 1/(1+100x) ≈ 1 - 100x ≈ 1 - 2^-525581 |
06-22-2024, 11:46 AM
Post: #51
(06-15-2024 03:29 PM)Albert Chan Wrote: I am updating old with new, in iter_i(), post #31 OLD: s=i/EFF(i,n); k=(pv+fv)*s; fp = -k*((n*s-1)+(n-1)*i)/(i+i*i) + pv; f = k + pv*i + pmt NEW: s=EFF(i,n) ; k=(pv+fv)/s; fp = k*(1-n*(s+1)/(s+s/i)) + pv; f = (k+pv)*i + pmt I tested both versions with car lease example, n,pv,pmt,fv = 36,30000,-550,-15000 Using Plus42 reference, solved i = 0.00580507281942013213837742298371094 With default setup (i=nil), old way error = 1 ULP, new = -2 ULP Note: error = exact - approx --> positive ULP means under-estimated. This is 1 example, 1 guess, and little differences. We can't tell which is better. I then compare example against million random guesses = random() - 0.5 (same sets) Also, tested whether Newton final correction make sense (default was half-correction) Newton none half full ULP old new old new old new -9 0 0 0 0 0 0 -8 0 0 0 0 0 0 -7 0 0 0 0 0 0 -6 0 0 0 0 0 0 -5 25645 31924 25645 31924 25645 31924 -4 56093 55614 56093 55614 165769 55614 -3 87030 86220 87030 86220 166564 168111 -2 119581 111874 119581 111874 164470 164696 -1 146559 142173 256235 142173 169406 169815 0 159774 155031 238969 235542 168496 166121 1 136685 132674 181565 185453 139650 136125 2 109676 107594 23186 136616 0 107594 3 79195 80511 8731 11133 0 0 4 44880 52779 2965 3451 0 0 5 22847 27642 0 0 0 0 6 8722 11090 0 0 0 0 7 2965 3451 0 0 0 0 8 339 1380 0 0 0 0 9 9 43 0 0 0 0 Final Newton correction produce better rate, with error within ±5 ULP Half correction produce better looking bell-shaped curve, centerd at 0 ULP Full correction looks good too, but distribution flattened, skewed to one side. Same problem can be solved in time-reversed way: Newton none half full ULP old new old new old new -9 0 0 0 0 0 0 -8 0 0 0 0 0 0 -7 0 0 0 0 0 0 -6 0 0 0 0 23745 27474 -5 899 0 0 0 0 0 -4 54374 60232 54374 60232 54374 60232 -3 87113 89638 87113 89638 164745 165200 -2 117888 112837 118787 112837 166925 168921 -1 144228 139168 167973 166642 144228 139168 0 157697 159256 235329 234442 166737 168343 1 164800 162206 213815 218283 167998 164772 2 110643 105890 110643 106266 111248 105890 3 77632 75186 9062 9094 0 0 4 49015 56077 2299 2566 0 0 5 23745 27474 605 0 0 0 6 9040 9087 0 0 0 0 7 2299 2566 0 0 0 0 8 605 376 0 0 0 0 9 22 7 0 0 0 0 No correction, time-reversed setup looks just as bad. Half-correction, time-reversed or not, looks about the same. Full correction still skewed, but now with a weird overshoot (error = -6 ULP). Old and new way seems to be similarly accurate. Time-reversed to limit size of pv, and final half-correction seems best == tvm() default ![]() |
06-24-2024, 12:46 PM
(This post was last modified: 06-24-2024 03:31 PM by Albert Chan.)
Post: #52
(06-21-2024 03:11 PM)Albert Chan Wrote: Last example, if we set P=0.01, big edge = 100%, center about 50% Fixed iter_i() code to handle big rate overflow issue. If s overflowed, it use asymptote line: f = pv*i + pmt lua> n, pv, pmt, fv = 365*24*60, 0.01, -0.01, 5260.382426 lua> tvm(n,0.5,pv,pmt,fv, true) -- guess about edges center 0.5 -0.005 0.01 1 0 0.01 1 lua> tvm(n,false,pv,pmt,fv, true) -- big edge, beyond OK too 1 0 0.01 1 Update: guess can now be -100%, or less! Implementation is cheap, if i ≤ -1, then f = -fv*i + pmt This made guess formulas safer to use, as long as overshoot is still finite. Of course, edge rates are safest, with guaranteed no overshoot. Updates in post #46 |
06-24-2024, 08:51 PM
(This post was last modified: 06-27-2024 10:04 AM by Albert Chan.)
Post: #53
Issues with previous update.
1. if iterated rate is huge, Newton step might not get back edge rate. What if i = ±inf ? No amount of correction will make it back to finite! It is more accurate and direct to set next iteration as edge instead. 2. We want code to work with any bad guess, even if rate overshooted to ±inf 3. Returning f, fp based on asymptote line might not make sense (i<-1, f and fp do not exist!) Instead, we just use f,fp formula, whatever its results stay. Turns out, for bad rate, fp = nan, which is a good signal to use! Code: local s = EFF(i,n) If s=inf, then (s+1)/(s+s/i) = inf/inf = nan If i=-1, then s=-1 or inf, both cases we have fp = nan If i<-1, then s=nan, so does fp If i is 1 ULP above -1, (s+s/i) ≠ 0 --> i ≤ -1 ⇒ fp = nan 4. For min points to use = c+1 (c calls to get f0, and we least at least 1 f's) a) if guess from edge, first call is good for f0 --> c=1 b) supplied guess itself caused fp = nan. Next iteration would get back edge --> c=2 c) supplied guess next iteration caused fp = nan. Next would get back edge --> c=3 This is what I come up with: (c = number of calls to get good f0) Code: local c, f0 = i0 and 2 or 1 -- just in case bad i0 Here is the new update, which should work with *any* rate guess! Code: function EFF(i,n,div) i=div and i/n or i; return expm1(log1p(i)*n) end (06-13-2024 09:28 PM)Albert Chan Wrote: lua> n = 365*24*60 -- = 525600 lua> tvm(n,1e-3,0,-1,fv, true) Code: 0.001 -1 -1.946648633485123e-220 lua> tvm(n,0,0,-1,fv, true) Code: 0 0.0008337949011274493 -263018.6208831188 lua> i = guess_i(n,i,0,-1,fv) lua> tvm(n,i,0,-1,fv, true) Code: 3.170979198350206e-09 6.661338147750939e-15 -262872.49916295544 Update: It may be hard to get accurate f(i), due to cancellation errors. If above examples had no sign changes, code would consider them no solution case. With no sign changes, we considered rate found if they have 9 digits convergence. (was 12) |
06-26-2024, 02:31 PM
(This post was last modified: 06-27-2024 10:22 AM by Albert Chan.)
Post: #54
Found a nice rate formula! https://brownmath.com/bsci/loan.htm#LoanInterest
Any clue how q-to-rate method is derived? Why log2? fv = 0 i0 = pmt/-pv q = log2(1+1/n) → i ≈ ((1+i0)^(1/q)-1)^q-1 Or, let Q = 1/q ≈ n*log(2) → (1+i)^Q ≈ (1+i0)^Q - 1 Example from previous post lua> n, pv, pmt, fv = 525600, 0, -1, 526038.2426000326 lua> 1/(600*n) -- true rate 3.1709791983764586e-09 lua> n, pv, fv = -n, -fv, -pv -- time reversal to match formula lua> i0 = pmt/-pv lua> q = log2(1+1/n) lua> EFF(APR(i0,q)-1, q) 3.1710141058643196e-09 lua> i0 - 1/(i0*n^2) -- compare to I ≈ 1/P - P/N^2 3.1714139412113494e-09 |
06-27-2024, 09:21 PM
(This post was last modified: 06-29-2024 08:12 PM by Albert Chan.)
Post: #55
(06-26-2024 02:31 PM)Albert Chan Wrote: Found a nice rate formula! https://brownmath.com/bsci/loan.htm#LoanInterest I finally figured this out ![]() C*pv + n*pmt = 0 → C = n*(pmt/-pv) = n*i0 > 0 Let s = (1+i0)^(1/q), then i ≈ (s-1)^q-1, very tiny if n is huge --> s ≈ 2 s = ((1+i0)^(1/i0))^(i0/q) < e^(i0/q) = e^(C/(n*q)) e^ln(2) = 2, we have C/(n*q) > ln(2) → (n*q) < C / ln(2) s assumed i0>0. For negative i0, it is (n*q) > C / ln(2) The rest is likely by experimentation, with typical user input. https://brownmath.com/bsci/loan.htm#Sample2 lua> n, i, pv, pmt, fv = 360, 0.0065, 225e3, -1619.71, 0 lua> i0 = pmt/-pv lua> i0 0.007198711111111112 lua> q = log1p(1/n) / log(2) -- slightly better than q = 1/n / log(2) lua> EFF(APR(i0,q)-1,q) 0.006464576864221504 lua> q = 1/(n+0.5) / log(2) -- log1p(1/n) = 2*atanh(1/(2n+1)) ≈ 1/(n+0.5) lua> EFF(APR(i0,q)-1,q) 0.006464578259952884 lua> C = n*i0 lua> i0 - 1/C / n -- compare to I ≈ 1/P - P/N^2 0.006126845708593925 Too much correction, lets try the real thing. -1/C factor was from W function. We pick W branch so W(y) ≈ -1/C, not -C. If C<1, we want more negative W-1 Since C<1 only occurs with negative n, unless we applied time-reversal, it is W0 lua> y = -C*exp(-C) lua> i0 + W(y, C<1 and -1 or 0) / n 0.0065070286651448175 |
06-29-2024, 06:21 PM
(This post was last modified: 06-30-2024 12:19 AM by Albert Chan.)
Post: #56
(06-26-2024 02:31 PM)Albert Chan Wrote: let Q = 1/q ≈ n*log(2) → (1+i)^Q ≈ (1+i0)^Q - 1 Previous post showed why ln(2) is there, because RHS is (s-1) If RHS is (s-2), then ln(3) pops out ... prove is not complete. Let's try again, assuming n is huge. (i is interest rate, not √(-1)) C = i*n / (1-(1+i)^-n) ≈ i*n / (1-e^(-i*n)) = 1 + (n*i)/2 + (n*i)²/12 - ... s = (1+i0)^Q = (1+C/n)^Q ≈ (1 + 1/n + i/2 + n/12*i² - ...)^Q (1+1/n)^Q ≈ ((1+1/n)^n) ^ ln(2) ≈ e ^ ln(2) = 2 We can pull out tiny 1/n term, as correction instead (note: n ≈ Q/ln(2)) RHS = s-1 ≈ 2 * (1 + i/2 + n/12*i² - ...)^Q - 1 ≈ 1 + Q*i + 0.490*(Q*i)² - ... LHS = (1+i)^Q = 1 + Q*i + Q*(Q-1)/2*i² + ... ≈ 1 + Q*i + 0.500*(Q*i)² + ... QED With Q=n*ln(2), RHS is still smaller. This explained Q = (n+0.5)*ln(2) is better. |
06-29-2024, 08:52 PM
(This post was last modified: 06-30-2024 02:57 PM by Albert Chan.)
Post: #57
With Q-method proven, I was able to improve its accuracy.
\((1+i)^Q \,≈\, (1+i_0)^Q - 1\) \(\displaystyle i \,=\, i_0 - \frac{i_0}{(1+i)^n} \,≈\, i_0 - \frac{i_0}{((1+i_0)^Q-1)^\frac{n}{Q}} \) This is suitable for C = n*i0 > 1, because denominator has size around C^2 (06-27-2024 09:21 PM)Albert Chan Wrote: lua> n, i, pv, pmt, fv = 360, 0.0065, 225e3, -1619.71, 0 lua> i0 - i0/APR(i0,q)^(n*q) 0.006491096452188186 lua> Q = (n+.5)*log(2) -- my preference is big Q lua> i0 - i0/EFF(i0,Q)^(n/Q) 0.006491096805454773 |
