The Stack in ALG Mode
06-17-2024, 04:37 AM (This post was last modified: 06-17-2024 04:40 AM by Powa.)
According to Appendix B, the stack in ALG mode holds the last 4 results. That's fine. It also says:
"Note that once a two-numbered function (such as +, -, x, / or y^x) has has the second argument entered, the two arguments cannot then be swapped using x><y because when the second argument is entered it replaces the first,..."
Where is the first argument stored then?
In RPN mode the y^x makes sense, you key in a value which goes into x register and when you key in the second value, it goes into the y register with the new value being in the x register. So the key makes logical sense in RPN mode. But I don't know what logic to use for ALG mode.
06-17-2024, 12:25 PM
RE: The Stack in ALG Mode
Please clarify what model machine this question is about...
06-17-2024, 02:00 PM (This post was last modified: 06-17-2024 02:01 PM by Powa.)
The calculator in question is the HP12C.
