HP 12C Fibonacci Sequence
08-16-2017, 05:16 AM
Here is the HP 12C program to find Fibonacci Sequence accurate up to 40
Anyone have a better solution?
Gamo
Attached File(s)
.pdf  FiboSequence.pdf (Size: 92.25 KB / Downloads: 73)
08-16-2017, 09:06 AM
RE: HP 12C Fibonacci Sequence
(08-16-2017 05:16 AM)Gamo Wrote:  Here is the HP 12C program to find Fibonacci Sequence accurate up to 40
Gamo
Hi, for interest see posts #2 & #3 in this thread in the Software Library:
http://www.hpmuseum.org/forum/thread-835...i#pid73315
Best regards
08-16-2017, 04:38 PM (This post was last modified: 08-16-2017 05:28 PM by Dieter.)
Your program implements an interesting formula that calculates the Fibonacci numbers directly instead of the usual approach with adding the two previous ones. I did not know this before, but it seems to be the Moivre-Binet formula:
\[F_n = \frac{1}{\sqrt{5}} \left [ \left ( \frac{1+\sqrt{5}}{2} \right )^n - \left ( \frac{1-\sqrt{5}}{2} \right )^n \right ] \]
A straightforward implementation does not require any registers and could be done like this:
01 ENTER
02 5
03 √x
04 1
05 +
06 2
07 /
ß8 1/x
09 x<>y
10 LstX
11 x<>y
12 y^x
13 x<>y
14 CHS
15 LstX
16 y^x
17 -
18 5
19 √x
20 /
21 INTG
22 GTO 00
(08-16-2017 05:16 AM)Gamo Wrote:  Anyone have a better solution?
Since for n≥0 the second term is always less than 1/2 it doesn't have to be calculated. Simply round \(\frac{1}{\sqrt{5}} \left (\frac{1+\sqrt{5}}{2} \right )^n\) to the nearest integer. That's what the following program does.
01 ENTER
02 5
03 √x
04 1
05 +
06 2
07 /
08 x<>y
09 y^x
10 5
11 √x
12 /
13 .
14 3
15 +
16 INTG
17 GTO 00
On the 10-digit 12C this also works correctly up to n=40. Above that the results are a bit larger than expected because the 10-digit value of \(\Phi\) is slightly high while \(\sqrt{5}\) in the denominator is slightly low. That's also why the rounding function in the above code does not add 0,5 but 0,3.
BTW, using code boxes like this instead of attaching a PDF (which is only available after login) may be the better solution.
Dieter
02-15-2023, 05:32 PM
I have come to a code to run the Fibonacci Sequence with just 13 steps!
No data need to inupted in memories or registers, just add the code and press R/S
Please, add a star to the repo if you like, that means a lot to me:
https://github.com/joaomariowd/hp-12c
08-08-2024, 07:40 PM (This post was last modified: 08-08-2024 08:05 PM by C.Ret.)
Dear friends,
Like you, my heart has fallen in love with these old machines.
But my mind remains lucid.
Why so much hassle and lines of code?
Doesn't your HP-12C have, like mine I hope, a dedicated key for calculating the elements of the Fibonacci sequence? This key is marked [FV] as Fibonacci's Value.
So you just have to properly initialize your HP-12C and it can instantly calculate any value of the Fibonacci sequence with two or three keystrokes!
For example, to obtain the value of \(F_{36}\), put the display in mode in (f)[ 0 ] to display only integers.
Enter 36, press [ n ] then [ FV ] and the value of \(F_{36}\) is displayed:
[Image: attachment.php?aid=13801]
Your HP-12C can do even better and for a given element of the sequence tell you at what index it appears or at least the index of the immediate preceding element.
For example,
75025 [ FV ] [ n ] will instantly tell you that it is the 25th element!
To do this, properly initialize your HP-12C:
(f) [CLEAR FIN ]
[ 5 ] (g)[ √x ] [CHS] [1/x] [ PV ]
initializes the constant factor of the Binet Formula in the Present value register PV.
[ 5 ] (g)[ √x ] [ 1 ] [ - ] [ 5 ][ 0 ][ × ][ i ] initializes the under-exponential part of the same formula in the Interest register i%.
And there is your friendly HP-12C ready to solve all your Fibonaccial worries in the same way that it allows you to solve the financial ones.
The simplified Binet Formulae is quite a build-in expression in our beloved HP-12C:
Just observe and compare the obvious: \( FV = -PV \cdot (1 + i )^n \) versus \( F_n = \frac{1}{\sqrt{5}} \left( \frac{1+\sqrt{5}}{2} \right)^n \)
Best Regards.
08-12-2024, 11:59 AM
(08-08-2024 07:40 PM)C.Ret Wrote:  To do this, properly initialize your HP-12C:
(f) [CLEAR FIN ]
Gives wrong results as of n=40
For a few more correct results, define the constants more accurately as
.2 (g) [√x] [CHS] [PV] and
200 [ENTER] 5 [√x] 1 [+] [/] [i]
Now the first wrong result is for n=44. Mh. Doesn't gain a lot..
Cheers, Werner
08-12-2024, 07:31 PM (This post was last modified: 08-12-2024 08:47 PM by C.Ret.)
(08-12-2024 11:59 AM)Werner Wrote:  For a few more correct results, define the constants more accurately as
.2 (g)[√x] [CHS] [ PV ] and
200 [ENTER] 5 [√x] 1 [ + ] [ ÷ ] [ i ]
Now the first wrong result is for n=44. Mh. Doesn't gain a lot...
Thank you for this pertinent remark.
I had not noticed that my way of doing the two calculations gave results so far from the two true values. I never think about it; it is annoying with the voyagers which only have ten digits. I am unforgivable, especially for the constant having to be raised by a power.
Now, even with all the digits correctly set, it is true that the improvement is a little disappointing and that we push back the limit of this method by only four ranks.
But, well, F_44 is already not bad.
Especially since the HP-12C can no longer give all the digits beyond F_49.
Thank you for your help.
P.S.: By re-reading my post, I just get an idea.
Since the last exact Fibonacci Value we may obtain on an HP Voyager is F_49 = 7'778'742'049.
Why not using the ability of the HP-12C to adjust the right parameters instead of trying to randomly entering accurate or inaccurate parameters manually?
The procedure may be:
_1_ Input best approximation of both parameters (using good advice to avoid unforgivable mistaken) as initial guests.
(f)[CLEAR][ FIN ]
If we test result for F_49:
49 [ n ][ FV ] display erroneous value 7'778'742'061.
_2_* Try to obtain the correct value:
49 [ n ]
7778742049 [ FV ]
Now try to alternatively optimize the two parameters PV and i% to achieve expected result.
Optimize PV by pressing the [ PV ] key. The new value for PV is displayed -0.447213595
Checking the accuracy of the new configuration:
49 [ n ] [ FV ] now display 7'778'742'047. Much better but still off by two units.
Optimize i% by reentering expected value of F_49 and pressing the [ i ] key.
49 [ n ]
7778742049 [ FV ]
[ i ] now display the new adjusted i parameter 61.80339888
49 [ n ] [ FV ] still display 7'778'742'047.
No good, just continue to adjust.
Reset system:
49 [ n ]
7778742049 [ FV ]
Optimize PV again by pressing the [ PV ] key. The same value for PV is displayed -0.447213595
But same unreachable bits may have been changed internally(*), since, if we check:
49 [ n ] [ FV ] now display correct value 7'778'742'049.
But this is not the last good news :
48 [ n ] [ FV ] display 4'807'526'976.
47 [ n ] [ FV ] display 2'971'215'073.
46 [ n ] [ FV ] display 1'836'311'903.
45 [ n ] [ FV ] display 1'134'903'170.
44 [ n ] [ FV ] display 701'408'733.
Good settings !
(*) holding the (f)[PREFIX] key may give you some clue here about this mystery.
08-12-2024, 07:58 PM
Here's another idea:
(08-06-2023 11:06 AM)Thomas Klemm Wrote:  Splitting the Index
But since the biggest value for \(n\) is only \(49\) we can use the following formulas to reduce the index:
\begin{aligned}
F_{2n-1}&={F_{n}}^{2}+{F_{n-1}}^{2}\\
F_{2n}&=(2F_{n-1}+F_{n})F_{n}\\
\end{aligned}
Now even in the worst case of \(F_{49}\) we can use rounding to calculate \(F_{24}\) and \(F_{25}\).
Examples
\begin{aligned}
F_{44}&=&(2F_{21}+F_{22})F_{22} &=& (2 \cdot 10,946 + 17,711) \cdot 17,711 &=& 701,408,733 \\
F_{49}&=&{F_{25}}^{2}+{F_{24}}^{2} &=& 75,025^2 + 46,386^2 &=& 7,778,742,049 \\
\end{aligned}
