PX41CX
09-03-2024, 12:25 AM
Post: #141
RE: PX41CX | |||
09-03-2024, 06:43 AM
Post: #142
RE: PX41CX
(09-03-2024 12:25 AM)agarza Wrote:(09-02-2024 06:13 PM)krischik Wrote: As promised I made a documentation on how to Receive and send memory dumps with macOS. Me too ! (congratulations: good job !) http://ti58c.phweb.me http://clones.phweb.me http://www.instagram.com/ti58c "No! Do or Do not. There is no try!" [Master Yoda] |
09-03-2024, 07:35 AM
Post: #143
RE: PX41CX Receive and Send Dumps
(09-03-2024 06:43 AM)Pierre Wrote:(09-03-2024 12:25 AM)agarza Wrote: Perfect, I will add a link to your documentation on the PX-41CX website.Me too ! (congratulations: good job !) Being Python the tool should work on Windows and Linux as well. It's just that I didn't try it. I updated the Documentation to make that more clear. Now I just need someone to actually try it out. https://uiq3.sf.net/rpn-45/ Developer RPN-45, FX-602P Simulator, FX-603P Simulator HP16C, HP35s, HP-Prime, FX-602P, FX-603P, PC-1403 |
09-03-2024, 10:01 AM
Post: #144
RE: PX41CX
(09-03-2024 07:35 AM)krischik Wrote: Now I just need someone to actually try it out. Just replace line 60 in Receive.py Quote:print (Line.decode ("Latin1"), end='')by Quote:print (Line_Array.decode ("Latin1"), end='') and everything works under Windows! My Windows command files : (1) px41cx_Receive_Dump.bat Quote:@echo off (2) px41cx_Send_Dump.bat Quote:@echo off to adapt according to your own context. http://ti58c.phweb.me http://clones.phweb.me http://www.instagram.com/ti58c "No! Do or Do not. There is no try!" [Master Yoda] |
09-03-2024, 03:38 PM
Post: #145
RE: PX41CX Firmware installation on macOS
As promised I have written a proper installation guide for macOS and Linux.
https://calculator-scripts.sourceforge.i.../firmware/ Linux, of course, is untested. https://uiq3.sf.net/rpn-45/ Developer RPN-45, FX-602P Simulator, FX-603P Simulator HP16C, HP35s, HP-Prime, FX-602P, FX-603P, PC-1403 |
09-04-2024, 07:39 PM
Post: #146
RE: PX41CX Firmware patch
I updated the firmware flash script to also patch the firmware first. Now you can download the newest version, apply a patch and flash a new firmware in one go. On macOS and Linux that is. https://calculator-scripts.sourceforge.i..._firmware/ Regards Martin https://uiq3.sf.net/rpn-45/ Developer RPN-45, FX-602P Simulator, FX-603P Simulator HP16C, HP35s, HP-Prime, FX-602P, FX-603P, PC-1403 |
09-06-2024, 04:08 PM
Post: #147
RE: PX41CX screenshots
Pierre (mostly) and me (a little) created a python script which will download screenshots without the need of copy paste. It can store multiple screen shots so there is no need to restart the program. Usage is fairly simple: Code:
Further details and download on my page: https://calculator-scripts.sourceforge.i...creenshot/ Martin https://uiq3.sf.net/rpn-45/ Developer RPN-45, FX-602P Simulator, FX-603P Simulator HP16C, HP35s, HP-Prime, FX-602P, FX-603P, PC-1403 |
09-12-2024, 08:25 AM
(This post was last modified: 09-12-2024 08:46 PM by ian5251.)
Post: #148
RE: PX41CX
Thanks Alex for a great kit. I bought myself the PX-15C a few months ago, and my daughter bought the PX-41CX for my recent birthday. I enjoyed the build process on both very much. I've managed to get my head around the python tools to a) upload new firmware and b) to modify the firmware with personalised settings - I've updated the "info" text and am using 0902 firmware. I have also worked out how to dump and load from and to the PX-41CX via the serial port (I'm using Windows 11 and CoolTerm as recommended). <EDIT> I believe my problems were PEBKAC - my own fault. I suspect I was habitually pressing the lower-right button expecting to hit R/S, but of course the ON button is there now. <insert facepalm> I have a program on the PX-41CX that behaves incorrectly. At a certain point in the program, the calculator turns itself off, but turning it back on and pressing R/S gets it going again and the program resumes. Depending on the answers to the early questions my programs ask, this behaviour can happen once or twice, but there after, the program runs fine. The program I wrote was to track the progress of T20 or 50-Over cricket matches. If you want to upload and run it (the program name is "RPO" for Runs Per Over), the calculator dump is:- Code: PX41 Ian HP-41CV PX-15C PX-41CX |
09-12-2024, 03:19 PM
Post: #149
RE: PX41CX | |||
User(s) browsing this thread: 16 Guest(s)
