P+ for HP Prime Development in PPL
08-26-2023, 07:53 PM
RE: P+ for HP Prime Development in PPL
[quote='Insoft' pid='172546' dateline='1683767659']
P+ [b] In reality the P+ language is basically an extension to the PPL language to help with code maintenance and comprehensibility. /quote] I'm just not a fan of pre-processors. If it was a standalone language, I'd use it. Tom L Cui bono? |
05-15-2024, 11:45 PM
(This post was last modified: 09-09-2024 02:43 PM by Insoft.)
PrimePlus (P+) now dose pre-calculations
This is useful for reducing the size and memory used by your PPL program but want to include the equation to understand why this value. eg. Code: #define SCREEN_WIDTH 320 PPL Code: LOCAL m:=80; |
05-24-2024, 10:29 PM
(This post was last modified: 05-25-2024 11:41 PM by Insoft.)
UPDATE: 1.7.1.075
NEW! Improved Structs for version 1.7.1 Previously in P+, defining a struct for a function parameter was not allowed, unlike for variables. However, starting from version 1.7.1, you can now define a struct for a function parameter just as you would for a variable. NOTE: When defining a struct for a parameter, ensure the parameter has an alias. This alias must be used consistently when defining and using the struct. Code: struct Color |
09-07-2024, 02:28 PM
(This post was last modified: 09-07-2024 03:50 PM by Insoft.)
Utility for PPL Code
Currently in the early experimental and testing phase, the primary goal is to minimize the file size of any PPL code, reducing its overall footprint. The PPL file must be in UTF-16LE format, and at this time, .hpprgrm files with headers are not supported—only raw code is accepted. Accommodate the P+ PreProccessor PPL-Mifier |
09-07-2024, 09:02 PM
Hi, I think that for this project, developing a program editor on the PC would make coding easier.
09-12-2024, 03:10 PM
(This post was last modified: 09-18-2024 04:58 PM by Insoft.)
UPDATE
P+ v2.0 is currently in development to resolve several issues and eliminate unnecessary, unused features, such as the minifier capabilities. Previous versions will remain available for download. PPL code that is generated will conform to the same format as PPL Reformatter would produce, it will not be in anyways or unable unlike v1.x to be minified or compressed, to minify and compress PPL code please use PPL Minifier utility. v2.x will be more strict with missing `;` unlike in v1.x if are missing they were optional, this will no longer be the case for v2.x P+ is very much PPL extended and with some C like futures. PPL Minifier Minifier & Compressor for PPL Code Minification of your code results in it taking up less space, making it use less storage of your HP Prime's storage memory giving you more space for more programs. v1.0 has been released as a binary for macOS (Intel & Apple Silicon), with the source code available on GitHub for users on other platforms to compile. PPL Reformat Reformater for PPL Code Reformating your code enforce a consistent coding style throughout your project, making it easier for multiple developers to work on the same codebase. It helps maintain a uniform look and feel, which can enhance code readability. Readability: Well-formatted code is easier to read and understand. Insoft Tools for HP Prime Software Development |
Yesterday, 01:42 AM
(This post was last modified: Yesterday 01:44 AM by Insoft.)
P+ 2.0 Released!
Improved the pre-processing handling, will produce formatted PPL code with indenting of 2 spaces per nesting level. Fixed an issue with `aliases` where some complex aliases created with `def` would not be correctly parsed. Improvement with the C style `for...next` loop, one can do `for ;; do` just like in C, tho simply produces same PPL code as `do...loop` Smarter Parser for the likes of `!` `!` now behave as one expect unless used in an `IF WHILE UNTIL` then they behave like C so ! is not factorial but a NOT Other bug fixes. Insoft Tools for HP Prime Software Development |
Yesterday, 03:39 AM
(Yesterday 01:42 AM)Insoft Wrote: P+ 2.0 Released! The PC files at the location in your signature aren't ZIP files. They're some sort of text files. Tom L Cui bono? |
Yesterday, 10:23 AM
(Yesterday 03:39 AM)toml_12953 Wrote:(Yesterday 01:42 AM)Insoft Wrote: P+ 2.0 Released! For none macOS users there is no binary provided currently for PC, Linux or Raspberry Pi, one will have to download the source files on GitHub and compile for that platform. Downloads for other platforms "The complete source code is available on GitHub , ready to be built for any platform." Insoft Tools for HP Prime Software Development |
