Transforming Data 1 Variable Stats
09-08-2024, 07:22 PM
How to transform data set on hp prime. I am in 1 var stats, and I have entered my data into col D1. I want D2 to be D1 + 1 for every cell.
09-09-2024, 01:56 PM
RE: Transforming Data 1 Variable Stats
Have you tried D2:=D1+1 ?
09-09-2024, 03:21 PM
(This post was last modified: 09-09-2024 03:22 PM by C.Ret.)
Yes, this is the right thing to do. But, don't try it! Do it!
You have your first set of data entered (see FIG 1): Then press the HOME button and key in D1+1▶D2 and validate by pressing the ENTER key. Dont forget to activate this second set by pressing the black TOOL button then touch App soft menu, then press 1 key and 4 key to select the CHECK instruction from the menu. Key 2 and press ENTER this activate the second DATA SET you just store into the D2 register (see FIG 2). Now if you press the black Num button the two datasets appears (see FIG 3). If you touch the Stat soft menu you now get the one-variable statistics for each of the checked set. (see FIG 4) Hope this help a bit. Any question or comments are welcome. C.Ret |
