Bug report
09-25-2024, 11:34 PM
Bug report
I am a user of G1 HP Prime with firmware version 2.1.14730.
I discovered that when you try to compute SVD of the matrix [[1, 1], [0, 0]] in CAS mode, HP Prime crashes for some reason.
09-26-2024, 01:53 AM
RE: Bug report
You could update to 2.2 and try again.
Insoft Tools for HP Prime Software Development
09-26-2024, 04:09 AM
RE: Bug report
Confirmed behaviour for HP Prime G1 (both in CAS and HOME modes)
Software Version: 2.2
Hardware Version: C
Details
Software Build Date: 2024-09-01
Software Revision: 15157
Versión de CAS: 1.5.0
Versión de MicroPython: 1.9.4
Sistema Operativo: V0.050.640
However, HP Prime Windows emulator (CAS mode) shows a warning message before giving an answer (which I think is correct). In HOME mode, no warning message appears and the answer is the same as CAS mode.
Versión de software: 2.1.14730 (2023-04-13)
Versión de hardware: Emu
10-07-2024, 06:17 AM
RE: Bug report
Thank you for the bug report. The detailed description is appreciated. I’ve managed to reproduce the issue (on both 2.2 and the current internal beta) and have created a ticket for this in the bug tracker.
10-07-2024, 04:11 PM
RE: Bug report
It seems that displaying the message that the matrix is ill-conditionned crashes the G1. At least disabling the message fixes the crash.
