The Rogue HP-12c
10-11-2024, 06:56 PM
(This post was last modified: 10-11-2024 10:32 PM by Surfin.)
Post: #81
RE: The Rogue HP-12c
(10-11-2024 05:43 PM)AnnoyedOne Wrote:(10-11-2024 05:29 PM)Surfin Wrote: Just to check if now we have the cable connection. I guess it´s I2C, also serial but almost sure it´s not the same protocol as used before. (10-11-2024 05:43 PM)AnnoyedOne Wrote:(10-11-2024 04:23 PM)Idnarn Wrote: In my units, the display shows 1.L 2.C 3.h 4.CPu... For record, my Prestige reports "4029814 h2" And also: Quote:ChE--564Ah But the older Platinum* model, all silver and no Undo button: Quote:CHE--0EdFH no '2004 hP' at the end, there is also no 4.CPu, just "1.LCD 2.CHE" options. |
10-11-2024, 07:04 PM
Post: #82
(10-11-2024 06:56 PM)Surfin Wrote: I guess it´s I2C, also serial but almost sure it´s not the same protocol as used before. Maybe so. My 2022 12C+ looks the same. USB (HP-15C CE cable). Confirmed. I've sucked and saved the firmware, A1 HP-15C (2234A02xxx), HP-16C (2403A02xxx), HP-15C CE (9CJ323-03xxx), HP-20S (2844A16xxx), HP-12C+ (9CJ251) |
10-12-2024, 04:02 AM
Post: #83
The 4. CPU value should change each time you run it, pretty sure it’s just reporting the clock speed
10-12-2024, 07:20 AM
Post: #84
(10-11-2024 04:59 PM)Idnarn Wrote: An example of a monochrome LCD that I used recently which was impressive is the one on the Garmin eTrex SE GPS receiver. I believe it's a Sharp memory LCD: https://sharpdevices.com/memory-lcd/ They do. This is exactly what the DM42 and similar use. Current daily drivers: HP-41CL, HP-15C, HP-16C |
10-12-2024, 12:42 PM
(This post was last modified: 10-12-2024 04:19 PM by AnnoyedOne.)
Post: #85
(10-12-2024 04:02 AM)cheesy Wrote: The 4. CPU value should change each time you run it, pretty sure it’s just reporting the clock speed Could be! From the GPLB31A datasheet I have Quote:Max. operating speed: 4.0MHz @ 2.4V - 3.6 From the GPL833F datasheet Quote:Built-in X’tal 32.768KHz oscillator circuit for real time clock function and system operating clock. So the latter can operate at twice the speed (8MHz vs 4MHz). If a GPLB31A based HP-12C Platinum/Prestige does show the system clock speed with the 4.CPu item the numbers for them would make sense (around 4,000,000). By contrast a GPL833F one would display around 8,000,000. I've no idea what the "h2" means though. Could be a chip rev ID. I'd expect the GPL833F to be different if so. A1 PS: 4,000,000 / 32768 ==> 122 for the PLL (phase locked loop) multiplier. 8,192,000 / 32768 ==> 250 32kHz crystals are usually accurate to ppm (parts per million). It is possible that the firmware "throttles" the clock speed to save power, HP-15C (2234A02xxx), HP-16C (2403A02xxx), HP-15C CE (9CJ323-03xxx), HP-20S (2844A16xxx), HP-12C+ (9CJ251) |
10-12-2024, 01:24 PM
Post: #86
RE: The Rogue HP-12c | |||
10-12-2024, 01:37 PM
Post: #87
(10-12-2024 01:24 PM)cheesy Wrote: I'd hazard a guess that it's Hz Makes you wish for a Swissmicros clone with a dot-matrix LCD vs a 7-segment one. A1 HP-15C (2234A02xxx), HP-16C (2403A02xxx), HP-15C CE (9CJ323-03xxx), HP-20S (2844A16xxx), HP-12C+ (9CJ251) |
10-13-2024, 09:34 PM
Post: #88
10-14-2024, 01:29 AM
Post: #89
(10-13-2024 09:34 PM)dm319 Wrote: Same here with the rogue - no 4th option. Yeah. That's to be expected. The "4.CPu" menu option is only present in the HP-12C Platinum/Prestige v2 firmware from 2004 or so. The early "silver" Platinum/Prestige models have v1 firmware and thus don't have that function. Since you've already verified that the "rogue" doesn't have any hidden extra Platinum functions present (e.g. g x^2) that option being absent isn't really surprising. Unless pressing '4' in the menu works anyway (unlikely). Nor is it a HP NUT emulation per my HP-12C+. You've proven that also. So what is it? The firmware probably can't be "sucked" (no programmer and/or it is "secured") so still a mystery. At least for now. A1 HP-15C (2234A02xxx), HP-16C (2403A02xxx), HP-15C CE (9CJ323-03xxx), HP-20S (2844A16xxx), HP-12C+ (9CJ251) |
10-19-2024, 05:48 AM
Post: #90
(10-10-2024 06:58 PM)dm319 Wrote: I am so confused now! I thought Platinums were made in China? Does anyone fancy getting hold of one of these and we can scratch our collective heads over another 12c? My Platinum was made in the Philippines. HP-12C Gold / HP-12C Platinum |
User(s) browsing this thread: 19 Guest(s)
