Why is Eliminate command not implemented in Prime?
10-14-2024, 11:45 AM
Why is eliminate command not implemented in Prime? Whereas it is found in XCAS and Prime has the same engine as XCAS.
10-14-2024, 04:15 PM
RE: Why is Eliminate command not implemented in Prime?
but it can be incorporated in future updates.
10-14-2024, 05:06 PM
According to this thread the command didn't work on the Prime (crashed G1), so it was not enabled.
- neek
10-14-2024, 05:27 PM
(10-14-2024 05:06 PM)ftneek Wrote:  According to this thread the command didn't work on the Prime (crashed G1), so it was not enabled.
That means another algorithm is needed or a large modification is required to implement this command for Prime.
I hope they can find a solution for this since eliminate is an important command.
