What comes next?
10-15-2024, 01:53 PM (This post was last modified: 10-15-2024 01:54 PM by Gil.)
RE: What comes next?
Gilles, hi.
I want to try your code but I don't use libraries (LstX library).
In your code
DUPDUP RHEAD SWAP
2 OVER SIZE START
ΔLIST DUP RHEAD ROT + SWAP
NEXT
+ ADD
how are defined
RHEAD & ΔLIST, please?
Thanks for your help.
Gil
10-15-2024, 02:53 PM (This post was last modified: 10-15-2024 05:37 PM by Thomas Klemm.)
(10-15-2024 01:34 PM)Gil Wrote:  My next question is if I may ask: what is the code algorithm you used in your first post to get the binomial coefficient?
Let me again add some comments:
00 { 24-Byte Prgm }         ; a_n
01 1                        ; 1 a_n
02 RCL+ 00                  ; n+1 a_n
03 STO 00                   ; n=n+1 a_n
04 X<>Y                     ; a_n n
05 ENTER                    ; a_n Σa=a_n n
06 GTO 01                   ; jump to label 01
07▸LBL 00                   ; repeat
08 RCL- IND ST Z            ; Δa_k=a_{k+1}-a_k Σa k
09 STO+ ST Y                ; Δa_k Σa=Σa+Δa_k k
10▸LBL 01                   ; a_k Σa k
11 STO IND ST Z             ; R[k]=a_k
12 DSE ST Z                 ; a_k Σa k=k-1
13 GTO 00                   ; until k==0
14 R↓                       ; Σa
15 END
We keep the increasing number of elements \(n\) in register 00.
Let's assume we're at the situation of post #4 and we want to add 35.
The difference is calculated in register X while the sum for the next value is calculated in register Y:
\begin{array}{|l|l|l|}
\hline
X & Y & Z \\
\hline
35 & 35 & 6 \\
15=35-20 & 50=35+15 & 5 \\
5=15-10 & 55=50+5 & 4 \\
1=5-4 & 56=55+1 & 3 \\
0=1-1 & 56=56+0 & 2 \\
0=0-0 & 56=56+0 & 1 \\
\hline
\end{array}
Meanwhile the counter in register Z is decremented until it is 0.
I suggest to give Free42 a try.
You can copy and paste the program when the simulator is in program mode: PRGM.
Switch back and clear the registers with CLEARCLRG.
And then just follow the example.
Press ▼ to single step through the program.
10-15-2024, 03:08 PM
(10-15-2024 01:34 PM)Gil Wrote:  Last question, what will you get in your calculator or l'émulation for the next number of the following list?
{ 17 72 97 8 32 15 63 97 57 60 83 48 26 12 62 3 49 55 77 97 98 0 89 57 34 92 29 75 13 40 3 2 3 83 69 1 48 87 27 54 92 3 67 28 97 56 63 }
Using Free42:
-313'323'742'215'540
This is the contents of the registers:
00: 47
01: 5'958'939'610'275
02: -78'383'926'242'917
03: -81'440'397'593'595
04: -61'857'014'876'959
05: -41'068'588'193'054
06: -25'166'184'482'905
07: -14'575'039'183'813
08: -8'077'783'405'239
09: -4'315'910'331'471
10: -2'233'812'545'366
11: -1'123'843'700'063
12: -551'048'120'900
13: -263'882'576'032
14: -123'622'702'625
15: -56'724'531'441
16: -25'506'257'595
17: -11'232'717'406
18: -4'834'604'086
19: -2'024'788'492
20: -819'077'008
21: -316'401'610
22: -114'802'997
23: -38'274'698
24: -11'472'693
25: -3'158'214
26: -1'009'379
27: -554'630
28: -400'969
29: -243'086
30: -83'702
31: 34'596
32: 95'896
33: 109'634
34: 95'153
35: 70'112
36: 45'767
37: 27'055
38: 14'703
39: 7'456
40: 3'600
41: 1'701
42: 805
43: 376
44: 158
45: 48
46: 7
47: 63
10-15-2024, 04:08 PM (This post was last modified: 10-15-2024 04:12 PM by Gilles.)
(10-15-2024 01:53 PM)Gil Wrote:  how are defined
In NewRPL ?
RHEAD : << DUP SIZE GET >>
ΔLIST is the the same than in stock RPL
In NewRPL with lists, the commands + and ADD are switched.
With stock HP50, the program could be (not tested) :
 DUPDUP DUP SIZE GET SWAP
 2 OVER SIZE START
   ΔLIST DUPDUP SIZE GET ROT + SWAP
 NEXT
10-15-2024, 05:39 PM
(10-14-2024 08:35 PM)Gilles Wrote:  newRPL with LstX library. Enter the first numbers as a list and you get a list with a new guess number. etc.
 DUPDUP RHEAD SWAP
 2 OVER SIZE START
 NEXT
 + ADD
For "Old RPL" with the ListExt Library, RHEAD can be replaced by LPOPR NIP.
10-15-2024, 09:09 PM
(10-15-2024 04:08 PM)Gilles Wrote:  In NewRPL with lists, the commands + and ADD are switched.
 2 OVER SIZE START
 NEXT
The last line should be ADD + .
10-15-2024, 10:59 PM
 DUPDUP RHEAD SWAP
 2 OVER SIZE START
 NEXT
 + ADD
… and with the GoferLists (1.0) Library (another jewel), RHEAD can be replaced by Last (with a capital L).
Bruno
Sanyo CZ-0124 ⋅ TI-57 ⋅ HP-15C ⋅ Canon X-07 + XP-140 Monitor Card ⋅ HP-41CX ⋅ HP-28S ⋅ HP-50G ⋅ HP-50G
10-16-2024, 12:56 AM
(10-15-2024 04:08 PM)Gilles Wrote:  With stock HP50, the program could be (not tested) :
 2 OVER SIZE START
 NEXT
This works mostly with an HP-48:
DIR
  NXT
    \<< DUP LST OVER 2 OVER SIZE
      START \GDLIST DUP LST ROT + SWAP
      NEXT DROP +
  LST
    \<< DUP SIZE GET
END
For a list with a single element I get:
ΔLIST Error: Invalid Dimension
10-16-2024, 04:51 AM
I wondered why I used this in my T program but now NXT also works with a single element list:
\<< DUP LST OVER
  WHILE DUP SIZE 1 >
  REPEAT \GDLIST DUP LST ROT + SWAP
  END DROP
Also the usage is similar to my initial program since the last + command was removed.
If the prediction of what comes next matches, add it to the list.
Otherwise DROP it and add the proper one.
10-16-2024, 10:14 AM (This post was last modified: 10-16-2024 10:30 AM by Gil.)
Question to Gilles relative to his post #24
Changing last line + + into ADD +
\<< DUPDUP DUP SIZE GET SWAP 2 OVER SIZE
  START \GDLIST DUPDUP SIZE GET ROT + SWAP
  NEXT ADD +
and building
\<< { } 0 3
  FOR i '2*i^2+3*i+5' EVAL +
  NEXT
we get { 5 10 19 32 }.
Deleting the number 32 from the above list,
we get { 5 10 19 }
and with that latter list as argument with your program we get 36 instead of "my" 32.
Question:
How is it possible?
If the 4th number were indeed 36, as given by your program, then the underlying polynomial should be f(x): '2/3*x^3+13/3*x+5'
and the next number after 36 would be (with the above given new polynomial) 65.
But, with the sequence list {5 10 19 36}, your output is then 69, and not 65.
Gil
10-16-2024, 11:41 AM
(10-16-2024 10:14 AM)Gil Wrote:  How is it possible?
It's a bug in the program: the last number is counted twice.
Once from extracting the element with GET from the list { 4 } and then ADD-ing it to { 4 }.
The fix is to replace ADD by DROP.
10-16-2024, 01:17 PM
Thanks again to all contributers.
Just test Gilles' astonishing compact and extremely fast program : less than 0.05 second vs several minutes with my program to get the next number after { 17 72 97 8 32 15 63 97 57 60 83 48 26 12 62 3 49 55 77 97 98 0 89 57 34 92 29 75 13 40 3 2 3 83 69 1 48 87 27 54 92 3 67 28 97 56 63 }, which is -313323742215540.
Congratulations!
10-16-2024, 04:54 PM
(10-16-2024 01:17 PM)Gil Wrote:  Thanks again to all contributers.
Congratulations!
You must have a very fast computer. That takes about 0.18 seconds on my old laptop which means about 7 seconds on a physical calc (I didn't bother to type the whole list into my 50g.)
Note also that the result will be meaningless unless the initial sequence is defined by a polynomial.
10-16-2024, 07:45 PM (This post was last modified: 10-16-2024 07:59 PM by Gilles.)
(10-16-2024 04:54 PM)John Keith Wrote:  You must have a very fast computer. That takes about 0.18 seconds on my old laptop which means about 7 seconds on a physical calc (I didn't bother to type the whole list into my 50g.)
In newRPL I confirm that it takes 0.048 sec with the physical 50g and 0 sec on my laptop with the Windows version. A 140x faster ratio between newRPL and RPL does not surprise me for this kind of calculation.
10-16-2024, 08:38 PM
This program might be faster:
\<< DUP ROT + SWAP DUP { } + SWAP ROT
  \<< - ROT OVER + SWAP ROT OVER + SWAP
  \>> STREAM DROP
It is of order \(\mathcal{O}(n)\) instead of \(\mathcal{O}(n^2)\) and works similarly to my initial program for the HP-42S.
Example
{ 1 }
2
NXT
{ 2 1 }
3
DROP 4
NXT
{ 4 2 1 }
7
DROP 8
NXT
{ 8 4 2 1 }
15
DROP 16
NXT
{ 16 8 4 2 1 }
31
NXT
{ 31 15 7 3 1 0 }
57
NXT
{ 57 26 11 4 1 0 0 }
99
NXT
{ 99 42 16 5 1 0 0 0 }
163
NXT
{ 163 64 22 6 1 0 0 0 0 }
256
10-17-2024, 05:15 AM
The same program with stack comments:
\<<                     @ A a
  DUP ROT +             @ a A=a+A
  SWAP DUP { } +        @ A Σ=a S={a}
  SWAP ROT              @ S Σ A
  \<<                   @ S Σ a a'
    -                   @ S Σ Δa=a-a'
    ROT OVER + SWAP     @ Σ S=S+Δa Δa
    ROT OVER + SWAP     @ S Σ=Σ+Δa Δa
  \>>                   @ S Σ a=Δa
  STREAM DROP           @ S Σ
10-17-2024, 10:16 AM (This post was last modified: 10-18-2024 10:47 PM by Gil.)
Precisions regarding the execution (time) for finding the next number of the polynomial that creates the initial string
{ 17 72 97 8 32 15 63 97 57 60 83 48 26 12 62 3 49 55 77 97 98 0 89 57 34 92 29 75 13 40 3 2 3 83 69 1 48 87 27 54 92 3 67 28 97 56 63}:
1) time to find out f(47), the 48th number = -313323742215540: about 0.05 s (most of the time about 0.049s, but maximum time 0.058s);
2) Code used (\GS is —>capital delta)
  NEXT DROP +
3) No NewRPL, but original user RPL;
4) No computer, but EMU48 on Samsung phone A53;
5) Like 4, but with setting "Authentication Calculator Speed": about 5.3s —> here then more than 100 times slower.
10-18-2024, 07:53 PM (This post was last modified: 10-18-2024 07:57 PM by Gilles.)
A recursive version en newRPL :
Next?
« DUP RHEAD SWAP ΔLIST DUP SIZE 1 > « Next? »  IFT + »
ex : { 0 0 0 0 1 5 15 35 70 126 } Next? -> { 210 }
10-18-2024, 10:49 PM
Is really the above code complete as lastly written by Gilles?
10-18-2024, 11:57 PM (This post was last modified: 10-18-2024 11:59 PM by John Keith.)
(10-18-2024 10:49 PM)Gil Wrote:  Is really the above code complete as lastly written by Gilles?
It works in "OldRPL" if you change RHEAD to DUPDUP SIZE GET and change the final + to ADD. (Remember, the functionality of + and ADD are reversed in NewRPL.)
