-10706+20 = -10746 on my 15CE
10-18-2024, 02:57 AM
I got a strange result when tried to compute -10706 + 20 and got -10746
My keystrokes were :
10706, CHS, ENTER, 20, +
with the same keystrokes, my 12c gave -10686
I re-tried below sequence on the 15CE but still got -10746
10706, ENTER, CHS, 20, +
My settings was RAD, complex mode
Was there anything wrong with my keystrokes ?
12C, 15C, 15cCE, 19Bii, 20S, 22S, 35S, 39Gii, 42S, 48G, 50G, 97
10-18-2024, 06:10 AM
RE: -10706+20 = -10746 on my 15CE
can't confirm that on a 15CE. Then I thought: how could you arrive at a number ending with ...46? There is a nonzero possibility (nonzero because it happened to me!) of having typed -107066 in the first place and having misread the result as -10746 (in fact it is -107046).
emeff.
[35, 45, 41CV, 41CX, 12c, 15c, 15CE, 28S, 42s, 48GX, DM15L, DM42, DM41X, wp34s, wp34s_on_DM42, 35S, Prime, IVEE]
10-18-2024, 07:05 AM (This post was last modified: 10-18-2024 07:07 AM by Johnh.)
Could it be a couple of problems segments on the LCD? eg if the 4th digit had three segments not working, it could look like a 4 instead of an 8?
A test would be to get the answer and then divide by 2 to get what should be -5343.
I couldn't replicate the issue on mine.
10-18-2024, 08:32 AM
Not a problem of segment or mis-typing.
I just tried to clear flag 8 but got an Error 10
As I wrongly believed that should be flag 7, I cleared flag 7 and the "C" annunciator gone.
Then I tried -10706+20 and it gave the correct answer -10686 !!!
As I wondered if the complex mode was the cause, I set flag 7. Of course the "C" did not appear.
After checking with the manual, I knew it should be flag8.
But now it always gives an Error 10 when I set flag 8
I believe something goes wrong with Matrix. I check the Matrix A has a dimension of 47 x 51 !
I tried f -> MATRIX -> 0 but got an Error 10
Now I have the correct result -10686 but no complex mode or Matrix.
Wonder if a reset helps ? ( by the way, could anyone know how to reset it ? )
10-18-2024, 08:53 AM
(10-18-2024 08:32 AM)HKG Wrote:  But now it always gives an Error 10 when I set flag 8
It seems the memory has been corrupted.
Try a "soft" reset described in the manual ("Resetting Continuous Memory"):
Quote:1. Turn the calculator off.
2. Press and hold the [ON] key, then press and hold the - key.
3. Release the [ON] key, then the - key. (This convention is represented as [ON] / -.)
When Continuous Memory is reset, Pr Error (power error) will be displayed. Press any key to clear the display.
J-F
10-21-2024, 03:36 AM
Hi J-F,
It works now ! I got the correct answer and no Error 10 now.
Thanks for your suggestion.
10-24-2024, 03:49 AM
So, technically it could happen with the 12C too, I'm correct?
HP-12C Gold / HP-12C Platinum
10-24-2024, 04:13 AM
I believe that depends on the cause of such problem.
I stored the 15CE in my backpack while traveling to work. Recently, there were many stuff inside the backpack which (I guess) the calculators keys were pressed & held for a long time
If that was the case, 12c may behave similarly under the same condition
10-24-2024, 04:41 AM
[Image: cnr.png]
10-25-2024, 08:08 AM
WOW !
