HP Prime Setting Date
10-29-2024, 01:32 AM
I have been unable to set the date in the Home Setting page 2/4 in my newly purchased HP Prime.I have done a search on the forum but there doesn't seem to be any info on this. Any help would be much appreciated.
10-29-2024, 02:06 PM
RE: HP Prime Setting Date
Press on the down side of the cursor control circle until the date is selected.
An edit button will appear on the screen. Press the edit button to change the date.
Make sure your date entry is in the same format as is the case on the format to the
right. (My format is YYYY/MO/DA -- yours maybe different).
Maybe someone else can come up with clearer directions.
Lter
10-30-2024, 01:00 PM
(10-29-2024 02:06 PM)Liamtoh Resu Wrote:  Press on the down side of the cursor control circle until the date is selected.
Alternative method using only the touch screen: Tap the "Date:" field (on page 2 of Home Settings) to select it, then tap it again to pop up a calendar. Use your finger on the calendar to change the date, to wit: swipe left & right to change the month; swipe up & down to change the year; tap a day to select it. Then press Enter to change the system date to your selected date.
<0|ΙΈ|0>
-Joe-
