Calculator test
Yesterday, 02:04 PM
(This post was last modified: Yesterday 02:05 PM by Maximilian Hohmann.)
Post: #81
RE: Calculator test
(Yesterday 01:37 PM)AnnoyedOne Wrote: There's really no such thing thing since you can't have -x of anything. After buying all these calculators, I have plenty of negative Euros on my bank account. And it will require a lot of imaginary money to even out the balance ;-) But without kidding: I actually do see negative numbers in the real/material world. Wherever there is a natural origin of a coordinate system, e.g. the surface of the ocean. Above is positive, below is negative. At least from a aviator's point of view. For a submariner it will be the opposite. Regards Max |
Yesterday, 02:12 PM
Post: #82
RE: Calculator test
(Yesterday 02:04 PM)Maximilian Hohmann Wrote: ...I actually do see negative numbers in the real/material world.Yes, like I said you see a real relationship between two or more things. A1 PS: How's your relationship with your bank? HP-15C (2234A02xxx), HP-16C (2403A02xxx), HP-15C CE (9CJ323-03xxx), HP-20S (2844A16xxx), HP-12C+ (9CJ251) |
Yesterday, 02:28 PM
(This post was last modified: Yesterday 02:28 PM by Maximilian Hohmann.)
Post: #83
RE: Calculator test
(Yesterday 02:12 PM)AnnoyedOne Wrote: PS: How's your relationship with your bank? This is also one of the big paradoxes of (bank) accounting: The more negative your balance is, the more positive you are seen by your bank manager. Instead of them owing something to you, they will get money from you every month and in the end they will get your house for next to nothing :-) Regards Max |
Yesterday, 03:27 PM
(This post was last modified: Yesterday 03:35 PM by AnnoyedOne.)
Post: #84
RE: Calculator test
(Yesterday 02:28 PM)Maximilian Hohmann Wrote: This is also one of the big paradoxes of (bank) accounting... A millionaire/billionaire was once quoted as saying Quote:If you owe a bank 250k you have a problem. Banks generally don't like negative numbers. As for imaginary ones... A1 HP-15C (2234A02xxx), HP-16C (2403A02xxx), HP-15C CE (9CJ323-03xxx), HP-20S (2844A16xxx), HP-12C+ (9CJ251) |
Yesterday, 06:19 PM
Post: #85
RE: Calculator test
Hi Guys,
Here are complex exponential and natural log: \[e^{x+iy} = e^{x}cos{y} + {i}e^{x}sin{y}\] \[ln({x+iy}) = \frac{1}{2}ln({x^{2}+y^{2}})+{i}arctan(\frac{y}{x})\] Cheers Darren TI89T,TI83+,TI84+,TI84+SE,TI84+C,TI84+CE, TI30X-MP,HP50g,HP45,HP15CE,HP35s,Casio cg50,Casio 991cw |
Yesterday, 06:25 PM
Post: #86
RE: Calculator test
My favourite example for negative numbers is Dirac's puzzle
https://math.stackexchange.com/questions...le-fishing os similar puzzle. Three persons are living in the house. If 4 persons left this house, how many persons should go in to have empty house? |
Yesterday, 06:29 PM
(This post was last modified: Yesterday 06:44 PM by AnnoyedOne.)
Post: #87
RE: Calculator test
(Yesterday 06:25 PM)klesl Wrote: ...how many persons should go in to have empty house? None. 4 left already. Perhaps more inside. No math needed. Whatever the case anyone going in (who live there or not) makes the number of occupants > 0. A1 HP-15C (2234A02xxx), HP-16C (2403A02xxx), HP-15C CE (9CJ323-03xxx), HP-20S (2844A16xxx), HP-12C+ (9CJ251) |
Yesterday, 06:35 PM
Post: #88
RE: Calculator test
(Yesterday 02:04 PM)Maximilian Hohmann Wrote: actually do see negative numbers in the real/material world. Wherever there is a natural origin of a coordinate system, e.g. the surface of the ocean. Above is positive, below is negative. At least from a aviator's point of view. I think you say that easily only because you are familiar and comfortable with the concept of negative numbers. Both locations are simply real, positive distances from a point, in different directions. |
Yesterday, 07:03 PM
Post: #89
RE: Calculator test
My young daughter couldn't quite grasp the idea of negative numbers, at school, until we sat down and played with money, and IOU/loan notes, and then she said "oh, but that's obvious!".
The bank analogy (for adults) is similarly easy for these odd non-mathematical folk to grasp, it seems. Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot/C47 Casio, Rockwell 18R |
Yesterday, 08:12 PM
(This post was last modified: Yesterday 08:21 PM by Idnarn.)
Post: #90
RE: Calculator test
(Yesterday 06:19 PM)Commie Wrote: \[ln({x+iy}) = \frac{1}{2}ln({x^{2}+y^{2}})+{i}arctan(\frac{y}{x})\] This is one logarithm. There are more. The above is missing a term: \[2k\pi i\] See: https://en.wikipedia.org/wiki/Complex_logarithm The above expression is clearer in the polar form where arctan(y/x) is theta and 1/2*ln(x^2+y^2) = ln(sqrt(x^2+y^2)) = ln(r). \[\ln(re^{i\theta}) = \ln r + i\theta + 2k\pi i\] |
Yesterday, 09:22 PM
Post: #91
RE: Calculator test
(Yesterday 08:12 PM)Idnarn Wrote: The above is missing a term: I'm sorry, but I don't understand wikipedia's interpretation of k, it seems to be quantized? The equation, I have shown, is from a pure math prospective, for example assume z=1+2i Entering this on my ti84+ reveals the answer of 0.8+1.11i If I calculate this using the equation given, then on my ti30x pro, I get 0.8+1.11i Doing the same calculation on the hp 35s reveals the same answer. I think you are mixing up pure maths with applied math/physics?I have not specified what the imaginary part actually is physically. Cheers Darren TI89T,TI83+,TI84+,TI84+SE,TI84+C,TI84+CE, TI30X-MP,HP50g,HP45,HP15CE,HP35s,Casio cg50,Casio 991cw |
Yesterday, 11:14 PM
(This post was last modified: Yesterday 11:39 PM by naddy.)
Post: #92
RE: Calculator test
(Yesterday 09:22 PM)Commie Wrote:(Yesterday 08:12 PM)Idnarn Wrote: \[\ln(re^{i\theta}) = \ln r + i\theta + 2k\pi i\] \(k = \dots, -2, -1, 0, 1, 2, \dots\) ; i.e., \(k \in \mathbb Z\) All of those (infinitely many) values are a correct solution for \(\ln(r e^{i\theta})\). Many complex functions have more than one value for any argument. Typically one is designated the principal value, which in this case is the one you gave a formula for. Section 3 of the HP-15C Advanced Functions Handbook has some helpful notes about this. Think square roots: \(\sqrt 4 = \pm 2\), but the calculator will only give you the principal value, \(2\). The best calculator is the one you actually use. |
User(s) browsing this thread: Divasson, mfleming, 87 Guest(s)
