Differences between the different solve/zeros commands?
10-23-2014, 11:36 PM
What are the differences between the different solve/zeros commands and which commands are recommended when?
Trying to solve this for x but cant find a working command: ARG((-e^(-0.3*i*x))/(x^2-i*x))=-165 Any help would be really appreciated! |
10-24-2014, 01:05 AM
RE: Differences between the different solve/zeros commands? | |||
10-24-2014, 06:18 AM
10-24-2014, 08:04 AM
This equation has no solution. If you take exp(0.3*i*x), x must be in radians, therefore argument should be rescaled in -pi..pi.
fsolve(arg((-e^(-0.3*i*x))/(x^2-i*x))=-165*pi/180,x=-10..10) returns 2 solutions. |
10-25-2014, 10:01 PM
(10-24-2014 08:04 AM)parisse Wrote: This equation has no solution. If you take exp(0.3*i*x), x must be in radians, therefore argument should be rescaled in -pi..pi. Thanks! When is fsolve recommended and when is other commands recommended for solving? Any other cases radians must be selected? |
10-26-2014, 07:34 AM
fsolve is recommended if you want a numeric answer, solve if you want a symbolic answer (but solve can only find roots for polynomial-like equations).
