WP34s Builds
10-26-2014, 05:16 PM
WP34s Builds
I'm trying to build bin files from Windows 7. I've read a lot about it, installed and modified files as suggested by Nigel J Dowrick in his article. I've succeeded in building wp34s-lib file but had no success with calc.bin.
I keep getting this error message from flash-build log file:
Modification of non-creatable array value attempted, subscript -1 at c:\WP\bin\wp34s-code\tools\wp34s_asm.pl line 1891.
Makefile:402: recipe for target 'xrom.c' failed
mingw32-make[1]: *** [xrom.c] Error 25
mingw32-make[1]: Leaving directory 'C:/WP/bin/wp34s-code'
make: *** [realbuild/calc.bin] Error 2
I'm missing something here.
I'm using makeflash.cmd. I couldn't find flash.cmd anywhere so I guess it has been replaced by makeflash.
If someone could give me a hint in sloving this issue, I would appreciate it.
Patrick
10-26-2014, 06:59 PM
RE: WP34s Builds
(10-26-2014 05:16 PM)mendesp Wrote:  Modification of non-creatable array value attempted, subscript -1 at c:\WP\bin\wp34s-code\tools\wp34s_asm.pl line 1891.
It is trying to assemble the XROM code with Neil's assembler. XROM is just a keystroke program to implement some of the built-in functionality.
Maybe Neil can chime in...
Marcus von Cube
Wehrheim, Germany
http://www.mvcsys.de
http://wp34s.sf.net
10-27-2014, 10:37 AM
RE: WP34s Builds
Could you please verify that you are using the actual revision of the script?
Path: tools/wp34s_asm.pl
URL: http://svn.code.sf.net/p/wp34s/code/trunk/tools/wp34s_asm.pl
Repository Root: http://svn.code.sf.net/p/wp34s/code
Repository UUID: 9654ca62-1852-461c-aa49-1be32f3bb02d
Revision: 3680
Node Kind: file
Schedule: normal
Last Changed Author: paulidale
Last Changed Rev: 3425
Last Changed Date: 2013-06-27 02:12:48 +0200 (Thu, 27 Jun 2013)
Text Last Updated: 2014-01-09 10:20:12 +0100 (Thu, 09 Jan 2014)
Checksum: 5c348f4629a92dc95be97d9f7e1348d5
tools/wp34s_asm.pl:
1877 #######################################################################
1878 #
1879 # Dump the output into a C-array.
1880 #
1881 sub dump_c_array {
1882   my $file = shift;
1883   my $leader = shift;
1884   my $indent_spaces = shift;
1885   my @val_array = @_;
1886   open OUT, "> $file" or die_msg(this_function((caller(0))[3]), "Could not open C-array file '$file' for writing: $!");
1887   print OUT "$leader\n";
1888   for my $hex_str (0 .. (scalar @val_array)-2) {
1889     printf OUT "%0s0x%04x,\n", " " x $indent_spaces, $val_array[$hex_str];
1890   }
1891   printf OUT "%0s0x%04x };\nconst unsigned short int xrom_size = sizeof(xrom) / sizeof(const s_opcode);\n", " " x $indent_spaces, $val_array[-1];
1892   close OUT;
1893   return;
1894 } # dump_c_array
I haven't executed the method dump_c_array but if I look at line 1891 there's only this statement that might lead to the aforementioned error message:
$val_array[-1]
But then this should only happen when we try to modify the array with an index that is out of range but not when it is just accessed:
  DB<1> @val_array = ();
  DB<2> x $val_array[-1]
0  undef
  DB<3> $val_array[-1] = 3;
Modification of non-creatable array value attempted, subscript -1 at (eval 10)[/usr/share/perl5/perl5db.pl:638] line 2.
Thus I don't think this might happen with the actual code.
HTH
10-27-2014, 01:05 PM
RE: WP34s Builds
Thank you, Thomas for your reply. I'll have a look at this file and let you know if I could build the bins.
10-27-2014, 01:31 PM
RE: WP34s Builds
Thomas, you were right, I wasn't using the actual revision of the file. I still can't build the file as I get a different error:
xrom_pre.wp34s
// WP 34S assembly preprocessor enabled: '-pp'
// Opcode map source: tools/wp34s.op (specified)
// Opcode SVN version: -- unknown --
// Running WP 34S preprocessor from: C:/wp/bin/wp34s-code/tools/wp34s_pp.pl
AccŠs refus‚.
WARNING: wp34s_asm.pl::run_pp: WP 34S preprocessor failed. Temp file: '.__0.24468994140625.tmp'
ERROR: wp34s_asm.pl::run_pp: Perhaps you can try running it in isolation using: $ "C:/wp/bin/wp34s-code/tools/wp34s_pp.pl" -m 235 -cat .__0.24468994140625.tmp -v3 -xrom -e2so -sd 4 -colour_mode 0
mingw32-make[1]: *** [xrom.c] Error 1
If this can help, it seems that the script can't run wp34s_pp.pl. A message box asks me if I want to open the file instaed of running it. In Makelib.cmd, I replaced the line
set LIB=%TOOLS%\wp34s_lib.pl -d %DEBUG% by
set LIB=%TOOLS%\wp34s_lib.exe -d %DEBUG%
to fix the issue. It worked but obviously this wasn't enough.
What should I modify to run pl scripts properly ?
10-27-2014, 02:50 PM
RE: WP34s Builds
Everything is working now. I had to fix a a file association issue.
Thanks for your help !
Congratulations for this fantastic project !!
10-27-2014, 03:12 PM
RE: WP34s Builds
In order to get some debug-information in tools/wp34s_asm.pl you can set:
 151 my $debug = 3;
Or then set the environment variable WP34S_ASM to PRESERVE_PP_DBG:
1848   print "// Running WP 34S preprocessor from: $pp_location\n";
1849   debug_msg(this_function((caller(0))[3]), "Running: '$cmd'")
1850     if ($debug > 2) or (exists $ENV{WP34S_ASM} and ($ENV{WP34S_ASM} =~ /PRESERVE_PP_DBG/i));
1851
1852   @lines = `$cmd`;
1853   $err_msg = $?;
1854   if( $err_msg ) {
1855     warn_msg(this_function((caller(0))[3]), "WP 34S preprocessor failed. Temp file: '$tmp_file'");
1856     die_msg(this_function((caller(0))[3]), "Perhaps you can try running it in isolation using: \$ $cmd");
1857   }
1858   unlink $tmp_file unless exists $ENV{WP34S_ASM} and ($ENV{WP34S_ASM} =~ /PRESERVE_PP_TMP/i);
But I must admit that I'm not familiar with the build-environment of this project.
Are you sure that your Perl installation is fine?
Completely unrelated:
Quote: # Override the step digits as required.
# XXX Hah! Who knew?! In Perl, 'log' is actually log2, not log10, like everywhere else!!
my $sd = ceil(log($max_flash_words)/log(10));
From perldoc -f log:
       log EXPR
       log     Returns the natural logarithm (base e) of EXPR.  If EXPR is omitted, returns log of $_.  To get the log of another base, use basic algebra: The base-N log of a number is equal to the natural log of that
               number divided by the natural log of N.  For example:
                   sub log10 {
                       my $n = shift;
                       return log($n)/log(10);
               See also "exp" for the inverse operation.
10-27-2014, 03:14 PM
RE: WP34s Builds
Oops, didn't notice that you could solve the problem in the meantime.
10-27-2014, 04:55 PM (This post was last modified: 10-27-2014 04:56 PM by mendesp.)
RE: WP34s Builds
Well it's not quite over yet...
My calc.bin file is much smaller (116 Kb) than the original one (643 Kb).
Maybe I could try to disassemble the files and find what's missing. I probably missed something else that should be obvious.
I tried to add the flash-build log file to this post, but this type of file seems to be not allowed. Should I copy and paste the content to this post ?
Thanks,
Patrick
10-27-2014, 04:59 PM
RE: WP34s Builds
(10-27-2014 04:55 PM)mendesp Wrote:  My calc.bin file is much smaller (116 Kb) than the original one (643 Kb).
116 KB for the calc.bin file is correct. It's just a binary image of the flash contents. The larger file calc (without the extension) is an intermediate file that is used by the hardware debugger.
Marcus von Cube
Wehrheim, Germany
http://wp34s.sf.net
10-27-2014, 05:07 PM
RE: WP34s Builds
So I guess I can flash my calculator with this file. Am I correct ?
Thanks a lot for your help!
Patrick
10-27-2014, 06:41 PM
RE: WP34s Builds
(10-27-2014 05:07 PM)mendesp Wrote:  So I guess I can flash my calculator with this file. Am I correct ?
You can compare it to the image in the repository. If the differences are minor(*), you are on the safe side.
(*) If you didn't change the source code the difference should just be in the revision number which is encoded in the file.
Marcus von Cube
Wehrheim, Germany
http://wp34s.sf.net
