Minehunt program
01-05-2014, 01:32 PM
(This post was last modified: 01-06-2014 08:31 AM by LarsF.)
Minehunt program
From an idea from HP48G
01-05-2014, 04:07 PM
RE: Minehunt program
There is a syntax error in Line 108.
IF L1©==1 THEN What is the © for? Can not figure out what the problem is,yet |
01-05-2014, 04:13 PM
(This post was last modified: 01-05-2014 04:14 PM by LarsF.)
Should be L( C )
01-05-2014, 09:53 PM
(This post was last modified: 01-05-2014 09:59 PM by Terje Vallestad.)
(01-05-2014 04:13 PM)LarsF Wrote: Should be L( C ) You are sure it should not be L1(C) rather than L(C)? I get a Syntax error with L(C) whilst L1(C) compiles fine.... Edit: I noted the forum software changes "L1( C )" to L1(C) Copyright which is unintended. Rewritten with a space either side of the C that should not be in the program. Cheers, Terje |
01-05-2014, 10:22 PM
(This post was last modified: 01-05-2014 10:25 PM by LarsF.)
L1( C ) should it be, thanks. I should have use the code tag, note the quote tag, I believe i would look right then with spaces and no copyright signs...
01-05-2014, 11:24 PM
RE: Minehunt program | |||
01-06-2014, 08:35 AM
I manage to change it to a code tag, looks much better now :-)
Tony, I already downloaded and played your nice little program, thanks. |
