(35S) Conditional Probabilities - Bayes Formula
11-25-2014, 03:00 PM
(This post was last modified: 06-15-2017 01:26 PM by Gene.)
Bayes’ formula is useful for calculating conditional probabilities.
If we set p(E) = A = .001 as the probability of a member of the population having a certain illness E, p(F|E) = B = .99 as the probability of a positive result for the illness test F if the member has the illness E, p(F|-E) = C = .05 as the probability of a positive result for the illness test F if the member does NOT have the illness E, a so-called false positive, then the formula D = A * B / ( A * B + ( 1 – A) * C ) can be used to calculate p(E|F) = D ie the probability of having the illness E if the test F is positive, which for the given data is .019 |
