New Version: 2014.1203
12-04-2014, 04:32 PM
Post: #41
RE: New Version: 2014.1124
(12-04-2014 04:27 PM)phgerin Wrote: Its a bug ? I cant see a busy indicator (hourglass) when selecting the "simplify" soft key for long operations. The calculator seems to be totaly frozen. You normally are able to cancel them with the ON key. The hourglass doesn't always come on with some CAS operations and we haven't been able to figure out why yet... TW Although I work for HP, the views and opinions I post here are my own. |
12-04-2014, 05:56 PM
Post: #42
(12-04-2014 03:37 PM)Tim Wessman Wrote:(12-04-2014 01:11 PM)toml_12953 Wrote: Still no printing from the CK. Actually, I and several others have mentioned this in the past. I like to print copies of my program listings after editing them in the CK. Right now I have to copy/paste them into Windows Notepad, and do a CTRL-P to print them. I seems like it should be fairly easy to incorporate this capability into the CK. |
12-04-2014, 05:58 PM
Post: #43
(12-04-2014 03:37 PM)Tim Wessman Wrote:(12-04-2014 01:11 PM)toml_12953 Wrote: Still no printing from the CK. I'd like to be able to print PPL source code instead of having to copy the source and paste it into notepad or whatever. It would be even better if I could print right from the calculator but since that won't be happening, printing the source from the CK will do. Tom L Tom L Cui bono? |
12-04-2014, 06:29 PM
Post: #44
Ok, I've put printing in on the list of stuff to look at. The connkit is QT based and I haven't done any printing from there yet. However, it looks rather simple.
Is it purely from the notes/programs, or do you think you want to be able to print out things like the a-z variables in a table? TW Although I work for HP, the views and opinions I post here are my own. |
12-04-2014, 07:53 PM
Post: #45
(12-04-2014 06:29 PM)Tim Wessman Wrote: Ok, I've put printing in on the list of stuff to look at. The connkit is QT based and I haven't done any printing from there yet. However, it looks rather simple. Well, just speaking for myself, I'd be good with doing a screen print of anything that appears in an edit window. |
12-04-2014, 11:42 PM
Post: #46
Can anyone give me the link or place to find the newest firmware for the HP Prime. I tried it and can not seem to get it. Also, I found somewhere else where it says it was the 6940 firmware but it was a whole bunch of DAT files. Can anyone help me please? Thank you
12-05-2014, 02:24 AM
Post: #47
(12-04-2014 11:42 PM)marcusnicolas1 Wrote: Can anyone give me the link or place to find the newest firmware for the HP Prime. I tried it and can not seem to get it. TW Although I work for HP, the views and opinions I post here are my own. |
12-05-2014, 02:40 AM
Post: #48
Thanks but where can I get the latest firmware update. IT seems as thought the New Version 2014.1124 is the newest one and I can not find it anywhere. I want to do 3D graphs on my HP Prime and from what I am seeing so far, I can not get the app for that unless I have the 6940 firmware. Can someone please help. Thanks
12-05-2014, 02:54 AM
Post: #49
Also, if I can not get this firmware, is there a way for me to still do 3D graphs still. I want to graph (x^2) - (y^2) or things to that nature. Thanks for the help
12-05-2014, 02:57 AM
Post: #50
(12-04-2014 11:42 PM)marcusnicolas1 Wrote: Can anyone give me the link or place to find the newest firmware for the HP Prime. I tried it and can not seem to get it. Also, I found somewhere else where it says it was the 6940 firmware but it was a whole bunch of DAT files. Can anyone help me please? Thank you In the first post in this thread, Tim gives the URL. But you have to remove the 'http://ftp' and replace it with 'ftp://' in your browser. You can use the controls at the top of the page to go back to the first page of posts. -Jonathan |
12-05-2014, 03:53 AM
Post: #51
Jonathan,
Thank you so much. I am sorry if I am asking so many questions. I have WIndows 8.1 so I am not sure if I have to first open the connectivity kit or do I just plug my Prime and double click on one of those icons. Can you please advise. Thank you so much for your help. I feel as though I am getting closer to solving this mystery. |
12-05-2014, 04:03 AM
Post: #52
(12-05-2014 03:53 AM)marcusnicolas1 Wrote: Jonathan, Download the software in the link provided in the first post. As Jonathan noted already, you have to manually copy the link and remove the "http://" part. Install all the programs (in particular the connectivity kit). Run the connectivity kit after it installs and check for updates. Then connect your HP Prime to your computer (with the connectivity kit running) and it should prompt you to update the calculator. If it doesn't, right-click on the calculator in the connectivity kit window (in the tab on the left), and select Update firmware. You may need to wait a second or two if you don't see that option when you right-click. If for some weird reason when you check for updates in the connectivity kit and it doesn't download the new firmware, you can extract the firmware zip file (see link in first post) into your My Documents/HP Connectivity Kit/firmware folder, and then proceed by connecting your calculator and follow the instructions above. Graph 3D | QPI | SolveSys |
12-05-2014, 07:05 AM
Post: #53
Hello:
I also have problems to download the new version. In this moment, the link provided by Tim only contains one file: "HP_Prime_Calculator_Firmware_20140331.zip", and the Connectivity Kit says that there is not new upgrade. I have to add that I checked with the mobile phone this link on the day that Tim published and I could see all updates. They have now disappeared. Thank you. |
12-05-2014, 07:44 AM
(This post was last modified: 12-05-2014 07:49 AM by Thomas_Sch.)
Post: #54
(12-05-2014 07:05 AM)anderin Wrote: Hello:Hello "HP", me to! The files are missing (see attachment), previously the download link had been very, very slow. Could you please check? |
12-05-2014, 08:08 AM
Post: #55
(12-05-2014 07:44 AM)Thomas_Sch Wrote: I have to add that I checked with the mobile phone this link on the day that Tim published and I could see all updates. They have now disappeared. This is probably good news! It could mean that HP has acknowledged the bugs in the new revision and is working on fixes to be released soon (I hope!). Tom L Tom L Cui bono? |
12-05-2014, 02:58 PM
Post: #56
RE: New Version: 2014.1124 [REMOVED]
(12-04-2014 06:29 PM)Tim Wessman Wrote: Ok, I've put printing in on the list of stuff to look at. The connkit is QT based and I haven't done any printing from there yet. However, it looks rather simple. I'd like to be able to print anything. Not just a screen print but the entire listing of a PPL program or list of variables. Tom L Cui bono? |
12-06-2014, 07:49 AM
Post: #57
Guys
Thank you for your help with my questions. I uploaded version 2.4 of the graph 3D app. It seems as though it is the only one for now that I can use because my firmware is only version 6031. I guess I have to wait until they put a new version up again so I can upgrade. I really want to get the newest 3D app because I want to be able to graph spheres as well. If anyone knows how to do so, please let me know. Thank you |
Post: #58
Guys
12-12-2014, 10:58 AM
Post: #59
Now the prime is completely removed from the ftp-site
http://ftp.hp.com/Pub/calculators Only the 39gII can be found actually. @TW any Explanation? |
12-12-2014, 02:07 PM
(This post was last modified: 12-12-2014 02:11 PM by Tim Wessman.)
Post: #60
(12-12-2014 10:58 AM)ww63 Wrote: @TW any Explanation? Nope, first I've seen that. Looks like there are some problems going on with the publishing system as nothing should have removed that folder. My guess is some automatic "cleaning" routine found there was nothing in that folder one all the older versions were removed and removed the dir... TW Although I work for HP, the views and opinions I post here are my own. |
