Opening more than 1 instance of the virtual calculator
01-24-2015, 02:45 AM
I discovered that more than 1 instance of the virtual calculator can be opened on the PC, and they show up in the CK. Is this by design? I did not pursue this any further, because I didn't want to mess up what I had in the virtual calculator I opened first. Thanks
rcf |
01-24-2015, 11:11 AM
(This post was last modified: 01-24-2015 11:13 AM by Hlib.)
RE: Opening more than 1 instance of the virtual calculator
(01-24-2015 02:45 AM)Bob Frazee Wrote: I discovered that more than 1 instance of the virtual calculator can be opened on the PC, and they show up in the CK. Is this by design? I did not pursue this any further, because I didn't want to mess up what I had in the virtual calculator I opened first. Thanks ![]() You meant it? Sometimes it is comfortably to have several independent apps. near at hand. |
01-24-2015, 12:56 PM
You can give a name to each calculator.
I use this feature 'several primes' e.g. testing several firmwares. HP 33C 34C 11C 41CX 12C 15C HP71B 35s 50g Prime Rev. A, C, D. DM 41X, 42. TI 58C, 59, 74, 92-II, Voyage 200, nspire CX II-T, Sanyo ICC 82D and more |
01-27-2015, 09:29 AM
yes, it's by design. Each prime will also create a separate directory in your %APPDATA% folder. Now, if you want to re-access the 3rd directory, you need to open 2 primes, and the 3rd one will open the 3rd directory... Not the best UI, but it will work. cyrille |
