[HP-48] calculating complex arccos and arcsin functions
01-11-2014, 11:23 PM
(This post was last modified: 07-01-2018 10:46 PM by Thomas Klemm.)
This article deals only with calculating the complex inverse of cosine.
Let's assume \(w=u+iv\). Then \[ \begin{align} z&=&x+iy=\cos(w)=\cos(u+iv) \\ &=&\cos(u)\cos(iv)-\sin(u)\sin(iv) \\ &=&\cos(u)\cosh(v)-i \sin(u)\sinh(v) \\ \end{align} \] But we would like to find \(w=\arccos(z)\). Better don't ask me who came up with this solution: \[ \begin{align} |z+1|^2 &=& (x+1)^2+y^2 \\ &=& x^2+2x+1+y^2 \\ &=& \cos^2(u)\cosh^2(v)+2\cos(u)\cosh(v)+1+\sin^2(u)\sinh^2(v) \\ &=& \cos^2(u)(1+\sinh^2(v))+2\cos(u)\cosh(v)+1+\sin^2(u)\sinh^2(v) \\ &=& \cos^2(u)+\cos^2(u)\sinh^2(v)+2\cos(u)\cosh(v)+1+\sin^2(u)\sinh^2(v) \\ &=& \cos^2(u)+2\cos(u)\cosh(v)+1+(\cos^2(u)+\sin^2(u))\sinh^2(v) \\ &=& \cos^2(u)+2\cos(u)\cosh(v)+1+\sinh^2(v) \\ &=& \cos^2(u)+2\cos(u)\cosh(v)+\cosh^2(v) \\ &=& (\cos(u)+\cosh(v))^2 \\ |z+1| &=& \cosh(v)+\cos(u) \end{align} \] And similarly we can conclude: \[ |z-1| = \cosh(v)-\cos(u) \] Add the two equations to get: \[ |z+1|+|z-1| = 2\cosh(v) \\ \cosh(v)=\frac{|z+1|+|z-1|}{2} \] From \(x=\cos(u)\cosh(v)\) we conclude: \[ 2x=2\cos(u)\cosh(v) \\ \cos(u)=\frac{2x}{|z+1|+|z-1|} \] This leads to the following function: from math import sqrt, acos, acosh def arccos(z): x, y = z.real, z.imag y2 = y**2 U = sqrt((x+1)**2 + y2) V = sqrt((x-1)**2 + y2) W = (U+V)/2 u = acos(x/W) v = acosh(W) return u - 1j*v Let's compare this to the builtin function: >>> import cmath >>> z=3+4j >>> arccos(z) (0.9368124611557199-2.305509031243477j) >>> cmath.acos(z) (0.9368124611557198-2.305509031243477j) >>> z/=10 >>> arccos(z) (1.2901667645030908-0.40511233717803047j) >>> cmath.acos(z) (1.2901667645030908-0.4051123371780309j) >>> z/=10 >>> arccos(z) (1.5408158285382982-0.04000730997058477j) >>> cmath.acos(z) (1.5408158285382982-0.04000730997058378j) It appears we loose some accuracy when calculating \(v=acosh(W)\) for values of \(W\) close to 1. Why is that? (substitute \(t=e^v\)) \[ \begin{align} W &=& \cosh(v) \\ &=& \frac{e^v+e^{-v}}{2} \\ W &=& \frac{t+\frac{1}{t}}{2} \\ 2Wt &=& t^2+1 \\ t^2-2Wt+1 &=& 0 \\ t &=& W\pm\sqrt{W^2-1} \\ \end{align} \] Now we can see what's happening: when \(W\) is close to 1 we experience extinction and thus loss of accuracy. We'd like to calculate \(W-1\) without loosing digits. Can we do better? Let's see what the HP-48 suggests: * Q := y^2/(sqrt((|x|+1)^2 + y^2) + (|x|+1)) * R := sqrt((|x|-1)^2 + y^2) +||x|-1| * S := y^2/R if R<>0, 0 otherwise * M := Q+R if |x|>=1, Q+S otherwise * P := Q+S if |x|>=1, Q+R otherwise * B := 2*x/(M+2) * C := sqrt((P/(M+2))*(2-(P/(M+2)))) * sg(y,x) := sgn(y) if y<>0, -sgn(x) otherwise * IM := sg(y,x)*lnp1((M/2) + sqrt((M/2)*((M/2)+2))) (sign replacement) * * { arccos(B) |B| <= (1/sqrt(2)) * RE1 := { arcsin(C) |B| > (1/sqrt(2)) and B >= 0 * { pi - arcsin(C) |B| > (1/sqrt(2)) and B < 0 * * RE2 := { arcsin(B) |B| <= (1/sqrt(2)) * { sgn(B)*arccos(C) |B| > (1/sqrt(2)) (sign replacement) * I've taken the liberty to add some new variables: def sgn(x): return cmp(x, 0.0) def sg(y,x): return sgn(y) if y != 0 else -sgn(x) def inverse(z): x, y = z.real, z.imag _x_ = abs(x) y2 = y**2 U = sqrt((_x_+1)**2 + y2) T = U + (_x_+1) Q = y2/T # = U - (|x|+1) V = sqrt((_x_-1)**2 + y2) R = V + abs(_x_-1) S = y2/R if R != 0 else 0 # = V - ||x|-1| M = Q+R if _x_ >= 1 else Q+S # M = U + V - 2 P = Q+S if _x_ >= 1 else Q+R # P = U + V - 2|x| B = 2*x/(M+2) C = sqrt((P/(M+2))*(2-(P/(M+2)))) IM = sg(y,x)*log1p((M/2) + sqrt((M/2)*((M/2)+2))) # sign replacement _B_ = abs(B) sqrt_2 = 1/sqrt(2) RE1 = acos(B) if _B_ <= sqrt_2 else asin(C) if B >= 0 else pi - asin(C) RE2 = asin(B) if _B_ <= sqrt_2 else sgn(B)*acos(C) # sign replacement return IM, RE1, RE2 Please note that M/2 = W-1 since M = U+V-2. That's exactly the value we were looking for. Instead of ln we use lnp1 (or log1p in Python) for values close to 1: \[v=\ln(t)=lnp1(t-1)=lnp1(W-1\pm\sqrt{(W-1)(W+1)}\] Substitute W-1 by M/2 and we end up with the formula for IM. Well nearly, we still have to deal with the sign of the expression. Here's the SYSRPL code with stack-diagrams: :: ; z C%>%% ; x y 2DUP ; x y x y DUP ; x y x y y %%*SWAP ; x y y^2 x %%ABS ; x y y^2 |x| DUP ; x y y^2 |x| |x| %%1+ ; x y y^2 |x| |x|+1 DUPDUP ; x y y^2 |x| |x|+1 |x|+1 |x|+1 %%* ; x y y^2 |x| |x|+1 (|x|+1)^2 4PICK ; x y y^2 |x| |x|+1 (|x|+1)^2 y^2 %%+ ; x y y^2 |x| |x|+1 (|x|+1)^2+y^2 %%SQRT ; x y y^2 |x| |x|+1 √((|x|+1)^2+y^2) %%+ ; x y y^2 |x| √((|x|+1)^2+y^2)+(|x|+1) 3PICKSWAP ; x y y^2 |x| y^2 √((|x|+1)^2+y^2)+(|x|+1) %%/ ; x y y^2 |x| Q OVER ; x y y^2 |x| Q |x| %%1 ; x y y^2 |x| Q |x| 1 %%- ; x y y^2 |x| Q |x|-1 %%ABS ; x y y^2 |x| Q ||x|-1| DUPDUP ; x y y^2 |x| Q ||x|-1| ||x|-1| ||x|-1| %%* ; x y y^2 |x| Q ||x|-1| ||x|-1|^2 5PICK ; x y y^2 |x| Q ||x|-1| ||x|-1|^2 y^2 %%+ ; x y y^2 |x| Q ||x|-1| ||x|-1|^2+y^2 %%SQRT ; x y y^2 |x| Q ||x|-1| √(||x|-1|^2+y^2) %%+ ; x y y^2 |x| Q R 4ROLLOVER ; x y |x| Q R y^2 R DUP ; x y |x| Q R y^2 R R %%0<> ; x y |x| Q R y^2 R ITE ; x y |x| Q R y^2 R %%/ ; x y |x| Q R y^2/R :: ; x y |x| Q R y^2 R 2DROP ; x y |x| Q R %%0 ; x y |x| Q R 0 ; ; x y |x| Q R S UNROTOVER ; x y |x| S Q R Q %%+ ; x y |x| S Q R+Q UNROT ; x y |x| R+Q S Q %%+ ; x y |x| R+Q S+Q ROT ; x y R+Q S+Q |x| %%1 ; x y R+Q S+Q |x| 1 %%< ; x y R+Q S+Q ?SKIPSWAP ; x y P M DUP ; x y P M M %%2 ; x y P M M 2 %%+ ; x y P M M+2 ROTOVER ; x y M M+2 P M+2 %%/ ; x y M M+2 P/(M+2) %%2 ; x y M M+2 P/(M+2) 2 OVER ; x y M M+2 P/(M+2) 2 P/(M+2) %%- ; x y M M+2 P/(M+2) 2-P/(M+2) %%* ; x y M M+2 P/(M+2)*(2-P/(M+2)) %%SQRT ; x y M M+2 C 5PICK ; x y M M+2 C x DUP ; x y M M+2 C x x %%+ ; x y M M+2 C 2x ROT ; x y M C 2x M+2 %%/ ; x y M C B ROT ; x y C B M %%2 ; x y C B M 2 %%/ ; x y C B M/2 DUP ; x y C B M/2 M/2 %%2 ; x y C B M/2 M/2 2 %%+ ; x y C B M/2 M/2+2 OVER ; x y C B M/2 M/2+2 M/2 %%* ; x y C B M/2 (M/2+2)*M/2 %%SQRT ; x y C B M/2 √((M/2+2)*M/2) %%+ ; x y C B M/2+√((M/2+2)*M/2) %%lnp1 ; x y C B lnp1(M/2+√((M/2+2)*M/2)) 5ROLL ; y C B lnp1(M/2+√((M/2+2)*M/2)) x 5ROLL ; C B lnp1(M/2+√((M/2+2)*M/2)) x y DUP ; C B lnp1(M/2+√((M/2+2)*M/2)) x y y %%0= ; C B lnp1(M/2+√((M/2+2)*M/2)) x y ITE ; C B lnp1(M/2+√((M/2+2)*M/2)) x y :: ; C B lnp1(M/2+√((M/2+2)*M/2)) x y DROP ; C B lnp1(M/2+√((M/2+2)*M/2)) x %%0< ; C B lnp1(M/2+√((M/2+2)*M/2)) ; ; C B lnp1(M/2+√((M/2+2)*M/2)) :: ; C B lnp1(M/2+√((M/2+2)*M/2)) x y SWAPDROP ; C B lnp1(M/2+√((M/2+2)*M/2)) y %%0>= ; C B lnp1(M/2+√((M/2+2)*M/2)) ; ; C B lnp1(M/2+√((M/2+2)*M/2)) ?SKIP ; C B lnp1(M/2+√((M/2+2)*M/2)) %%CHS ; C B sg(y,x)*lnp1(M/2+√((M/2+2)*M/2)) UNROTDUP ; IM C B B %%ABS ; IM C B |B| %%.7 ; IM C B |B| .7 %%<= ; IM C B case ; IM C B :: ; IM C B SWAPDROPDUP ; IM B B %%ACOSRAD ; IM B RE1 SWAP ; IM RE1 B %%ASINRAD ; IM RE1 RE2 ; ; IM RE1 RE2 SWAPDUP ; IM B C C %%ASINRAD ; IM B C arcsin(C) SWAP ; IM B arcsin(C) C %%ACOSRAD ; IM B arcsin(C) arccos(C) %%ABS ; IM B arcsin(C) |arccos(C)| ROT ; IM arcsin(C) |arccos(C)| B %%0>= ; IM arcsin(C) |arccos(C)| ?SEMI ; IM RE1 RE2 %%CHS ; IM arcsin(C) -|arccos(C)| %%PI ; IM arcsin(C) RE2 pi ROT ; IM RE2 pi arcsin(C) %%- ; IM RE2 pi-arcsin(C) SWAP ; IM RE1 RE2 ; ; IM RE1 RE2 This article was initiated by a thread in the old forum where Cyrille asked a question concerning the implementation of the complex inverse trigonometric functions. |
