Multinomial coefficient
02-15-2015, 11:59 AM (This post was last modified: 02-15-2015 05:49 PM by salvomic.)
hi all,
I would write a little program to calculate "multinomial coefficient" (see here), as I cannot find it in the Prime's command list...
So, I need to input n (total number of objects) and a list of groups items (k_i) which sum is n.
Any hints to control user's input?
For now I tried this wrong program:
EXPORT Multinomial()
BEGIN
local n, k, x, list, multi;
input ({n, {k}}, "Multinomial Coefficient", {"n", "k_i list"}, {"Total n", "input {k_i list} with comma"}, {0,0});
list := apply(x-> x!, k);
multi := n!/∏LIST(list);
return multi;
END;
but this code give "Error: Bad argument type". More: the user must insert {} in the input (i.e. {1,4,4,2}) for the list.
Any hints to give user the possibility to input list without brackets?
About that, generally speaking, how to insert in Windows with HP Connectivity Kit, ∏LIST(), ∑LIST, ∆LIST? Connectivity Kit should have a way to insert special characters easily...
Also with the arrow -> used in apply(), map() and others commands: I insert it via shift-9 list but I get syntax error: I'm wrong, why?...
Thank you for help!
Salvo
02-15-2015, 05:48 PM
RE: Multinomial coefficient
ok,
after some tries, I simplified all with this:
BEGIN
local n,k;
// we need integers (also for list)
n:=IP(n); k:=IP(k);
return n!/∏List(k!);
END;
This program accept an integer for "n" and a list with {} for the list of k (like {1,4,4,2}) and give a integer that represent permutations in a multi set...
There are some (ugly) problems:
1. a way to avoid user to input also the {} for the list (it would better to have only something like 1,4,4,2)
2. a control because the sum of k must be equal to n
Any hints are welcome!
02-15-2015, 07:44 PM
I would recommend not to use input, but pass arguments to your function.
FYI, there is a multinomial command in Xcas for probability, it has an additional 2nd argument, the list of probabilities. It would perhaps be interesting to include in the Prime.
02-15-2015, 08:20 PM
(02-15-2015 07:44 PM)parisse Wrote:  I would recommend not to use input, but pass arguments to your function.
ok, I'll try to re-write the program without input, in effects...
Yes, it would be interesting to include multinomial in the Prime, I hope the Team would seriously consider the idea to do that!
About combinatorics, in the CAS there are also functions for combination with repetition and permutation with repetition?
I defined to function to have them in the Prime (simply -> comb(x+k-1,k) and x^k)...
I'm thinking also to write something to treat Stirling numbers.
02-15-2015, 09:25 PM (This post was last modified: 02-21-2015 11:17 AM by salvomic.)
And then (thank you Parisse for hint), the version without input.
Use: multinom(n,{list of k_i})
#cas
multinom(args):=
// Multinomial by Salvo M. multinom(n,{list k_i})
BEGIN
local n, k, argv,argc;
argv:=[args];
argc:=size(argv);
IF argc !=2 THEN
return "Input: integer n, {list k}";
ELSE
n:=argv(1);
k:=argv(2);
IF (type(k) != DOM_LIST) THEN return "Second argument must be a list"; ELSE
// controllo interi
 n:= ip(n); k:= ip(k);
 return  n!/∏LIST(k!);
END; // if inner
END; // if out
END;
#end
The program has a control if user doesn't input 2 arguments (no more, no less), if the second argument is not a list and rounds both arguments, to get integers.
Caveat: with this version (#cas program) integer part command -ip()- must be lowercase or ip(k) doesn't works for the list giving wrong results (I wonder why...)
Enjoy and please suggest improvements
