IP and CAS
02-15-2015, 10:21 PM (This post was last modified: 02-15-2015 10:22 PM by salvomic.)
IP and CAS
hi all,
perhaps it has been already written (but I haven't found in the forum) or it will be corrected in the next firmware upgrade: IP() command in CAS doesn't works with the list if is written in upper case.
IP({1,5.5,6.8}) gives -> when({1,5.5,6.8}>=0,{1,5,6},{1,6,7})
ip({1,5.5,6.8}) gives correctly {1,5,6}
No problem in Home, both lower and upper case, and no problem in CAS with reals.
02-16-2015, 07:17 AM
RE: IP and CAS
Indeed, fixed in source.
02-16-2015, 09:38 AM
RE: IP and CAS
(02-16-2015 07:17 AM)parisse Wrote:  Indeed, fixed in source.
very well!
thanks
