Get "de-string" an expression
03-09-2015, 01:11 PM
(This post was last modified: 03-09-2015 01:22 PM by Angus.)
When given a String like "#AAh". How can that be changed to an integer constant #AAh?
I had in mind that CAS(String) is a way to convert a String to its (cas)meaning. Is that right? And why would that not work in the given example. Please also look at the code: Code: EXPORT INT_HEX(X) edit: remembering Han's tutorial about cas programs I tried locally assigning str:="#"+X+"h"; CAS(str); which SEEMS to work better, but apparently always leads to everything but the desired result.... dec semms to be preferred. Can someone help with the functionality I am looking for? |
03-09-2015, 01:24 PM
RE: Get "de-string" an expression
That works. But I do not understand what CAS() is doing to integers. |
03-09-2015, 01:56 PM
R→B(approx("#AAh")); // Who would have thought?
03-09-2015, 02:02 PM
Cool to see an other working solution! Thank you.
However is using approx() so obvious that I should sense cynicism in your comment? I am not sure. |
03-09-2015, 02:17 PM
No cynicism intended, although I see your thinking on my poor phrasing! It's just that I tried various tools, while scanning through the catalog, and happened to land on "approx()." I never would have guessed that to be a viable solution! Damn good thing it wasn't Zapprox, or I would've been here until the next blue moon, whenever that is!
-Dale- |
03-09-2015, 02:38 PM
(This post was last modified: 03-09-2015 02:38 PM by Angus.)
How would you classify your solution? Is it intended or logical behaviour or is it just working out of luck? Or to put it in other words? How high of a risk do you see to be confronted with non working code after a future firmware update?
The cleanest solution is the best solution. What could it be. |
03-09-2015, 05:11 PM
is EXPR what you are looking for? Cyrille |
03-10-2015, 05:47 AM
Best solution I would say :-) Thank you
