Announce: HP-15C Simulator / Release 3.3.00, Build 5403
01-19-2014, 09:19 PM
I am pleased to announce a new version of my HP-15C Simulator for Windows, Linux and Mac OS X: Release 3.3.00, Build 5403.
[Image: HP-15C.png]
It can be downloaded from the simulator home page.
01-19-2014, 10:00 PM
RE: Announce: HP-15C Simulator / Release 3.3.00, Build 5403
Thank you for the new version. Excellent work!
Namir
01-19-2014, 11:28 PM (This post was last modified: 01-19-2014 11:51 PM by Jeff_Kearns.)
Torsten,
Great simulator indeed. I do have a question regarding internal accuracy of calculations. When I run the example in the TVM program, I get the following:
Torsten HP-15C Simulator: 333,783.2505
Official HP-15C Emulator: 333,783.3508
Real HP-15C and HP-15 LE: 333,783.3508
Swiss Micro DM-15: 333,783.3508
Correct answer: 333,783.349948 (HP-30b, HP-19BII and HP-17BII)
What do you believe causes this discrepancy? Can it be identified and addressed in a subsequent release? I actually prefer the interface of your simulator over the official emulator (even if it is a bit slower).
Jeff
01-20-2014, 10:27 AM
Mike,
My point is that the simulator is 'incorrect' by $0.10.
Jeff
01-20-2014, 09:15 PM
Great tool and nice listings! Thank you very much!
# HEWLETT·PACKARD 15C Simulator program
# Created with version 3.3.00
   000 {             }
   001 {    42 21 11 } f LBL A
   002 {       43 11 } g x²
   003 {       43 36 } g LSTx
   004 {          40 } +
   005 {           2 } 2
   006 {          10 } ÷
   007 {       43 32 } g RTN
01-20-2014, 09:19 PM
Jeff,
I can not confirm your result of 333.783,2505 for my simulator.
I have tested it on Windows 7 64bit and XP 32bit. In both cases, I got the "correct" result of 333.783,3499484285. The simulator uses the full 17 digits available in IEEE format.
If "Strict HP-15C behaviour" is checked in the "Preferences", the result is the same as with the hardware models: 333.783,3508. In "strict mode", the precision is reduced to the 10 digits of the emulators using a copy of the original ROM.
Torsten
01-20-2014, 09:24 PM
(01-20-2014 09:15 PM)Gerson W. Barbosa Wrote:  Great tool and nice listings! Thank you very much!
Did you see the HTML export? It's even nicer ;-)
Torsten
01-20-2014, 10:17 PM
Torsten
Indeed!
[Image: Gauss_HP-15C_zpsec34727a.png]
And that's only the listing! Thanks again!
Gerson.
01-20-2014, 11:07 PM (This post was last modified: 01-20-2014 11:13 PM by Jeff_Kearns.)
(01-20-2014 09:19 PM)Torsten Wrote:  I can not confirm your result of 333.783,2505 for my simulator.
Torsten:
Thanks for your reply. I re-checked the program listing and it was accurate. I checked the "Strict HP-15C behaviour" and still it gave the same result: 333.783,2505. I was (or so I thought) meticulous in conducting the test the first time.
Then I verified the storage registers and 0.089633601 instead of '0' was found in register 3. I saved 0 in register 3 and it then gave the correct result. I will assume that I erred and I apologize for raising any concerns about your excellent simulator. It is a very impressive piece of work indeed. Not only that, it is even more accurate (in that it more closely matches the results of the financial calculators) when the "Strict HP-15C behaviour" is left unchecked.
Jeff
01-21-2014, 04:09 AM
(01-20-2014 09:24 PM)Torsten Wrote:  Did you see the HTML export? It's even nicer ;-)
Torsten
Is it me, or RollUp icon in HTML has rectangle after 'R' rather than an up arrow?
Great job otherwise, cheers!
01-21-2014, 10:42 AM
Quote:Is it me, or RollUp icon in HTML has rectangle after 'R' rather than an up arrow?
This is a font issue. You do not have a font on your system, that has the character. I recommend to install the DejaVu Fonts. There are more details in the simulator help files under "Usage | Preferences | Font Settings".
Torsten
01-22-2014, 12:23 AM
(01-21-2014 10:42 AM)Torsten Wrote:  This is a font issue. You do not have a font on your system, that has the character. I recommend to install the DejaVu Fonts.
Torsten
Thanks a lot, it all works perfectly now.
Cheers,
01-23-2014, 03:23 PM
Torsten,
I finally got a chance to spend some time using the simulator. Great work! Thank you.
"Science is a wonderful thing if one does not have to earn one's living at it." -- Albert Einstein
01-24-2014, 05:35 AM (This post was last modified: 01-24-2014 10:04 AM by RMollov.)
Solver problem.
Corrected after Walter's findings.
EQN:
R*( TAN (ACOS (R/(R+h))) - ACOS(R/(R+h)) ) - dL/2 = 0
R= 6,371,000m (stored in register .0)
dL=1m (stored in register 0)
h=?
   000 {             }
   002 { 45 40 48  0 } RCL ✛ .0
   003 { 45 10 48  0 } RCL ÷ .0
   004 {          15 } 1/x
   005 {       43 24 } g COS-¹
   006 {          25 } TAN
   007 {       43 36 } g LSTx
   008 {          30 } −
   009 { 45 20 48  0 } RCL ✕ .0
   010 {    45 30  0 } RCL − 0
   011 {       43 32 } g RTN
RAD mode
Initial Guesses: 0, 1
Solve 'A' ->
Returns solver error unlike all HP calculators I have.
I realize this simulator uses different algorithm but never the less.
WP-34s also struggles at this.
I'm wondering if I'm doing something wrong.
I found interesting differences in answers given by: HP48G, HP35s and HP15c LE - real calculators and simulators: iPhone's 42S and Free15c. They all solve the case.
01-24-2014, 08:22 AM
(01-24-2014 05:35 AM)RMollov Wrote:  Solver problem.
EQN:
R(TAN (ACOS (R/(R+h)) - ACOS(R/(R+h))) - dL/2 = 0
R= 6,371,000m
dL=1m
h=?
RAD mode
BTW WP-34s also struggles at this.
I'm wandering if I'm doing something wrong.
I'm wondering if your EQN is wrong. I can simplify it to R(0) - dL/2 = 0 which doesn't include h anymore. Undecided
01-24-2014, 09:50 AM (This post was last modified: 01-24-2014 09:53 AM by RMollov.)
(01-24-2014 08:22 AM)walter b Wrote:  I'm wondering if your EQN is wrong. I can simplify it to R(0) - dL/2 = 0 which doesn't include h anymore. Undecided
You're always correct, thank you for correcting my typos.
It should be:
R*( TAN(ACOS (R/(R+h))) - ACOS(R/(R+h)) ) - dL/2 = 0
Did I count the brackets properly this time?
I'll correct my original post accordingly.
The HP15c listing above is right though.
Shall I post the WP34s version, which also doesn't seem to work? Wink
01-24-2014, 12:10 PM
(01-24-2014 09:50 AM)RMollov Wrote:  Shall I post the WP34s version, which also doesn't seem to work? Wink
Feel free to do so.
d:-)
01-24-2014, 07:15 PM
Very nice. Runs over 50 times faster on my Linux based computer than the HP-15C LE.
01-24-2014, 07:21 PM
Hello RMollov,
which kind of problem do you describe?
h=?
The value of R looks like the earth radius for me. And as a not very well scaled problem.
Greetings
peacecalc
01-25-2014, 03:29 AM
h=?
In register 0 the value dL/2 = 0.5 should be stored.
Quote:The value of R looks like the earth radius for me. And as a not very well scaled problem.
I guess it's the solution to a rope around the earth problem:
Take 3 of Sweet & Short Math Challenges #15: April 1st Spring Special
