Stack Overflow Sensing (or: make your own Red Dot!)
04-16-2015, 11:08 PM
(This post was last modified: 04-16-2015 11:14 PM by hansklav.)
Inspired by the proposal of John A. Ball in his book ‘Algorithms for RPN Calculators’, as a proof of concept I implemented a stack overflow sensing (SOS) scheme using Neil Fraser's JavaScript HP-35 simulator.
In the process I made my own ‘Red Dot’ HP-35 calculator ;-) Have a look here and see for yourself if HP missed a chance to build SOS into its very first pocket calculator (and, incidentally, into all its subsequent classical RPN models). Hans P.S.: I discovered a small inaccuracy in the functioning of the π-key of the original HP-35 simulator and corrected it in the HP-35 SOS. |
04-18-2015, 10:25 AM
(This post was last modified: 04-18-2015 01:20 PM by PANAMATIK.)
RE: Stack Overflow Sensing (or: make your own Red Dot!)
(04-16-2015 11:08 PM)hansklav Wrote: Inspired by the proposal of John A. Ball in his book ‘Algorithms for RPN Calculators’, as a proof of concept I implemented a stack overflow sensing (SOS) scheme using Neil Fraser's JavaScript HP-35 simulator. This is interesting. As I understood you made patches of the original HP-35 firmware. Do you think it could be possible to make further changes like adding new functions, making the HP-35 a programmable calculator, or write a compiler for ACT firmware? Bernhard That's one small step for a man - one giant leap for mankind. |
04-18-2015, 02:26 PM
(04-18-2015 10:25 AM)PANAMATIK Wrote: As I understood you made patches of the original HP-35 firmware. From Neil Fraser's HP-35 RPN Calculator Quote:Since they did not have a simulator for the HP-35, I wrote one in JavaScript for them. The result is a very faithful simulation with the exception of some rounding errors. Cheers Thomas |
04-18-2015, 03:55 PM
(This post was last modified: 04-18-2015 03:55 PM by PANAMATIK.)
Thanks Thomas for clarifying this.
As I understand now, this HP-35 simulator does not emulate the original HP-35 firmware. Bernhard That's one small step for a man - one giant leap for mankind. |
04-18-2015, 10:56 PM
(04-18-2015 03:55 PM)PANAMATIK Wrote: As I understand now, this HP-35 simulator does not emulate the original HP-35 firmware. You’re quite right: Neil Fraser’s JavaScript HP-35 simulator doesn’t emulate the HP-35 firmware but it does emulate its external behaviour. My modification of it (the ‘HP-35 SOS’) adds one feature, Stack Overflow Sensing (SOS) to show how this could work out for the user of a classical RPN calculator. You can download the source code (or simply study it from within your webbrowser); I documented all the added/modified lines. Hans |
