EDITLIST in CAS program
05-18-2015, 08:01 PM
I'm trying EDITLIST in a #CAS program and it seems not to edit a list.
The line EDITLIST(flows); works well in a Home program, but has no effect in a #CAS/#end program. Am I wrong? Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
05-20-2015, 05:48 AM
RE: EDITLIST in CAS program
(05-18-2015 08:01 PM)salvomic Wrote: I'm trying EDITLIST in a #CAS program and it seems not to edit a list. It returns the correctly edited list (to the history stack) as its output, but in CAS it fails to automatically store that result back into the named list. So in a CAS program, you'll have to use this apparently redundant syntax: L1:=EDITLIST(L1). At least until that bug is fixed. <0|ɸ|0> -Joe- |
05-20-2015, 07:01 AM
(05-20-2015 05:48 AM)Joe Horn Wrote: ... thank you! I'll try this, then, until the bug will be corrected. Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
10-11-2015, 07:43 AM
(This post was last modified: 10-11-2015 08:05 AM by StephenG1CMZ.)
Actually, I wonder whether that should be a bug?
Using L1 := EDITLIST(L1) Looks like a useful syntax for those times you want to edit a list and keep the original: L2 := EDITLIST(L1) If EDITLIST (L1) always changes L1, that last line would make L2 = L1 = edited Whereas L2 = edited L1 =Original Would be it's obvious meaning without looking up EDITLIST's spec. So for readability of the source code, I would suggest EDITLIST should not automatically edit the list given as a parameter, though if no destination list is specified it should default to doing so). A potential downside is that that might be less efficient, but it avoids L2:=EDITLIST(L1) editing L1 when you might not expect it to. If doing this is considered too wasteful given that on many occasions you will be editing back to the same list, I would suggest EDITLIST should not be assignable - the corresponding code then becoming: EDITLIST (L1); // no L2 makes it clear what is being edited Or L2:=L1; //keep original EDITLIST (L2); // change copy L2:=EDITLIST (L1) // could give syntax error to avoid confusion I would also like to suggest EDITLIST should have an optional READONLY parameter (alternatively: a VIEWLIST command) for those times when you want to browse a list without changing it. See for example how I use it in Version 0.3 of my Z EDITOR (select Searchall then View, and see how awkward the editing can look before my program implements search-and-replace). Having a readonly setting would be much neater. Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
