HP 82985A video interface/Hp 110 PLUS
06-10-2015, 05:42 AM
what HP cable (or TYPE OF CABLE) CONNECTS BETWEEN THE hp 82985a VIDEO INTERFACE BOX AND INTO THE hp 110 PLUS computer that has been modified to accept the CABLE ?
06-10-2015, 03:24 PM
(This post was last modified: 06-10-2015 05:08 PM by Dave Frederickson.)
RE: HP 82985A video interface/Hp 110 PLUS
(06-10-2015 05:42 AM)Richard B. Kaiser Wrote: what HP cable (or TYPE OF CABLE) CONNECTS BETWEEN THE hp 82985a VIDEO INTERFACE BOX AND INTO THE hp 110 PLUS computer that has been modified to accept the CABLE ? I was researching this a while back. The best I could come up with is some sort of modular cable, similar to an HP-HIL cable, except with 8 pins. From the Portable PLUS Service Manual: 5.19.3 Video Interface The HP 82985A Video Interface provides a connection for duplicating the computer display on an external monitor. The video interface consists of a modified battery door for the computer that connects to the motherboard PCA in the computer, a video cable that connects to the the battery-door connector, a separate interface module that connects to the video cable, and a monitor cable that connects the interface module to a monitor. An ac adapter provides power to the interface module. A description of the interface and complete service information are contained in the HP 82985A Video Interface Assembly-Level Service Manual (part number 82985-90003). Perhaps the service manual provides a part number. Page 5 of this document gives the part number of the replacement receptacle panel. After further research, this looks close: http://au.rs-online.com/web/p/telecom-co...s/7199435/ Dave |
06-11-2015, 12:38 AM
(06-10-2015 03:24 PM)Dave Frederickson Wrote:Thanks, for your exacting research and right on the nail head. This PM, I found my ca 12" flat cable. No part numbers were displayed. Yes, eight (8) pins. wires. all the gold (?) plated pins are openly exposed on the underside of each male end receptacle. which has a staggard block tee shape. I got it plugged in to the video interface device and in a matter of seconds was able to stream DATA from my HP110 + on to an HP 82985A 9-inch monitor. (which has been sold and will be sent to Deutschland. Thanks, Dave. Much appreciated !@(06-10-2015 05:42 AM)Richard B. Kaiser Wrote: what HP cable (or TYPE OF CABLE) CONNECTS BETWEEN THE hp 82985a VIDEO INTERFACE BOX AND INTO THE hp 110 PLUS computer that has been modified to accept the CABLE ? |
06-11-2015, 01:22 AM
(06-11-2015 12:38 AM)Richard B. Kaiser Wrote: Thanks, for your exacting research and right on the nail head. This PM, I found my ca 12" flat cable. No part numbers were displayed. Yes, eight (8) pins. wires. all the gold (?) plated pins are openly exposed on the underside of each male end receptacle. which has a staggard block tee shape. I got it plugged in to the video interface device and in a matter of seconds was able to stream DATA from my HP110 + on to an HP 82985A 9-inch monitor. (which has been sold and will be sent to Deutschland. Thanks, Dave. Much appreciated !@ Very cool. I'd like to see pics when it's all together. Any part numbers on the cable plugs? I'm curious if they're SDL plugs in case I need to make a cable one day. Dave |
07-02-2015, 09:55 AM
There are variants for flat cable as well as round cables.
Not sure whether these are a match: round cable: http://uk.rs-online.com/web/p/products/7199447/ http://uk.rs-online.com/web/p/telecom-co...s/7199447/ flat cable: http://uk.rs-online.com/web/p/products/7199444/ http://uk.farnell.com/te-connectivity-am...dp/1284391 Martin |
