HAngle in FW 7820
06-14-2015, 10:39 PM
HAngle in FW 7820
hi,
I'm trying a program by Eddie (Solar, here) but my Prime doesn't execute the line
HAngle:= 1;
What's about?
Salvo
06-15-2015, 02:16 AM (This post was last modified: 06-15-2015 02:17 AM by kharpster.)
RE: HAngle in FW 7820
The "command' executes on the command line. Are you running the program in Home mode? The help text defines the variable as a Home Setting Variable.
06-15-2015, 07:37 AM
(06-15-2015 02:16 AM)kharpster Wrote:  The "command' executes on the command line. Are you running the program in Home mode? The help text defines the variable as a Home Setting Variable.
I'm trying in CAS and in Home, same result...
I'm using the example in the blog of Eddie: if I change first the angle mode manually it returns the same numbers, otherwise no.
Salvo
06-15-2015, 07:51 AM (This post was last modified: 06-15-2015 07:56 AM by DrD.)
There are some conflicting descriptions in the User Guide for HAngle settings. Some places state HAngle:=0 sets degree mode, and other places have it as setting radian mode.
The help description has it right:
:=0 for Radians (default)
:=1 for Degrees
(Programmatically; or via the command line, when in HOME view.)
06-15-2015, 07:56 AM
(06-15-2015 07:51 AM)DrD Wrote:  There are some conflicting descriptions in the User Guide for HAngle settings. Some places state HAngle:=0 sets degree mode, and other places have it as setting radian mode.
:=1 for Degrees
(Programmatically or via the command line, when in HOME view.)
in fact...
However HAngle:=0 in CAS gives error, :=1 no, but doesn't change (also in Home), here...
Maybe a setting wrong by me?
Salvo
06-15-2015, 08:03 AM (This post was last modified: 06-15-2015 08:04 AM by DrD.)
In HOME view (via command line):
HAngle:=0; // results in a green "∡π" display in upper right corner of display
HAngle:=1; // results in a green "∡°" display in upper right corner of display
06-15-2015, 08:05 AM (This post was last modified: 06-15-2015 08:08 AM by salvomic.)
(06-15-2015 08:03 AM)DrD Wrote:  In HOME view (via command line):
not by me: only the "π" symbol...
but... found a thing!
I wa in "Statistic 1 var": it depends on Application...
With "Function" activated it works.
06-15-2015, 08:13 AM
If the Title bar shows CAS, HAngle doesn't work, and the spelling of the home var has the first two characters capitalized. If these settings aren't the problem, I have no further idea why it wouldn't work.
It works on my calcs and emulator here, and for revs back to 6975.
06-15-2015, 08:16 AM (This post was last modified: 06-15-2015 08:17 AM by DrD.)
I just checked it on my equipment and it works fine in Statistics 1Var. So your instance is different than what I see here. Is your case repeatable? Is it on the emulator or on the calc or both?
06-15-2015, 08:16 AM (This post was last modified: 06-15-2015 08:20 AM by salvomic.)
(06-15-2015 08:13 AM)DrD Wrote:  If the Title bar shows CAS, HAngle doesn't work, and the spelling of the home var has the first two characters capitalized. If these settings aren't the problem, I have no further idea why it wouldn't work.
yes, it doesn't work in CAS, and do depend by active Application.
Here: if Function is active ok (Home), if Statistic then don't...
EDIT: found!
In Statistic 1 var by me, in Symb setup there was Angle measure set to "Radians"..., now I put it "System" and HAngle seems to work!
Thank you Dale!
06-15-2015, 08:21 AM
I have checked that on my calc (rev C) and the emulator, and HAngle works as expected.
06-15-2015, 08:23 AM
Ok, that makes sense, now. It's hard to isolate these things with so many system settings, but necessary, I guess. We need a background program to keep our house in order...hi!
06-15-2015, 08:28 AM
(06-15-2015 08:23 AM)DrD Wrote:  It's hard to isolate these things with so many system settings, but necessary, I guess. We need a background program to keep our house in order...hi!
yes, I agree :-)
06-15-2015, 11:22 AM
If this was already pointed out, forgive the repeat, but the problem is that the VALUES of HAngle and HFormat are different in CAS than they are in Home.
In CAS, HAngle is 0 or 1, but in CAS, it's 1 or 2.
Radian mode: HAngle=0 in Home, 1 in CAS.
Degree mode: HAngle=1 in Home, 2 in CAS.
Similarly, HFormat is 0 through 5, but in CAS, it's 1 through 6.
Standard mode: HFormat=0 in Home, 1 in CAS.
Etc.
HAngle and HFormat are the only system variables that exhibit this buggy offset. They have done this since the beginning of time. The documentation applies only to their Home values, not their CAS values. Beware when writing CAS programs or using them in User-Defined Functions from CAS.
<0|ɸ|0>
-Joe-
06-15-2015, 11:28 AM
(06-15-2015 11:22 AM)Joe Horn Wrote:  ...
yes Joe, indeed.
However, in my case (a program with that setting) the problem was that (I don't know why) in Statistic 1 var I had the setting for Angle set as "Radiant": putting it "System" now it runs well also in CAS (from the program)...
I hope that offset could be deleted, if it's possible...
06-15-2015, 12:39 PM (This post was last modified: 06-15-2015 12:39 PM by compsystems.)
a flag is needed to change the mode of simplification, none, minimum, máximum
This flag is useful?
06-15-2015, 03:11 PM
(06-15-2015 12:39 PM)compsystems Wrote:  a flag is needed to change the mode of simplification, none, minimum, máximum
YES, making that setting programmable would be VERY useful! Also hugely useful would be a programmable flag for the "Change apparent integers into exact integers" CAS setting, which currently makes some CAS functions fail in Home programs when it's turned off. It's annoying to have to check that setting manually, when programs should be able to take care of it automatically.
In general, ALL user-settable options should be programmable. Seems relatively intuitively obvious, no?
<0|ɸ|0>
-Joe-
06-16-2015, 08:48 AM
Forgive my ignorance but wouldn't AAngle be a better option ?, works for me in 7820.
06-16-2015, 02:03 PM
(06-16-2015 08:48 AM)Digitaldreams Wrote:  Forgive my ignorance but wouldn't AAngle be a better option ?, works for me in 7820.
I think you're right. AAngle always trumps HAngle, so programs should (a) save AAngle in a temp var, (b) set AAngle as needed, then (c) restore it from the temp var before exiting. That way the program will handle angles as intended, and the user's current app setting will be respected. HAngle can be ignored.
<0|ɸ|0>
-Joe-
06-16-2015, 03:07 PM
Help says:
If AAngle ==0, then use Home View Setting (HAngle can be either 0 or 1, controlling the radian/degree mode).
IF AAngle ==1, then in the specific App in view, the angle mode is radian.
If AAngle == 2, then in the specific App in view, the angle mode is degree.
-Dale-
