what does RESET do on prime
10-17-2015, 11:14 AM
(This post was last modified: 10-24-2015 07:01 PM by ji3m.)
On android prime reset is in the slide in menu.
Here's whst it does: 1. It saves the app I added 2. It deletes all programs 3. It deletes all notes 4. It deletes all AFiles I created So it saves the app. Might as well do a reinstall for a cleaner restart. I tried turning the app off before reset since I have no clue about when things are actually saved. This did not help. I got the impression somewhere that at least AFiles would be saved (to "disc"). Nada. Spontanious crashes lose some things but not as much. I work with android Prime only for now on my Galaxy Tab Pro/Note 2 |
10-19-2015, 03:13 PM
RE: what does RESET do on prime
Should be doing the same thing it does everywhere else - wipe all data from disk and ram (with the exception of your language settings, theme, and calculator name) and then restart.
10-20-2015, 01:01 AM
Wow.
So its a hard factory reset with some minor exceptions. This is what it does after some crashes. Is there a "soft reset"? I work with android Prime only for now on my Galaxy Tab Pro/Note 2 |
10-22-2015, 03:11 PM
(This post was last modified: 10-22-2015 03:17 PM by Spybot.)
I was wondering if I backup my Prime(let's say it is running FW 7820), then I update to FW 8151. after that... I restore my calc using the 7820 back up I made. what firmware will I end up with? 7820 or 8151? Spybot. |
10-22-2015, 04:38 PM
The restore is only files - not the firmware on the device. 8151
10-23-2015, 11:59 PM
Thank you Tim! it's good to know.
Spybot. |
