RETURN instruction
02-18-2016, 04:35 PM (This post was last modified: 02-18-2016 05:19 PM by compsystems.)
RETURN instruction
in all the languages I've programmed the RETURN instruction end the function
Why not the case in the language of hpprime?
#cas
prg1(x,y):=
BEGIN
  a:=seq(x^2,x,1,3);
  return a;
   √(x^2+Y^2);
END;
#end
prg1(3,4) [ENTER] => [1,4,9] OK & not 5
02-18-2016, 05:02 PM
RE: RETURN instruction
This is a bug. In the meantime, use RETURN instead of return.
Graph 3D | QPI | SolveSys
02-18-2016, 05:07 PM
(02-18-2016 05:02 PM)Han Wrote:  This is a bug. In the meantime, use RETURN instead of return.
reserved words, should not be sensitive to case-sensitive, this is a bad programming practice, do not know when to use each instruction
I recommend that this form reconsider the firmware and only operate with out case sensitive
Do you agree?
+1
02-19-2016, 01:31 PM
Yes, but there are some commands where one is for CAS and the other for HOME environet. They are distinguishable by lower/uppercase.
