Positive infinity symbol mutates in a +/- infinity within integral (gamma function)
02-16-2014, 12:13 PM
I'm playing with CAS.
I tried to calculate the gamma function using my own definition (not the internal one). g(x):=int(e^(-t)*t^(x-1),t,0,+infinity) The CAS convert the +infinity to a +/-infinity. When you try to calculate the function using an integer value you obtain the right result: g(5) gives 24 When you try to calculate the gamma for a rational number or a decimal you obtain this symbolic result: g(5+1/3) gives int(t^5*e^(-t)/(t^(1/3))²,t,0,+/-infinity) You can note that +infinity mutates in +/-infinity. Why? Massimo from 34c to prime |
02-16-2014, 08:03 PM
RE: Positive infinity symbol mutates in a +/- infinity within integral (gamma function)
Doesn't happen to me.
define in CAS g(t):=int(x^(t-1)*exp(-x),x,0,inf) g(5)=24 OK g(5+1/3)=int((3*x^4*x*e(-x))/3*(x^1/3)^(-2),x,0,inf) Note: No change to +/-inf approx(Ans)=40.1289... OK |
02-16-2014, 09:43 PM
02-17-2014, 12:22 AM
So do I.
02-17-2014, 06:28 AM
(This post was last modified: 02-17-2014 06:38 AM by massimo.)
On my calc or emulator, the problem appears when you set the Simplify settings in CAS to Minimum.
If you set it to None or Maximum the behavior is as expected. BTW I set it to None and tried to obtain the same "error" by hand but I have not obtained any success so far. Massimo from 34c to prime |
02-17-2014, 10:53 AM
The expand function changes +infinity in -/+infinity:
expand(int(t^x*e^(-t),t,0,+infinity)) gives int(t^x*e^(-t),t,0,+/-infinity) Massimo from 34c to prime |
