NP-41 Emulator (may be)
03-03-2016, 01:28 PM
Post: #161
RE: NP-41 Emulator (may be)
I *really* want to get one of these, with the case and keyboard.
Any idea when you might be taking orders?
Thanks,
smp
03-03-2016, 05:27 PM
Post: #162
(03-01-2016 02:26 PM)rprosperi Wrote:  Can you guess about when these will be available, and also will it be possible/straightforward to update the firmware, e.g. via USB?
(03-01-2016 04:23 PM)Massimo Gnerucci Wrote:  Gimme, gimme, gimme one (at least!)... Smile
(03-03-2016 01:28 PM)smp Wrote:  Any idea when you might be taking orders?
I didn't plan to sell the 14-segment version. The build is difficult and time consuming. The fact that I need to direct drive segment-by-segment the LCD glass make the hand soldering quite challenging. Many times I have to re-work / re-flow to get things right. Let alone the fact that I had messed up two builts.
I had a few (< 10) custom LCDs left, likewise I had may be 6 or 7 PCBs (both head and keyboard unit). If you think you had good skills and really like one of these, I can assemble a few kits (i.e. all the parts needed). You will, however purchase an appropriate TI launchpad and use it as a programmer. This will allow you to load the firmware and update / change it in the future.
Also the PCBs had bugs (you can see them on the photo I uploaded) and require 2 jumps.
My focus remains on the smaller NP-41S, where I am focusing to turn it into a kit / assembled kit. The built is a lot easier (and way quicker) and it should be more reliable. Please wait for the next version which hopefully will be the kit version. I think if everything goes well, I will received my boards in 2 weeks time, and another week to built it. So after a month I may be able to offer up to 4 kits / builts for early adopters. I had only ordered 4 LCD modules this time. I also recommend to get this launchpad as programmer, the firmware is still work-on-progress, but already fun to play w/.
Currently, the way I load ROM modules is to compile them into the firmware. I am working on a UART loading mechanism. It will most likely require a terminal program like putty, realterm or something similar. This will also be a WIP for the NP-41S, as I will also be experimenting serial ROM to expand it's capability.
Once a NP-41S becomes stable, we may want to evaluate again the feasibility of the 14-segment version. It will only be feasible if there are enough interest to trigger a LCD production batch (300 units min.) and me investing into better SMD equipments.
03-03-2016, 05:40 PM
Post: #163
Thank you Chris, I like your works very much but I can wait for a stable version. Furthermore I think it's better to follow your recommendations.
I love the 14 segments display but if it will prove to be too much difficult to assemble I'll gladly get a 41S instead.
Probably I will buy more than one but, alas, cannot vouch for 300! :)
03-03-2016, 08:35 PM
Post: #164
(03-03-2016 05:27 PM)Chris Chung Wrote:  You will, however purchase an appropriate TI launchpad and use it as a programmer. This will allow you to load the firmware and update / change it in the future.
For those of us that are not h/w developers, what set of skills would be required to update the f/w, or even to add a ROM image, etc. using this Launchpad? At $10, there's no decision to be made, and I can do things like burn EPROMS, download files, etc. but no idea if one needs soldering skills, etc.
(03-03-2016 05:40 PM)Massimo Gnerucci Wrote:  Probably I will buy more than one but, alas, cannot vouch for 300! Smile
1 + ( or maybe it should be 2 +, but certainly 300 NOT)
Thanks for sharing the plans and timing Chris, keep up the great work!
03-06-2016, 11:52 AM
Post: #165
(03-03-2016 05:27 PM)Chris Chung Wrote:  Once a NP-41S becomes stable, we may want to evaluate again the feasibility of the 14-segment version. It will only be feasible if there are enough interest to trigger a LCD production batch (300 units min.) and me investing into better SMD equipments.
Great work! I want to have +1 too, so only 297 to go. Smile
Bernhard
03-06-2016, 06:31 PM
Post: #166
Bernhard
+1 for me,
296 missing.
03-06-2016, 08:17 PM
Post: #167
1+
Only 295
03-06-2016, 08:33 PM
Post: #168
+1 (294 left)
Sylvain
03-06-2016, 11:50 PM
Post: #169
+1 (292 left)
03-07-2016, 08:21 PM (This post was last modified: 03-07-2016 08:28 PM by Chris Chung.)
Post: #170
Bernhard
Thank you all for interested in and supporting this project. We do not need 300 NP41 units to make this feasible. 50 committed buyers would be enough. A batch of 300 LCDs will cost around US$500 (I hope my estimate is close, there are quite a bit of logistic cost here). With 50 kits, I can assume a $10 LCD unit cost.
My feeling is that I would probably get 50 committed takers but we all cannot make commitments when there is not even a price. I do not have a price yet as there are still some variables. Except that it will be reasonable (compare this w/ NP25), I would say it will be between US$50 and US$80. There will be a simple 3D printed back case only. I found out the keytops is not giving any functional and visual advantages except that it took me 3 hours to print one.
This is the revised case which is thinner than the last one as I am not attaching a keypad.
It is comfortable to hold and the PCB has all the key legends and I found it works and looks better than w/o the keypad.
Unfortunately because of the length, I still have not yet perfected the print and there is still wrapping on the far corner. I need to adjust my 3D printer and / or print parameters to improve this.
/EDIT, I know the K, L, M and O, P letter legends on the PCB are off. Have to fix them on next PCB batch.
03-07-2016, 10:20 PM
Post: #171
(03-07-2016 08:21 PM)Chris Chung Wrote:  My feeling is that I would probably get 50 committed takers but we all cannot make commitments when there is not even a price. I do not have a price yet as there are still some variables. Except that it will be reasonable (compare this w/ NP25), I would say it will be between US$50 and US$80. There will be a simple 3D printed back case only.
For that price, I am definitely in for one of these! (291 left) *or* (41 left)
smp
03-07-2016, 10:30 PM
Post: #172
smp
Ditto! One for sure, and probably two, depending on final features. So, maybe, we're already at 40 left.
03-09-2016, 02:56 AM
Post: #173
That keypad looks wonderful...
At the risk of derailing your work in progress, would you consider selling just the keypad?
If made as a USB style keyboard, I could probably plug it into my Nexus 7 Android, and use / make my own calculator app.
I could even arrange screen & pad independently, in portrait / landscape mode, as I see fit.
03-09-2016, 01:49 PM
Post: #174
(03-09-2016 02:56 AM)sa-penguin Wrote:  That keypad looks wonderful...
I assume you mean the keys PCB. It is not intelligent, more of just a physical matrix of keys and battery holder. There will be a lot of work to implement your idea.
An easy way is to pair w/ some known solutions that employs an MCU that has USB capabilities.
My keypad design, however, is not the common rows x columns layout. To save GPIO pins, they have additional multiplexing.
I am using 10 pins for the keys, w/ R x C layout, the most I can do is 5 x 5 or 25 keys.
Instead, I scan my 10 pins like so.
pin 0 scans w/ 1 2 3 4 5 6 7 8 9
pin 1 scans w/ 2 3 4 5 6 7 8 9
pin 2 scans w/ 3 4 5 6 7 8 9
pin 3 scans w/ 4 5 6 7 8 9
.... etc, this setup allows me to scan 45 keys.
If you like to try use this PCB, I can send one to you on shipping cost. Another idea is to install Fritzing and with my design file, you can add a ProMicro, or similar device (< $4) for a more complete solution.
03-09-2016, 02:19 PM
Post: #175
A member is getting the parts to do a build (14 segment version). As it is still prototyping quality, there are a few tips / instructions needed. I am putting them here in a reply so that it could be useful in the future to others who want to duplicate this.
I am not releasing the source / PCB design at this moment. They are not good to look at (messy as usual). And whoever is interested in them can PM me.
The keypad PCB is rather straight-forward. Same technique as in NP25 where you have to bent the SMD tactile buttons w/ a pair of long nose pliers and use them to fit the thru-holes. A CR2032 battery holder also on the underside.
The current PCB has 2 missing traces (design fault, I missed them) and they need to be added back. I just use resistor legs, but any wire would also do. See below.
For the "Head" unit, the design is also minimal. Apart from the MCU, there are 3 x 0.1uF bypass caps, a 10uF for power and a 4.7uF for the LCD charge pump.
The MCU should be soldered 1st and be examined properly w/ a magnifying glass. I had upgraded to use solder syringes and hot air gun, and still my most recent build requires a few re-flowing, caused by uneven solder paste application.
The LCD glass, do require some attention, to fit the layout, some 5 pins in the middle need to be bent (see various previous photos) and solder as surface mount.
To connect the 2 PCBs together, I am using common 0.1" header pins. My original idea is to allow tryouts of having the head unit tilt up better viewing angle.
I did not plan ahead when I solder the head unit (the keys PCB was not done when I do this), I had solder the female header too far from the PCB edge, I am using a thru-pin female header as SMD (for cost and availability reasons) and I should have position it close to the edge.
The result is that the male pins from the keys PCB could not fit reliably w/ the female side. Eventually I had to reshape the male pins (they are right angle pins) to extend and lower them for head unit fitting.
So to sum it up, my advice would be
  • Solder MCU 1st, check the work and see if reflow is needed.
  • Solder other parts EXCEPT all header pins and LCD.
  • Play w/ the LCD and decide if and how much elevation is needed. This is similar to NP25 as parts on both sides interfere w/ each other. My build had the LCD elevated 1.5mm. Insert LCD, insert the 4 pin header for programming, the female headers (if part of these pins goes thru the PCB). decide the best fit before soldering.
  • Solder the LCD, I would just solder 2 or 3 corner pin only at this stage.
  • Layout both PCBs and trial fit the 2x 8 pin header connections. Decide and fix the female headers.
  • Solder header pins.
  • Solder reset of LCD pins.
03-09-2016, 03:35 PM
Post: #176
Hi Chris,
thanks for the info!
I think the build will be easy with those instructions.
However, I didn't quite understand how your key scanning works
(03-09-2016 01:49 PM)Chris Chung Wrote:  ...
Do you have a schematic for the keyboard? That might help me understand what you are doing.
Cheers,
Harald
03-09-2016, 06:21 PM
Post: #177
(03-09-2016 03:35 PM)Harald Wrote:  Hi Chris,
Cheers,
Harald
I did not properly draw a schematic, I just used Fritzing to "draw" the PCB using it's manual trace routing.
Here is a simplified schematic for a 5 pin key multiplexer to illustrate the connection and scanning, it yields 4 + 3 + 2 + 1 keys.
In the firmware I start by placing pin 0 (say from top) as output set to high, pin 1, 2, 3, 4 as input w/ pull-down to low. And I would scan for the 4 input pins to see any of the 1st row keys has been hit.
On the next scan cycle I would place pin 1 as output to high, and scan for pin 2, 3, and 4. I won't scan pin 0 here as it was done in the last scan cycle.
Likewise on the next can cycle we can the next row w/ one fewer inputs / buttons.
03-09-2016, 06:58 PM
Post: #178
I agree! And it shows the same style as the NP-25. Both together could be nice twins lying on a desk or placed in a showcase.
The keyboard matrix with changing input/output pins is also a slick idea. It scans n*(n-1)/2 keys with n lines compared to (n/2)^2 with a conventional matrix.
Bernhard
03-09-2016, 07:03 PM
Post: #179
Cheers,
Harald
Ahh, now I get it! Thanks for the explaination, that is a very clever Idea.
That way with n lines you can scan n*(n-1)/2 keys.
The conventional way it would be (n/2)^2.
03-09-2016, 09:51 PM
Post: #180
(03-09-2016 07:03 PM)Harald Wrote:  Ahh, now I get it! Thanks for the explaination, that is a very clever Idea.
Seems we got the same results Smile Approved!
Bernhard
