A new HP-67 Simulator for the iPhone
06-05-2016, 07:45 PM
RE: A new HP-67 Simulator for the iPhone
(06-05-2016 06:35 PM)Gerson W. Barbosa Wrote: Any idea where DSP mode is hiding? Thanks! Not easy to find, Gerson, but I think I just located it. Have to use the OP function. Press g OP (shifted CLX). Then you scroll way down almost to the bottom to find DSP MODE. By placing 1.4 in X prior to executing DSP mode I got thousands separators and fix to 4 decimal places. If I read the instructions correctly at: http://cuveesoft.ch/rpn67/p02.html It appears the type of separators (. ,) should be set automatically according to what country you are in. I'd be interested to know how that is working. Regards, Bob |
06-05-2016, 11:15 PM
(This post was last modified: 06-05-2016 11:17 PM by Gerson W. Barbosa.)
(06-05-2016 07:45 PM)bshoring Wrote: By placing 1.4 in X prior to executing DSP mode I got thousands separators and fix to 4 decimal places. If I read the instructions correctly at: Thanks! With 1.9, for 12345678.9 I get on the display 123.456.789 , 90 as expected. This is nice, but I still can't find the comma|decimal point|auto selection which is mentioned in the update notice. Perhaps I just haven't searched enough. Gerson. |
06-06-2016, 08:46 PM
(This post was last modified: 06-06-2016 08:51 PM by Willy R. Kunz.)
(06-05-2016 11:15 PM)Gerson W. Barbosa Wrote:(06-05-2016 07:45 PM)bshoring Wrote: By placing 1.4 in X prior to executing DSP mode I got thousands separators and fix to 4 decimal places. If I read the instructions correctly at: Sorry for any confusion. The feature is not available on the current versions of RPN-67/97 Pro for the iPad. That's why it's not described on the homepage yet. In short, the decimal point character is defined by the second digit following the decimal point in the argument for the DSP MODE command: 0 = auto = set according the locale (region) defined for the device 1 = forced to "." 2 = forced to "," The corresponding number grouping character is defined by the selected display mode: 0 = auto = set according the locale (region) defined for the device 1 = "," or – if neither "." nor "," – left unchanged 2 = "." or – if neither "." nor "," – left unchanged The number grouping is set according to the locale. Usually, that's groups of three digits, but for a change, try setting your device to India, language English or Hindi. Example: Value: 3141592.654 DSP MODE = 1.3 US: 3,141,592.654 Germany: 3.141.593,654 Switzerland: 3'141'592.654 India: 31,14,592.654 DSP MODE = 1.31 US: 3,141,592.654 Germany: 3,141,593.654 Switzerland: 3'141'592.654 India: 31,14,592.654 DSP MODE = 1.32 US: 3.141.592,654 Germany: 3.141.593,654 Switzerland: 3'141'592,654 India: 31.14.592,654 |
07-29-2016, 10:05 AM
Praise for the RPN-67 Pro (and RPN-65 Pro).
Thank you for creating these outstanding simulators! They are a joy to use and especially the versatile program database where I can easily keep track of my (fully annotated) programs, has rekindled my old passion for keystroke programming. |
08-01-2016, 05:40 PM
I also have and love all of the emulators on my iPad. Any chance of an HP-55 emulator?
08-03-2016, 11:51 AM
(07-29-2016 10:05 AM)tomisan Wrote: Praise for the RPN-67 Pro (and RPN-65 Pro). Thank you. It's great to hear you like my work. Here are some features of the next update of RPN-67/97 Pro:
User(s) browsing this thread: 21 Guest(s)
