HP35s - Flashiing Memory Clear
08-23-2016, 08:46 PM
I was playing with my 35s today and after pressing the R/S key several times, a flashing Memory Clear message appeared on the display. I could not turn off the calculator with the LS-On key so I removed the batteries. After replacing the batteries the flashing Memory Clear message was still there. I also tried the reset on the back to no avail. Any idea as to what happened and is there a way to reboot this thing?
08-23-2016, 09:13 PM
(This post was last modified: 08-23-2016 11:26 PM by Marcio.)
RE: HP35s - Flashiing Memory Clear
You're not the first to report this kind of problem. See this thread.
Have you tried shorting the terminals together? |
08-25-2016, 09:49 AM
Also ensure you have good batteries, this behaviour also occurs when the batteries start getting a bit low.
08-25-2016, 06:56 PM
RE: HP35s - Flashiing Memory Clear | |||
