(15C) Accurate TVM for HP-15C
01-10-2014, 03:36 AM (This post was last modified: 01-02-2016 01:46 PM by Jeff_Kearns.)
Note: See post #6 for the latest version (now 40 lines in length). I have left previous posts unedited to avoid causing confusion.
This is an adaptation of the Pioneer's (42S/35S/33S/32Sii/32S) Accurate TVM routine for the HP-15C using Karl Schneider's technique for invoking SOLVE with the routine written as a MISO (multiple-input, single-output) function, using indirect addressing.
001 f LBL E
002 STO(i)
003 RCL 2
004 EEX
005 2
006 ÷
007 ENTER
008 ENTER
009 1
010 +
011 LN
012 X<>Y
013 LSTx
014 1
015 X≠Y
016 -
017 ÷
018 *
019 RCL * 1
020 e^x
021 ENTER
022 RCL * 3
023 X<>Y
024 1
025 -
026 RCL * 4
027 EEX
028 2
029 RCL ÷ 2
030 RCL + 6
031 *
032 +
033 RCL + 5
034 RTN
Usage instructions:
1. Store 4 of the following 5 variables, using appropriate cash flow conventions as follows:
  • N STO 1 --- Number of compounding periods
  • I STO 2 --- Interest rate (periodic) expressed as a %
  • B STO 3 --- Initial Balance or Present Value
  • P STO 4 --- Periodic Payment
  • F STO 5 --- Future Value
and store the appropriate value (1 for Annuity Due or 0 for Regular Annuity) as
    B/E STO 6 --- Begin/End Mode. The default is 0 for regular annuity or End Mode.
2. Store the register number containing the floating variable to the indirect storage register.
3. f SOLVE E
Example from the HP-15C Advanced Functions Handbook-
"Many Pennies (alternatively known as A Penny for Your Thoughts):
A corporation retains Susan as a scientific and engineering consultant at a fee of one penny per second for her thoughts, paid every second of every day for a year.
Rather than distract her with the sounds of pennies dropping, the corporation proposes to deposit them for her into a bank account in which interest accrues at the rate of 11.25 percent per annum compounded every second. At year's end these pennies will accumulate to a sum
total = (payment) X ((1+i/n)^n-1)/(i/n)
where payment = $0.01 = one penny per second,
i = 0.1125 = 11.25 percent per annum interest rate,
n = 60 X 60 X 24 X 365 = number of seconds in a year.
Using her HP-15C, Susan reckons that the total will be $376,877.67. But at year's end the bank account is found to hold $333,783.35 . Is Susan entitled to the $43,094.32 difference?"
  • 31,536,000 STO 1
  • (11.25/31,536,000) STO 2
  • 0 STO 3
  • -0.01 STO 4
  • 5 STO I
  • f SOLVE E
The HP-15C now gives the correct result: $333,783.35.
Thanks to Thomas Klemm for debugging the above routine.
Edit: The code has been edited to reflect Thomas' suggested changes below.
Jeff Kearns
01-10-2014, 05:31 AM
RE: Accurate TVM for HP-15C
(01-10-2014 03:36 AM)Jeff_Kearns Wrote:  027 RCL 2
028 EEX
029 2
030 ÷
031 1/x
Any reason for not using:
027 EEX
028 2
029 RCL ÷ 2
Just curios.
01-10-2014, 05:38 AM (This post was last modified: 01-10-2014 05:48 AM by Jeff_Kearns.)
(01-10-2014 05:31 AM)Thomas Klemm Wrote:  Any reason for not using:
027 EEX
028 2
029 RCL ÷ 2
Just curios.
Oversight! I note that you 'did' suggest this change in the other thread. I will test it tomorrow and edit the post accordingly (or would that cause an issue with the follow-on posts?).
Jeff
01-16-2014, 09:32 PM
(01-10-2014 03:36 AM)Jeff_Kearns Wrote:  Edit: The code has been edited to reflect Thomas' suggested changes below.
There's a 1/x too much now. ;-) Obviously a leftover from the original code. Take a look at line 30.
Dieter
01-16-2014, 09:38 PM (This post was last modified: 01-16-2014 09:40 PM by Jeff_Kearns.)
Dieter wrote: "There's a 1/x too much now. ;-) Obviously a leftover from the original code. Take a look at line 30."
Fixed! Thanks Dieter.
05-25-2014, 03:03 PM (This post was last modified: 05-25-2014 03:42 PM by Jeff_Kearns.)
Most accurate version is now 40 lines:
001 - LBL E
002 - STO (i)
003 - RCL 2
004 - EEX
005 - 2
006 - /
007 - ENTER
008 - ENTER
009 - 1
010 - +
011 - LN
012 - x<>y
013 - LSTx
014 - 1
015 - TEST 6
016 - -
017 - /
018 - x
019 - RCLx 1
020 - ENTER
021 - e^x
022 - RCLx 3
023 - x<>y
024 - 2
025 - /
026 - SINH
027 - LSTx
028 - e^x
029 - x
030 - 2
031 - x
032 - RCLx 4
033 - EEX
034 - 2
035 - RCL/ 2
036 - RCL+ 6
037 - x
038 - +
039 - RCL+ 5
040 - RTN
08-27-2016, 10:07 PM (This post was last modified: 08-27-2016 10:42 PM by Nick.)
RE: (15C) Accurate TVM for HP-15C
UI Mod: 40 step version w/ 12C Layout
Layout (12C): [A: N], [B: I], [C: PV], [D: PMT], [E: FV]
Clear: GSB 2
- Mnemonic: 12C
- Note: You must run Clear to initialize the program before use.
Store: STO {A..E}
Solve: [f] {A..E} or for User Mode simply {A..E}
- (Option) Set X & Y to a range of values to search (slightly faster to run and much slower to key)
- (Option) Don't bother entering anything as most of the time it will work as-is. Use 1 ENTER or -1 ENTER and re-run if SOLVE fails. (faster to key)
Recall: RCL {A..E}
Set End (default): 0 STO 2
Set Begin: 1 STO 2
- Mnemonic: 12C
01 LBL A
02 RCL MATRIX A
03 GTO 0
04 LBL B
05 RCL MATRIX B
06 GTO 0
07 LBL C
08 RCL MATRIX C
09 GTO 0
10 LBL D
11 RCL MATRIX D
12 GTO 0
13 LBL E
14 RCL MATRIX E
15 LBL 0
16 STO I
17 Rdn
18 SOLVE 1
19 RTN
20 LBL 1
21 STO (i)
22 RCL B
23 EEX
24 2
25 /
26 ENTER
27 ENTER
28 1
29 +
30 LN
31 X<->Y
32 LSTx
33 1
34 TEST 6
35 -
36 /
37 *
38 RCL* A
39 ENTER
40 e^x
41 RCL* C
42 X<->Y
43 2
44 /
45 HYP SIN
46 LSTx
47 e^x
48 *
49 2
50 *
51 RCL* D
52 EEX
53 2
54 RCL/ B
55 RCL+ 2
56 *
57 +
58 RCL+ E
59 RTN
60 LBL 2
61 MATRIX 0
62 1
63 ENTER
64 DIM A
65 DIM B
66 DIM C
67 DIM D
68 DIM E
69 MATRIX 1
70 [CLEAR] SIGMA
71 STO 2
72 RTN
Comments:
- Uses 1x1 Matricies to treat A..E as direct access registers. This requires R0=1 and R1=1 for A..E to function. This is set via MATRIX 1 in the Initialize/Clear routine. The contents of A..E will not be lost if R0 or R1 are changed, but they must be reset with MATRIX 1 (or manually) to restore direct access.
- The 12C style version in the 15C Advanced Functions Handbook p24-30 [2012] by contrast is 108 steps long.
08-27-2016, 10:34 PM (This post was last modified: 08-27-2016 11:58 PM by Nick.)
Issue:
The 40 step version fails when I = 0 (either by setting it as a value or when searching for I).
Workaround:
Set X & Y = 1 when solving for I (or a similar known range to search)
Set I = (a very small interest rate) to approximate 0% interest problems or solve manually.
