Strange behavior solver app - V.20160829
09-01-2016, 05:07 PM
Good afternoon every one.
This afternoon my Hp prime updated correctly from the conkit. The first thing I did, was check it had solved the problem with solve application. Here the problem with the last firmware http://www.hpmuseum.org/forum/thread-6487.html I tried again with the example from the user manual, EQ1: X-Y=-1 EQ2: (X^2)+(Y^2)=16 Now my solve aplication works, but the answer is not correct: X=2 Y=28 388 218 142 In virtual calculator, now it doesn´t works. In android, it works fine. Please, can anyone check with the same equationes on your hp prime/virtual prime/android prime. Thanks a lot. |
09-01-2016, 06:21 PM
RE: Strange behavior solver app - V.20160829
I got
X=2.28388 Y=3.28388 looks OK to me. primer |
09-01-2016, 08:16 PM
This is what I have:
09-01-2016, 08:27 PM
If you change to a non , decimal mark setting all will work correctly. That is the only workaround I can offer you in the meantime.
09-01-2016, 08:47 PM
(09-01-2016 08:27 PM)Tim Wessman Wrote: If you change to a non , decimal mark setting all will work correctly. That is the only workaround I can offer you in the meantime. Thanks for your answer Tim. As you say I changed to a non decimal, and it works fine. After that I returned again to decimal sistem, and now it works fine. In any case, curious... |
09-02-2016, 02:38 PM
Happened te same to me, but cound't fix it when I returned to the decimal symbol ",". Is there a bug with the decimal symbol ","?
09-02-2016, 02:58 PM
I would not expect it to be "fixed" by changing back. The problem has to do with parsing the results returned from the CAS fsolve command (in a string form). What you are seeing is the number being split at the , symbol incorrectly. The part after the , shows up as the Y value.
09-02-2016, 10:01 PM
Thanks for the reply. Do you have any idea if this bug will be fixed in a future update?
09-07-2016, 09:07 AM
Ohh I'm sorry. As Tim says, changing back does not improve.
It has been my newly diagnosed presbyopia certainly makes me confused sometimes between (.) y (,) I apologize for any inconvenience this may have caused. |
09-19-2016, 09:49 AM
The different digit grouping formats seem to be a constant source for trouble. Started with programming and is true for the very heart of the calculator. I struggled with that and I took it as given. Never came to the idea that number formatting could cause such funny results.
Annoying on the one hand, interessting on the other and definitely a feel good thing. Feel good in a way that makes you feel less idiotic when one modification in a larger software project is a reliable source for trouble. I assume the dev team is much much more capable than I am and knowing the prime shows such annoying bugs aswell will help me through this work-week. Although interessting to see that they still did not find a solid integration of xcas into their code. |
