PIC Code for Teenix emulators
09-16-2016, 09:37 AM
Not sure if anyone is a PIC chip experimenter but I have published the source code for the emulators for those that might be interested. It works in conjunction with the PC emulator which is available in the same download. The PIC is a 16F1519 and will emulate the following calculators, HP21, HP22, HP25, HP27, HP29C, HP31E, HP32E, HP33E, HP37E, HP35, HP45, HP55, HP65, HP67, HP70, HP80 http://www.teenix.org cheers Tony |
09-16-2016, 11:09 AM
RE: PIC Code for Teenix emulators
(09-16-2016 09:37 AM)teenix Wrote: Hi all, Thanks for that Tony, I'll have a look at that now. Btw, have you emailed anything in the last two weeks? I don't have access to my kostal email address while I am away during September. But I might find some time to work on our display data transfer. So it would be good to know if you have made a start on that. Cheers, Harald |
09-16-2016, 10:37 PM
(09-16-2016 11:09 AM)Harald Wrote: Thanks for that Tony, Hi Harald, I've been working on replacing my old flight school management software which is proving to be a larger task that I thought. So along with normal work commitments, I haven't had much time to do anything else. I'll send the HP35 5x8 keyboard modified source code to your address soon. Its a bit messy though :-) cheers Tony |
09-17-2016, 10:00 AM
(09-16-2016 09:37 AM)teenix Wrote: Not sure if anyone is a PIC chip experimenter but I have published the source code for the emulators for those that might be interested. It works in conjunction with the PC emulator which is available in the same download. Wow! I didn't expect that you made it in pure assembler code. That is nowadays a very special ability. My respect and hats off. Bernhard That's one small step for a man - one giant leap for mankind. |
09-17-2016, 11:04 AM
RE: PIC Code for Teenix emulators | |||
09-18-2016, 09:15 PM
(09-16-2016 10:37 PM)teenix Wrote:(09-16-2016 11:09 AM)Harald Wrote: Thanks for that Tony, Hi Tony, I didn't mean to rush you. I am very grateful you are doing this at all! I doubt I'd be able to write anything that large in assembler. Very impressive! Cheers, Harald |
09-19-2016, 07:18 AM
