GO9800 Emulator
10-12-2016, 09:25 PM
GO9800 Emulator
Dear friends,
I'm pleased to announce, that after a few years without progress, a new release 2.02 of my HP9800 series emulator is available for download from https://sourceforge.net/projects/hp9800e...00%202.02/ This release features a complete new microcode based CPU emulation using dumps of the CPU, ALU, and BCD ROMs and includes a microcode disassembler and ROM decoder. The revised manual contains a large section about the theory of operation and implementation of the CPU micro-instructions. Have fun, Achim |
10-12-2016, 10:16 PM
(This post was last modified: 10-12-2016 10:54 PM by hp41cx.)
GO9800 Emulator
Wonderful!!! Thank you so much !!! :-)
But no manual :-( Systems Analyst 48G+/58C/85B/PC1500A TH-78A/DooGee S9 Focal & All Basic´s |
10-13-2016, 06:45 AM
RE: GO9800 Emulator
Really great project!
J-F |
10-13-2016, 07:20 AM
RE: GO9800 Emulator
Hi folks,
sorry, I forgot to include the manual and just uploaded a new bin archive containing it as well as a separate PDF file. Achim |
10-13-2016, 11:41 AM
(This post was last modified: 10-13-2016 11:57 AM by Sylvain Cote.)
RE: GO9800 Emulator
Wow! Great project!
Its incredible the work and time you spent on this but the result is awesome. I have run it on OSX 10.11.6. I have absolutely no idea how they works, never tried these machines before but everything seems to work including the sounds I have this warning Code: 07:15:57.042 WARNING: 140: This application, or a library it uses, is using the deprecated Carbon Component Manager for hosting Audio Units. Thank you very much for sharing this marvellous emulator. Did I say Wow! Sylvain Edit: after testing more emulators, it seems that the file "HP9866A.jpg" is not loaded/displayed in the HP9866A window. Terminal log ... Code: gtombp17:GO9800_bin_2.02 sycote$ ./HP9830B.sh |
10-13-2016, 01:17 PM
RE: GO9800 Emulator
Silvain,
thank you very much, I appreciate your comments. Yes, I will have to work on the audio engine, as it doesn't work at all on Raspberry PI. And yes, to be honest, display of a JPG image for the 9866A/B is not implemented. Its just a window with white background for the print output. Greetings, Achim |
10-13-2016, 09:04 PM
RE: GO9800 Emulator
Hi Achim,
this looks very interesting. Unfortunately I have not succeeded in starting the emulator. I have download the binaries, unpacked them into a folder and tried to start go9800.jar. On my Ubuntu 16.04 machine and also on the Windows 8 machine nothing at all happens. Both try to open it using Java Runtime. What am I missing? Cheers, Harald |
10-13-2016, 09:12 PM
RE: GO9800 Emulator
(10-13-2016 09:04 PM)Harald Wrote: Hi Achim, Execute hpxxxx.cmd Systems Analyst 48G+/58C/85B/PC1500A TH-78A/DooGee S9 Focal & All Basic´s |
10-13-2016, 09:25 PM
RE: GO9800 Emulator
(10-13-2016 09:12 PM)hp41cx Wrote:(10-13-2016 09:04 PM)Harald Wrote: Hi Achim, Thanks! That didn't work either. But copying the contents of the cmd file to the terminal did. |
10-13-2016, 09:43 PM
(This post was last modified: 10-14-2016 09:33 AM by achim.)
RE: GO9800 Emulator
Harald,
on windows use the hp*.cmd files to start the emulator for the corresponding machine, on Linux or MacOSX use the hp*.sh files. Prior to this you have to give them execute rights by entering chmod a+x *.sh in a shell. And Java runtime 1.7 or higher has to be installed in /usr/bin. If this is not the case, edit the .sh files and set the correct path. I hope that helps. Best regards, Achim |
11-01-2016, 07:08 PM
RE: GO9800 Emulator
Sylvain,
I have checked the audio warning you mentioned. A the moment I can do nothing about it, seems to be a problem of the Java libraries in conjuction with OSX 10.11. See [url=https://github.com/libgdx/libgdx/issues/3572] and [url=https://github.com/cmus/cmus/issues/331] Which Java release do you use? Achim |
05-04-2017, 04:52 PM
RE: GO9800 Emulator
Sorry for digging in old thread but why go9800 was removed from sourceforge?
I was able to download V2.03 from other website and its great. Before i had 1.60 and its one of the best emulators ever. What is the latest version? Where can i download it? And why there was no manual in 2.03 package while 1.60 package had manual. Where can i download manual for latest version? |
05-04-2017, 07:49 PM
RE: GO9800 Emulator
(10-12-2016 09:25 PM)achim Wrote: Dear friends, Is this still available somewhere? I can't find it anymore. Tom L Tom L Cui bono? |
05-04-2017, 08:00 PM
(This post was last modified: 05-04-2017 08:25 PM by Dave Frederickson.)
RE: GO9800 Emulator
(05-04-2017 07:49 PM)toml_12953 Wrote: Is this still available somewhere? I can't find it anymore. https://emulationrealm.net/downloads/file/2498-go9800 There's an updated manual, GO9800_User_Manual_2.03.pdf, that I can't find. |
02-03-2018, 03:23 AM
RE: GO9800 Emulator
(10-12-2016 09:25 PM)achim Wrote: Dear friends,Is this emulator still available somewhere? I can't find it on SourceForge. Tom L Cui bono? |
02-03-2018, 10:59 AM
RE: GO9800 Emulator
(02-03-2018 03:23 AM)toml_12953 Wrote: Is this emulator still available somewhere? I can't find it on SourceForge. I have a copy. Temporary link, hurry up! Program Docs Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
02-03-2018, 05:14 PM
RE: GO9800 Emulator
I uploaded my GO9800 archive to the VintHPcom group files section a couple months ago. It includes v1.60, 2.02 and 2.03 of the emulator, although I'm missing the manual and source code for 2.03.
https://groups.io/g/VintHPcom/files/Emul...GO9800.zip I think you have to join the group to get file access, but I can put it up on my site for now. The link should be good for a few weeks, or until I run a site update. http://www.decadecounter.com/vta/GO9800.zip |
02-04-2018, 03:40 AM
RE: GO9800 Emulator
(02-03-2018 10:59 AM)Massimo Gnerucci Wrote:(02-03-2018 03:23 AM)toml_12953 Wrote: Is this emulator still available somewhere? I can't find it on SourceForge. Got 'em. Thanks! Tom L Cui bono? |
02-04-2018, 03:44 AM
RE: GO9800 Emulator
(02-03-2018 05:14 PM)Accutron Wrote: I uploaded my GO9800 archive to the VintHPcom group files section a couple months ago. It includes v1.60, 2.02 and 2.03 of the emulator, although I'm missing the manual and source code for 2.03. Great! Thanks! Tom L Cui bono? |
07-30-2018, 11:04 PM
RE: GO9800 Emulator
Can someone make available the PDF documentation? I have the emulator working, but it would be nice to know how to use the tape files (i.e. what's on them), etc. Thanks.
