41 Programs for 7470 Plotter - Why so few?
09-13-2016, 09:25 AM
Post: #41
RE: 41 Programs for 7470 Plotter - Why so few?
(09-13-2016 08:39 AM)Mike (Stgt) Wrote:(09-12-2016 07:08 PM)aurelio Wrote: How many things needed, really. Ciao Mike, I know that there is a plotter emulator (if you mean that) but anyway you have to interface the real calculator with a PC, how? Or maybe you mean complete emulation of the hardware? |
09-13-2016, 01:18 PM
Post: #42
(09-13-2016 10:04 AM)Mike (Stgt) Wrote:(09-13-2016 09:25 AM)aurelio Wrote: I know that there is a plotter emulator (if you mean that) but anyway you have to interface the real calculator with a PC, how? Dreaming time: get an active ("hot") USB-interface between the real machine and V41 (or your favorite simulator) - that links them both "live"... "To live or die by your own sword one must first learn to wield it aptly." |
11-06-2016, 09:09 AM
Post: #43
I published a beta version of pyILPER with a HP7470 emulation and I am still interested in getting more test programs. Does anybody have all programs in the book "Grafik mit dem HP-41" as raw files? I got only some of them from the GRAFIX ROM.
Are there any HP-71 applications for the HP7470A plotter? Regards Joachim |
11-06-2016, 02:20 PM
Post: #44
RE: 41 Programs for 7470 Plotter - Why so few? | |||
11-06-2016, 05:54 PM
Post: #45
The barcode reader utility requires however very clean high resolution 600dpi black and white scans of the barcodes.
11-08-2016, 12:55 AM
Post: #46
(11-06-2016 09:09 AM)jsi Wrote: I published a beta version of pyILPER with a HP7470 emulation and I am still interested in getting more test programs. Does anybody have all programs in the book "Grafik mit dem HP-41" as raw files? I got only some of them from the GRAFIX ROM.I didn't find any info for the GRAFIX rom, appears in the CL rom list though. Which programs do you have? Here’s one; LINH, the first on the book. As I didn’t test it, errors are not excluded. Is there some translation – English, French, Spanish or Portuguese – of the book? |
11-08-2016, 08:31 PM
Post: #47
Type error. I meant the GRAFIKS rom project discussed in this thread. At the moment I have raw files for LINH, STABH. KREISH, LINLOG, LOGLOG, NETZ. I failed to get XY running because the program listing seems to be incomplete between line 392 and 402.
I do not think that this book was translated into other languages. Regards Joachim |
11-09-2016, 01:41 PM
Post: #48
(11-08-2016 08:31 PM)jsi Wrote: Type error. I meant the GRAFIKS rom project discussed in this thread. At the moment I have raw files for LINH, STABH. KREISH, LINLOG, LOGLOG, NETZ. I failed to get XY running because the program listing seems to be incomplete between line 392 and 402. I remember there were a few glitches in the bar codes and program listings, but you can make up for the omissions looking in the "parallel" routines. You can also create the RAW files using the MOD file loaded on V41, that's probably the easiest way? Cheers, 'AM "To live or die by your own sword one must first learn to wield it aptly." |
11-09-2016, 05:10 PM
Post: #49
