vars, geometry app
01-22-2017, 12:59 AM
vars, geometry app
Is it possible to change the options of the graphic vars like color, label or visibility, by means of code?
01-22-2017, 01:24 AM
RE: vars, geometry app
Can be done using Instruction().
Arno |
01-22-2017, 02:43 AM
Where I could find documentation about Instruction?
Thanks |
01-22-2017, 04:52 AM
(01-22-2017 02:43 AM)fabila Wrote: Where I could find documentation about Instruction? Method 1: Press the Help key, then tap Tree, Search, type "ins" (without the quotes), and press Enter three times. Method 2: Type "Instruction" on the command line (without quotes), then press the Help key. <0|ΙΈ|0> -Joe- |
01-22-2017, 01:48 PM
At the beginning of the code
STARTAPP("Geometry") To manipulate the elements directly Viga C | TD | FB |
