How can I make an app from an application?
03-29-2017, 07:15 AM
03-29-2017, 09:02 AM
RE: How can I make an app from an application?
(03-29-2017 07:15 AM)Onieh Wrote: How can I make an app from an application? I guess you mean from a program. Duplicate an existent app and write your program in the Name (app) program (from the Program Catalog) My website: ried.cl |
03-30-2017, 06:48 AM
And how do I get my own app image.
03-30-2017, 07:11 AM
See here.
03-30-2017, 12:17 PM
(03-30-2017 06:48 AM)Onieh Wrote: And how do I get my own app image. Right click in the app, inside the Connectivity Kit My website: ried.cl |
03-30-2017, 08:08 PM
Thanks for your suggestions, I will try it
04-03-2017, 06:12 PM
Hello everybody,
The change of the app graphics has worked. That with the program is not. I have copied an existing app and renamed it. Then I copied my program into the file director "program". When I start the app, the old app is running. What am I doing wrong? |
04-04-2017, 05:37 AM
What do you mean by: when I start the program, the old app is running? You made a copy of an app, copied your program into it... I assume that your program "takes" over a number of app view events (plot, symb...)... is your program running when you press these keys? Are you doing anything on app start (START function)? is that running? At the end of your override functions, are you using setviews to set a specific view? Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
04-09-2017, 10:33 AM
I have copy the App Solution. Rename it. Copy my program into the App. When I start the program then the original app is started. Can you show me an example how I have to make it exactly so that my program starts !?
04-09-2017, 11:17 AM
(This post was last modified: 04-09-2017 11:21 AM by eried.)
(04-09-2017 10:33 AM)Onieh Wrote: I have copy the App Solution. Rename it. Copy my program into the App. When I start the program then the original app is started. Can you show me an example how I have to make it exactly so that my program starts !? You need to read another app code to learn more about how the apps work. Start by trying: Code: Syntax: Get any app that you like and check how they use VIEW internally. Also you can put your initial code inside: Code: START My website: ried.cl |
04-09-2017, 12:33 PM
Thanks Eried,
a little program works :-) but This one doesn't works if i make it so!! START BEGIN STARTVIEW(-1); LOCAL Line; Line:=1; STARTAPP("Fluglatz"); WHILE Line<>0 DO CASE IF Line==1 THEN //Start Flugnavigation LOCAL CO:=RGB(255,255,255); RECT(RGB(154,205,50)); TEXTOUT_P("F L U G N A V I G A T I O N",31,20,7,RGB(255,255,255)); TEXTOUT_P("© 2017 Heino Krüger",180,220,3); //RWY RECT_P(0,90,320,160,RGB(155,155,155)); //0 RECT_P(68,112,79,114,RGB(255,255,255)); RECT_P(68,121,79,123,RGB(255,255,255)); RECT_P(66,114,68,121,RGB(255,255,255)); RECT_P(80,114,82,121,RGB(255,255,255)); //3 RECT_P(80,127,82,134,RGB(255,255,255)); RECT_P(66,127,68,134,RGB(255,255,255)); RECT_P(73,130,75,134,RGB(255,255,255)); RECT_P(68,135,79,137,RGB(255,255,255)); //2 RECT_P(240,137,242,126,RGB(255,255,255)); RECT_P(243,126,246,128,RGB(255,255,255)); RECT_P(247,137,249,126,RGB(255,255,255)); RECT_P(250,137,253,135,RGB(255,255,255)); RECT_P(254,137,256,126,RGB(255,255,255)); //1 RECT_P(240,114,256,116,RGB(255,255,255)); RECT_P(240,117,242,119,RGB(255,255,255)); RECT_P(10,97,50,107,RGB(255,255,255)); RECT_P(10,112,50,122,RGB(255,255,255)); RECT_P(10,127,50,137,RGB(255,255,255)); RECT_P(10,142,50,152,RGB(255,255,255)); RECT_P(270,97,310,107,RGB(255,255,255)); RECT_P(270,112,310,122,RGB(255,255,255)); RECT_P(270,127,310,137,RGB(255,255,255)); RECT_P(270,142,310,152,RGB(255,255,255)); LINE_P(120,124,161,121,CO);//Rumpf LINE_P(120,125,161,122,CO); LINE_P(120,126,161,123,CO); LINE_P(120,126,161,124,CO); LINE_P(120,126,161,125,CO); LINE_P(120,126,161,126,CO); LINE_P(120,126,161,127,CO); LINE_P(120,126,161,128,CO); LINE_P(120,126,161,129,CO); LINE_P(126,119,126,131,CO);//Heck LINE_P(125,119,125,131,CO); LINE_P(127,119,127,131,CO); LINE_P(128,120,128,130,CO); LINE_P(149,103,149,147,CO);//Flügel LINE_P(150,102,150,148,CO); LINE_P(151,101,151,149,CO); LINE_P(152,100,152,150,CO); LINE_P(153,100,153,150,CO); LINE_P(154,100,154,150,CO); LINE_P(155,100,155,150,CO); LINE_P(156,101,156,149,CO); LINE_P(162,122,162,128);//Motor LINE_P(163,123,163,127); LINE_P(164,125,166,125); LINE_P(166,118,166,132);//Propeller LINE_P(167,118,167,132); FREEZE; WAIT(); Line:=2; END; //Line1 Flugparameter IF Line==2 THEN //Start Flugkoordinaten STARTVIEW(-1); LOCAL K:=0, Z1:=0; RECT_P(0,0,320,220,RGB(0,255,0)); TEXTOUT_P("F L U G N A V I G A T I O N",31,20,7); TEXTOUT_P("1 für: Startplatz ICAO",70,60); TEXTOUT_P("2 für: Zielplatz_ICAO",70,85); TEXTOUT_P("3 für: Start POSITION",70,110); TEXTOUT_P("4 für: Ziel POSITION",70,135); TEXTOUT_P("Del für Abbruch",70,160); REPEAT K:=GETKEY; IF K==42 THEN Line:=3; END; //Taste 1 IF K==43 THEN Line:=4; END; //Taste 2 IF K==44 THEN Line:=5; END; //Taste 3 IF K==37 THEN Line:=6; END; //Taste 4 IF K==38 THEN PRINT("FLUGSTRECKE"); STARTVIEW (-1);END; //Taste 5 UNTIL K==19 or K==37 or K==38 or K==42 or K==43 or K==44; END; //ENDE Line2 Flugkoordinaten IF Line==3 THEN // Beginn Flugstart STARTVIEW(-1); LOCAL A,B,C,D,E,F,g; LOCAL H,I,K,S,T,Letter; LOCAL Keys:={"-","-","-","-","-", "-","-","-","-", "-","-","-","-","-", "A","B","C","D","E","Del", "F","G","H","I","J","K", "L","M","N","O","-", "P","Q","R","S","T", "-","U","V","W","X", "-","Y","Z","-","-", "-","-","-","-","-"}; STARTAPP("Flugplatz"); RECT_P(0,0,320,240,RGB(0,205,205)); //Clear screen RECT_P(90,40,129,59,RGB(255,255,255)); TEXTOUT_P("S t a r t f l u g p l a t z",40,0,7); TEXTOUT_P("Eingabe: ",0,38,5); T:=""; S:=0; WHILE S<4 OR POS(a:a,T)==0 DO //Loop until we got 4 letters that are in the spreadsheet Letter:="-"; WHILE Letter=="-" DO //Loop until a letter or the Del key is pressed K:=0; WHILE K=0 DO K:=WAIT()+1; END; //Wait until a key is pressed and get the key code Letter:=Keys(K); //Convert the keycode to a letter END; IF Letter=="Del" THEN //If Del key has been pressed, clear text and remove one letter from H IF S>0 THEN TEXTOUT_P(T,90,40,4,RGB(0,205,205),90,RGB(0,205,205));IFTE(S=1,T:="",T:=LEFT(T,S-1));S:=S-1; END; ELSE //Else it's a letter, IF S<4 THEN T:=T+Letter;S:=S+1; END; // add it to H and increase the number of letters if we have not yet 4 letters END; IF S==4 AND POS(a:a,T)==0 THEN //If we have 4 letters that are not in the spreadsheet ... TEXTOUT_P(T,90,40,4,RGB(255,0,0),90,RGB(0,205,205)); // ... then print them in RED ... ELSE TEXTOUT_P(T,90,40,4); // .. else print current letters in black END; END;//END WHILE S:=POS(a:a,T); RECT_P(0,32,320,34); A500:=(EXPR("D"+S)+EXPR("E"+S)/60+EXPR("F"+S)/3600); B500:=(EXPR("g"+S)+EXPR("H"+S)/60+EXPR("I"+S)/3600); //TEXTOUT_P((EXPR("A"+S)),90,40,4); TEXTOUT_P((EXPR("B"+S)),90,70,4); TEXTOUT_P((EXPR("C"+S)),90,95,4); TEXTOUT_P((EXPR("D"+S)+"°"),90,120,4); TEXTOUT_P((EXPR("E"+S)+"´"),140,120,4); TEXTOUT_P((EXPR("F"+S)+" ̋"),190,120,4); TEXTOUT_P((EXPR("g"+S)+"°"),90,150,4); TEXTOUT_P((EXPR("H"+S)+"´"),140,150,4); TEXTOUT_P((EXPR("I"+S)+" ̋"),190,150,4); WAIT(); FREEZE; Line:=2; END; //END Line3 Flugstart IF Line==4 THEN //Beginn Flugziel STARTVIEW(-1); LOCAL A,B,C,D,E,F,g; LOCAL H,I,K,S,T,Letter,CZ,DZ; LOCAL Keys:={"-","-","-","-","-", "-","-","-","-", "-","-","-","-","-", "A","B","C","D","E","Del", "F","G","H","I","J","K", "L","M","N","O","-", "P","Q","R","S","T", "-","U","V","W","X", "-","Y","Z","-","-", "-","-","-","-","-"}; STARTAPP("Flugplatz"); RECT_P(0,0,320,240,RGB(0,205,205)); //Clear screen TEXTOUT_P("Z i e l f l u g p l a t z",40,0,7); TEXTOUT_P("Eingabe: ",0,38,5); T:=""; S:=0; WHILE S<4 OR POS(a:a,T)==0 DO //Loop until we got 4 letters that are in the spreadsheet Letter:="-"; WHILE Letter=="-" DO //Loop until a letter or the Del key is pressed K:=0; WHILE K=0 DO K:=WAIT()+1; END; //Wait until a key is pressed and get the key code Letter:=Keys(K); //Convert the keycode to a letter END; IF Letter=="Del" THEN //If Del key has been pressed, clear text and remove one letter from H IF S>0 THEN TEXTOUT_P(T,90,40,4,RGB(0,205,205),90,RGB(0,205,205));IFTE(S=1,T:="",T:=LEFT(T,S-1));S:=S-1; END; ELSE //Else it's a letter, IF S<4 THEN T:=T+Letter;S:=S+1; END; // add it to H and increase the number of letters if we have not yet 4 letters END; IF S==4 AND POS(a:a,T)==0 THEN //If we have 4 letters that are not in the spreadsheet ... TEXTOUT_P(T,90,40,4,RGB(255,0,0),90,RGB(0,205,205)); // ... then print them in RED ... ELSE TEXTOUT_P(T,90,40,4); // .. else print current letters in black END; END; S:=POS(a:a,T); RECT_P(0,32,320,34); C500:=(EXPR("D"+S)+EXPR("E"+S)/60+EXPR("F"+S)/3600); D500:=(EXPR("g"+S)+EXPR("H"+S)/60+EXPR("I"+S)/3600); //TEXTOUT_P((EXPR("A"+S)),90,40,4); TEXTOUT_P((EXPR("B"+S)),90,70,4); TEXTOUT_P((EXPR("C"+S)),90,95,4); TEXTOUT_P((EXPR("D"+S)+"°"),90,120,4); TEXTOUT_P((EXPR("E"+S)+"´"),140,120,4); TEXTOUT_P((EXPR("F"+S)+" ̋"),190,120,4); TEXTOUT_P((EXPR("g"+S)+"°"),90,150,4); TEXTOUT_P((EXPR("H"+S)+"´"),140,150,4); TEXTOUT_P((EXPR("I"+S)+" ̋"),190,150,4); CZ:=(EXPR("D"+S)+EXPR("E"+S)/60+EXPR("F"+S)/3600); DZ:=(EXPR("g"+S)+EXPR("H"+S)/60+EXPR("I"+S)/3600); WAIT(); FREEZE; Line:=7; END; //ENDE Line4 Flugziel IF Line==5 THEN // Beginn FlugStartPos STARTVIEW(-1); LOCAL BG,BGM,BGS,LG,LGM,LGS; LOCAL control:=1; REPEAT INPUT({{BG,[0],{60,20,0}}, {BGM,[0],{60,20,1}}, {BGS,[0],{60,20,2}}, {LG,[0],{60,20,4}}, {LGM,[0],{60,20,5}}, {LGS,[0],{60,20,6}}}, "Start Position", {"Breitengrad LAT [°] ","Breitenminute [´] ","Breitensekunde [ ̋ ] ","Längengrad LONG [°] ","Längenminute [´] ","Längensekunde [ ̋ ] "}, {"Breitengrad [LATITUDE]","Breitenminute","Breitensekunde","Längengrad LONGITUTE ","Längenminute","Längensekunde"}); C500:=BG+BGM/60+BGS/3600; D500:=LG+LGM/60+LGS/3600; CASE IF (BG<47 or BG>55) THEN MSGBOX("Breitengrad ausserhalb Deutschland");control:=1; END; IF (LG<6 or LG>15) THEN MSGBOX("Längengrad ausserhalb Deutschland"); control:=1; END; IF ((BGM<0 or BGM>60) OR (BGS<0 or BGS>60) OR (LGM<0 or LGM>60) OR (LGS<0 or LGS>60)) THEN MSGBOX("Eingabe [ˊ] und [ ̋ ]nur von 0 - 60 erlaubt!"); control:=1; END; DEFAULT control:=0; END; //ENDE CASE-Anweisung UNTIL control <1; Line:=2; END; //END Line5 FlugStartlPos IF Line==6 THEN //Beginn FlugZielPos STARTVIEW(-1); LOCAL BG,BGM,BGS,LG,LGM,LGS; LOCAL control:=1; REPEAT INPUT({{BG,[0],{60,20,0}}, {BGM,[0],{60,20,1}}, {BGS,[0],{60,20,2}}, {LG,[0],{60,20,4}}, {LGM,[0],{60,20,5}}, {LGS,[0],{60,20,6}}}, "Ziel Position", {"Breitengrad LAT [°] ","Breitenminute [´] ","Breitensekunde [ ̋ ] ","Längengrad LONG [°] ","Längenminute [´] ","Längensekunde [ ̋ ] "}, {"Breitengrad [LATITUDE]","Breitenminute","Breitensekunde","Längengrad LONGITUTE ","Längenminute","Längensekunde"}); C500:=BG+BGM/60+BGS/3600; D500:=LG+LGM/60+LGS/3600; CASE IF (BG<47 or BG>55) THEN MSGBOX("Breitengrad ausserhalb Deutschland");control:=1; END; IF (LG<6 or LG>15) THEN MSGBOX("Längengrad ausserhalb Deutschland"); control:=1; END; IF ((BGM<0 or BGM>60) OR (BGS<0 or BGS>60) OR (LGM<0 or LGM>60) OR (LGS<0 or LGS>60)) THEN MSGBOX("Eingabe [ˊ] und [ ̋ ]nur von 0 - 60 erlaubt!"); control:=1; END; DEFAULT control:=0; END; //ENDE CASE-Anweisung UNTIL control <1; Line:=7; END; END; //END Line6 FlugZielPos IF Line==7 THEN //Start Flugparameter STARTVIEW(-1); //LOCAL TA1,WR1,WS1,RW1,LA1,VA1,DE1,WC1; //LOCAL VG1,MW1,BN1,BM1,P3; LOCAL control:=1; LOCAL m,m1,mx,my; REPEAT INPUT({{TA1,[0],{60,20,0}}, {WR1,[0],{60,20,1}}, {WS1,[0],{60,20,2}}, {VA1,[0],{60,20,3}}, {DE1,[0],{60,20,4}}, {BN1,[0],{60,20,6}}}, "AirSpeed / Wind", {"Fluggeschwindigkeit TAS [KT] ","Windrichtung WR [°] ","Windgeschwindigkeit WS [KT] ", "Variation [°] ","Deviation ","Benzinverbrach [l/h] "}, {"Fluggeschwindigkeit","Windrichtung","Windgeschwindigkeit","Variation","Deviation","Benzinverbrauch je Stunde"}); CASE IF (WS1<0 or WS1>100) THEN MSGBOX("WS>0 und WS<100");control:=1; END; IF (WS1>=TA1) THEN MSGBOX("Windstärke >= TAS!?"); control:=1; END; IF (WR1<0 or WR1>360) THEN MSGBOX("Windrichtung zwischen 0° und 360°"); control:=1; END; IF (VA1>30 OR VA1<-30) THEN MSGBOX("Variation zwischen >30° oder <-30°"); control:=1; END; IF (DE1>30 OR DE1<-30) THEN MSGBOX("Deviation zwischen >30° oder <-30°"); control:=1; END; IF (BN1<0 OR BN1>40) THEN MSGBOX("Benzinverbrach >0 bzw. <40 Liter"); control:=1; END; DEFAULT control:=0; END; //ENDE CASE-Anweisung UNTIL control <1; IF ABS(D500-B500)<0.02 AND (C500<A500) THEN RW1:=180; LA1:=60*(A500-C500); END; IF ABS(D500-B500)<0.02 AND (C500>A500) THEN RW1:=0; LA1:=60*(C500-A500); END; IF ABS(C500-A500)<0.02 AND (D500<B500) THEN RW1:=270; LA1:=60*(B500-D500)*COS(A500); END; IF ABS(C500-A500)<0.02 AND (D500>B500) THEN RW1:=90; LA1:=60*(B500-D500)*COS(A500); END; X1:=0.00758*(D500-B500); Y1:=(LOG(TAN(45+C500/2))-LOG(TAN(45+A500/2))); RW1:=ATAN(X1/Y1); LA1:=(C500-A500)*60/COS(RW1); IF LA1<0 THEN LA1:=-1*LA1; RW1:=RW1-180;END; IF RW1<0 THEN RW1:=360+RW1; END; IF RW1>360 THEN RW1:=RW1-360; END; WC1:=0; IF ABS(WR1-RW1-180)<2 THEN VG1:=TA1+WS1; END; IF ABS(WR1-RW1)<2 THEN VG1:=TA1-WS1; END; X2:=SIN(WR1-RW1-180); IF X2==0 THEN Z1:=LA1/VG1 ELSE WC1:=ASIN(WS1*X2/TA1); Y2:=SIN(360+RW1-WR1-WC1)*TA1; VG1:=Y2/X2; MW1:=RW1-WC1-DE1-VA1; IF MW1<0 THEN MW1:=360+MW1; END; IF MW1>360 THEN MW1:=MW1-360; END; Z1:=LA1/VG1; END; //Ende von IF THEN ELSE IF Z1==IP(Z1) THEN P3:=0; Z1:=IP(Z1); P3:=IP(P3) ELSE P3:=FP(Z1)*60; END; BM1:=IP((0.2+Z1)*BN1); // Benm1=Benzinverbrauch SW1:=ROUND(ABS(SIN(RW1-WR1)*WS1),1);//Seitenwind VW1:=ROUND(WC1*-1,0);//Vorhaltewinkel GG1:=ROUND(VG1,0);//Geschwindigkeit über Grund CH1:=ROUND(MW1,0);//Kompaskurs //BEGINN GRAFIK LOCAL X,Y,WI,N; LOCAL U,V; LOCAL F:=#FF0000; //ROT LOCAL O:=RGB(0,0,128); //BLAU RECT(RGB(154,205,50)); //REPEAT //K:=GETKEY; //INPUT(WI) ARC_P(160,120,60); ARC_P(160,120,59,RGB(0,120,15),RGB(150,150,150)); ARC_P(160,120,4);ARC_P(160,120,3); TEXTOUT_P("Flugrichtung "+ROUND(RW1,0)+"°",20,5,4); FOR N FROM 1 TO 4 STEP 1 DO ARC_P(10,13,N,F); END; TEXTOUT_P("Wind aus "+ROUND(WR1,0)+"°"+" / "+WS1+" KN",20,210,4); FOR N FROM 1 TO 4 STEP 1 DO ARC_P(10,219,N,O); END; TEXTOUT_P("N",153,30,6); RECT_P(159,55,161,65,#000000); TEXTOUT_P("O",229,107,6); RECT_P(95,119,105,121,#000000); TEXTOUT_P("S",155,186,6); RECT_P(159,175,161,185,#00000); TEXTOUT_P("W",72,107,6); RECT_P(215,119,225,121,#000000); IF (RW1>=90 AND RW1<=270) THEN TEXTOUT_P("Start",145,100,3) ELSE TEXTOUT_P("Start",145,125,3); END; //FLUGRICHTUNG IF (RW1>=0 AND RW1<=90) THEN X:=IP(SIN(RW1)*60); Y:=IP(√(60^2-X^2)); LINE_P(160,120,(160+X),(120-Y)); FOR N FROM 1 TO 4 STEP 1 DO ARC_P(160+X,120-Y,N,F); END; END; //WINDRICHTUNG IF (WR1>=0 AND WR1<=90) THEN U:=IP(SIN(WR1)*60); V:=IP(√(60^2-U^2)); LINE_P((160+U/1.4),(120-V/1.4),(160+U),(120-V)); FOR N FROM 1 TO 4 STEP 1 DO ARC_P(160+U,120-V,N,O); END; END; //FLUGRICHTUNG IF (RW1>90 AND RW1<=180) THEN X:=IP(SIN(RW1)*60); Y:=IP(√(60^2-X^2)); LINE_P(160,120,(160+X),(120+Y)); FOR N FROM 1 TO 4 STEP 1 DO ARC_P(160+X,120+Y,N,F); END; END; //WINDRICHTUNG IF (WR1>90 AND WR1<=180) THEN U:=IP(SIN(WR1)*60); V:=IP(√(60^2-U^2)); LINE_P((160+U/1.4),(120+V/1.4),(160+U),(120+V)); FOR N FROM 1 TO 4 STEP 1 DO ARC_P(160+U,120+V,N,O); END; END; //FLUGRICHTUNG IF (RW1>180 AND RW1<=270) THEN X:=IP(SIN(RW1-180)*60); Y:=IP(√(60^2-X^2)); LINE_P(160,120,(160-X),(120+Y)); FOR N FROM 1 TO 4 STEP 1 DO ARC_P(160-X,120+Y,N,F); END; END; //WINDRICHTUNG IF (WR1>180 AND WR1<=270) THEN U:=IP(SIN(WR1-180)*60); V:=IP(√(60^2-U^2)); LINE_P((160-U/1.4),(120+V/1.4),(160-U),(120+V)); FOR N FROM 1 TO 4 STEP 1 DO ARC_P(160-U,120+V,N,O); END; END; //FLUGRICHTUNG IF (RW1>270 AND RW1<=360) THEN X:=IP(COS(RW1-270)*60); Y:=IP(√(60^2-X^2)); LINE_P(160,120,(160-X),(120-Y)); FOR N FROM 1 TO 4 STEP 1 DO ARC_P(160-X,120-Y,N,F); END; END; //WINDRICHTUNG IF (WR1>270 AND WR1<=360) THEN U:=IP(COS(WR1-270)*60); V:=IP(√(60^2-U^2)); LINE_P((160-U/1.4),(120-V/1.4),(160-U),(120-V)); FOR N FROM 1 TO 4 STEP 1 DO ARC_P(160-U,120-V,N,O); END; END; WAIT(); //RETURN //UNTIL K==0; //ENDE GRAFIK RECT(RGB(154,205,50)); PRINT(); TEXTOUT_P("F L U G N A V I G A T I O N",31,10,7,RGB(255,255,255)); TEXTOUT_P("Rechtsw. Kurs zum Ziel: ",10,40,4); TEXTOUT_P("=",190,40,4); TEXTOUT_P((ROUND(RW1,0)+" Grad"),210,40,4); TEXTOUT_P("Entfernung: ",10,60,4); TEXTOUT_P("=",190,60,4); TEXTOUT_P((ROUND(LA1,0)+" NM"),210,60,4); TEXTOUT_P("Kompas Kurs [CH]: ",10,80,4); TEXTOUT_P("=",190,80); TEXTOUT_P((ROUND(CH1,0)+" Grad"),210,80,4); TEXTOUT_P("Geschwind. über Grund: ",10,100,4); TEXTOUT_P("=",190,100,4); TEXTOUT_P((ROUND(GG1,0)+" Grad"),210,100,4); TEXTOUT_P("Vorhaltewinkel: ",10,120,4); TEXTOUT_P("=",190,120,4); TEXTOUT_P((ROUND(VW1,0)+" Grad"),210,120,4); TEXTOUT_P("Seitenwindkomponente: ",10,140,4); TEXTOUT_P("=",190,140,4); TEXTOUT_P((ROUND(SW1,0)+" Grad"),210,140,4); TEXTOUT_P(("Flugzeit "+(IP(Z1))+" Stunde "+(IP(P3))+" [Minuten]"),10,175,4); TEXTOUT_P(("Benzinverbrauch "+BM1+" Liter"),10,195,4); DRAWMENU("ENDE","","NavNeu","","","zurück"); REPEAT // Get mouse data REPEAT m:=MOUSE; m1:=m(1); UNTIL SIZE(m1)>0; mx:=m1(1); my:=m1(2); // ENDE IF (my≥220 AND my≤319) AND (mx≥0 AND mx≤51) THEN Line:=0; Startview(-1); END; STARTVIEW(-4); //Flugnavigation neu IF (my≥220 AND my≤319) AND (mx≥106 AND mx≤157) THEN Line:=1; END; //END; //END; //Close main loop UNTIL ((my≥220 AND my≤319) AND (mx≥0 AND mx≤51) or (my≥220 AND my≤319) AND (mx≥256 AND mx≤319) or (my≥220 AND my≤319) AND (mx≥106 AND mx≤157)); END; END; //END Line7 Flugparameter STARTVIEW(-4); END;// MyNav |
04-09-2017, 01:55 PM
You need to read the documentation, the example was just to get you starting.
Read about how to use STARTAPP, STARTVIEW, etc and everything is going to make more sense. My website: ried.cl |
